Hi !
When I try to debug myself, I notice that my error appears on line 97 : ret = connect(client->transport.tls.sock, client->broker, peer_addr_size);
could you help me ? thanks in advance
Hi !
Hello, lecozahu!
What sample have you based your project on and what amendments have you made?
Error -95 is probably EOPNOTSUPP, meaning that the requested operation is not supported on the socket.
Carl Richard
Carl Richard,
I was based on the aws_fota project, I did not touch the main, it is during the initialization of the client that the error appears.
I modified several things:
- I have defined CONFIG_PROVISION_CERTIFICATES
-I modified the certificate with the private, public and CA keys
-I modified in Kconf the address of the broker ending with amazonaws.com
- I modified CONFIG_CLOUD_CLIENT_ID and put it in the name of the object created on aws.
-I kept port 8883
lecozahu
Hello again!
I'm trying to reproduce the issue myself now. While I'm at it, did you make sure to add the three certificates correctly with < "(...)\n"\ > at every line?
Note aswell that you must add the public certificate, not the public key.
Carl Richard
That could be your error, yes.
The CLOUD_CLIENT_PUBLIC_CERTIFICATE should contain the .cert.perm you received. The CLOUD_CA_CERTIFICATE should contain the AWS root certificate which is found here. Hope this helps!
Carl Richard
