How to DFU the SD from 7 to 8
Hi all,
I want to upgrade current SD from 7.0 to 8.0 by DFU, and try it as followed:
1.Use the nRF Toolbox 1.12 in Android; 2.Select 'Soft Device' as the file type and load SD8.0 hex; 3.Select the DfuTarg, and click the upload button; 4.But it return Error with remote DFU not supported(3);
There is no problem on DFU application yet. So, I am not clear on what's wrong on this.
Is it need to use the distribution packet ZIP way? If YES, I see the info show it should use the NRF UTILITY which is a part on MCP 3.8.0+, could you guide me how to create such ZIP file by any documents?
Thanks a lot.
  • Perhaps it is time to answer this question properly :)
    With S110 7 and bootloader from SDK 7, softdevice and bootloader updates were possible with an over the air update. This means that if you have i.e. S110 7 + bootloader from SDK 7, it is possible to update the device over the air (via Master Control Panel for Windows PC or nFR Toolbox app for Android, IOS or Windows phone) to contain S110 8 and bootloader from SDK 8 or SDK 9.
    PART 1: Flashing softdevice+bootloader+application to the device
    If you merge e.g. the following files with mergehex.exe
    s110_nrf51822_7.3.0_softdevice.hex
    BL7_1.hex
    ble_app_bps_SDK_7_1_0.hex
    app_valid_setting_apply.hex
    into one file
    SD_BL_APP_valid.hex
    with the following command sequence:
    mergehex --merge s110_nrf51822_7.3.0_softdevice.hex BL7_1.hex --output SD_BL.hex
    mergehex --merge SD_BL.hex ble_app_bps_SDK_7_1_0.hex --output SD_BL_APP.hex
    mergehex --merge SD_BL_APP.hex app_valid_setting_apply.hex --output SD_BL_APP_valid.hex
    and then flash the file onto your nRF51-DK board (PCA10028) using nrfjprog.exe with
    nrfjprog --program SD_BL_APP_valid.hex
    then the ble_app_bps application should be advertising on your nRF51-DK.
    Another method of obtaining the same thing without merging the files is with flashing the 4 files directly with the following command sequence:
    nrfjprog --eraseall
    nrfjprog --dfu --programs s110_nrf51822_7.3.0_softdevice.hex
    nrfjprog --program BL7_1.hex
    nrfjprog --program ble_app_bps_SDK_7_1_0.hex
    nrfjprog --program app_valid_setting_apply.hex
    It is also possible to upload softdevice and bootloader with nrfgo Studio. The steps are shown on this thread.
    PART 2: Creating the softdevice 8 + bootloader 8 zip file
    If you now want to update the device over the air to contain e.g. S110 8 and bootloader from SDK 8.1, you must first create a zip file that contains the new S110 8 and bootloader 8.1. Use the nrf.exe tool to create this and follow this description. With the following S110 file and bootloader file
    s110_nrf51_8.0.0_softdevice.hex
    BL8_1.hex
    it is possible to create a zip file with the following command
    nrf dfu genpkg --bootloader BL8_1.hex --softdevice s110_nrf51_8.0.0_softdevice.hex --application-version 0xffff --dev-revision 0xff --dev-type 0xff --sd-req 0xfffe SD_8_BL_8_1.zip
    which should create this zip file
    SD_8_BL_8_1.zip
    PART 3: Upload the zip file to the device
    Now you can upload the zip file to the device via Master Control Panel for PC, or nRF Toolbox for Android, IOS or Windows Phone which will make the device start bootloader 8.1 when upload is complete. Before uploading the file, you must start the device in bootloader mode by power-resetting the nRF51-DK board while pushing Button_4. LED_1 and LED_3 should light up to indicate that the device is in bootloader mode.
    BL7_1.hex
    into one file
    SD_BL_APP_valid.hex
    nrfjprog --eraseall
    BL8_1.hex
    SD_8_BL_8_1.zip
