The actual problem: I want to store some stuff to flash at factory, that is never erased. And I also need another persistent memory that can be written in runtime. I figured that the best ways to achieve this is to make two partitions and define the other one as read only(in application level)
And the 8 hours of head banging problem:
What are the steps to define a second partition for NVS use? I've tried to read the docs and concluded that it should work by just adding e.g. this to my custom overlay file
&flash0 { partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; boot_partition: partition@0 { label = "mcuboot"; reg = <0x00000000 0x10000>; }; ... // Clip the others away, same as DK board definitions ... storage_partition: partition@fa000 { label = "storage"; reg = <0x000fa000 0x00005000>; }; permanent_storage_partition: partition@ff000 { label = "storage-1"; reg = <0x000ff000 0x00001000>; }; }; };
However this causes FLASH_AREA_OFFSET(storage_1) macro to give strange errors:
nordic/ncs/nrf/include/flash_map_pm.h:34:11: error: 'PM_PM_PM_storage_1_ID_LABEL_ADDRESS' undeclared (first use in this function) UTIL_CAT(PM_, UTIL_CAT(UTIL_CAT(PM_, UTIL_CAT(PM_ID(label), _LABEL)), _ADDRESS))
I also tried to modify the /ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_common.dts file directly, but after rm -rf:ing the build folder and rebuild I get the same error. When I grep my build folder I see these:
jussi@jussi-VirtualBox:~/devel/loopshore/loneplus-embedded/nrf91$ grep -r -E "STORAGE_" build/* build/mcuboot/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_ADDRESS 0xfa000 build/mcuboot/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_SIZE 0x6000 build/mcuboot/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_NAME nvs_storage build/mcuboot/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_ID 7 build/mcuboot/zephyr/include/generated/pm_config.h:#define PM_nvs_storage_ID PM_NVS_STORAGE_ID build/mcuboot/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_DEV_NAME "NRF_FLASH_DRV_NAME" build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_ID 6 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_READ_ONLY 0 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_OFFSET_0 1024000 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_OFFSET DT_FLASH_AREA_STORAGE_OFFSET_0 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_SIZE_0 20480 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_SIZE DT_FLASH_AREA_STORAGE_SIZE_0 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_DEV "NRF_FLASH_DRV_NAME" build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_ID 7 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_READ_ONLY 0 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_OFFSET_0 1044480 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_OFFSET DT_FLASH_AREA_STORAGE_1_OFFSET_0 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_SIZE_0 4096 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_SIZE DT_FLASH_AREA_STORAGE_1_SIZE_0 build/mcuboot/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_DEV "NRF_FLASH_DRV_NAME" build/pm_nrf9160dk_nrf9160.config:PM_NVS_STORAGE_ADDRESS=0xfa000 build/pm_nrf9160dk_nrf9160.config:PM_NVS_STORAGE_SIZE=0x6000 build/pm_nrf9160dk_nrf9160.config:PM_NVS_STORAGE_NAME=nvs_storage build/pm_nrf9160dk_nrf9160.config:PM_NVS_STORAGE_ID=7 build/pm_nrf9160dk_nrf9160.config:PM_nvs_storage_ID=PM_NVS_STORAGE_ID build/spm/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_ADDRESS 0xfa000 build/spm/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_SIZE 0x6000 build/spm/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_NAME nvs_storage build/spm/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_ID 7 build/spm/zephyr/include/generated/pm_config.h:#define PM_nvs_storage_ID PM_NVS_STORAGE_ID build/spm/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_DEV_NAME "NRF_FLASH_DRV_NAME" build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_ID 6 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_READ_ONLY 0 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_OFFSET_0 1024000 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_OFFSET DT_FLASH_AREA_STORAGE_OFFSET_0 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_SIZE_0 20480 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_SIZE DT_FLASH_AREA_STORAGE_SIZE_0 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_DEV "NRF_FLASH_DRV_NAME" build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_ID 7 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_READ_ONLY 0 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_OFFSET_0 1044480 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_OFFSET DT_FLASH_AREA_STORAGE_1_OFFSET_0 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_SIZE_0 4096 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_SIZE DT_FLASH_AREA_STORAGE_1_SIZE_0 build/spm/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_DEV "NRF_FLASH_DRV_NAME" build/zephyr/include/generated/autoconf.h:#define CONFIG_STORAGE_LOOPONE_LOG_LEVEL 4 build/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_ADDRESS 0xfa000 build/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_SIZE 0x6000 build/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_NAME nvs_storage build/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_ID 7 build/zephyr/include/generated/pm_config.h:#define PM_nvs_storage_ID PM_NVS_STORAGE_ID build/zephyr/include/generated/pm_config.h:#define PM_NVS_STORAGE_DEV_NAME "NRF_FLASH_DRV_NAME" build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_ID 6 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_READ_ONLY 0 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_OFFSET_0 1024000 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_OFFSET DT_FLASH_AREA_STORAGE_OFFSET_0 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_SIZE_0 20480 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_SIZE DT_FLASH_AREA_STORAGE_SIZE_0 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_DEV "NRF_FLASH_DRV_NAME" build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_ID 7 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_READ_ONLY 0 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_OFFSET_0 1044480 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_OFFSET DT_FLASH_AREA_STORAGE_1_OFFSET_0 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_SIZE_0 4096 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_SIZE DT_FLASH_AREA_STORAGE_1_SIZE_0 build/zephyr/include/generated/devicetree_legacy_unfixed.h:#define DT_FLASH_AREA_STORAGE_1_DEV "NRF_FLASH_DRV_NAME"
So it looks like partition sizes have changed, but some PM_NVS constants still hold the original value. Also some offsets show over 1M values, which does not sound too good->Edit: ok those are decimal values so nothing wrong with those(1024000->0xFA000). Anyway, any hints about the steps that I am missing or doing wrong are appreciated.
Edit: I have a custom board, but still compiling with DK device tree definitions + some overlays. NRF sdk 1.3
