I need to digitize one input every 10 usec and store results into memory. After say 100000 samples the ADC should stop.
Thanks
Thanks
You should be able to achieve this with the SAADC example from the SDK with only minor modifications. You need to lower the acquisition time to 5 us in order to take a sample every 10 us (as the SAADC also has a 2 us conversion time for each sample). The timer must be changed to trigger every 10 us, and you need a counter to know when to stop sampling. It is also a good idea to increase the buffer size, to reduce the number of interrupts. The SAADC peripheral can accept buffer sizes up to 32767 samples in a single buffer.
I attached a sample main.c that you can replace in the SAADC example. It does stop the timer and disable PPI channel after 100 events of buffer size 1000 samples are received, but it does not disable/uninitialize the SAADC peripheral. The example also re-uses the same two 1000 sample buffers over and over. If you need to store all samples in RAM, you can use 100 different buffers of 1000 samples each that you setup using the nrf_drv_saadc_buffer_convert() function.
* Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup nrf_adc_example main.c
* @ingroup nrf_adc_example
* @brief ADC Example Application main file.
* This file contains the source code for a sample application using ADC.
* @image html example_board_setup_a.jpg "Use board setup A for this example."
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SAMPLES_IN_BUFFER 1000
#define TOTAL_BUFFER_EVENT_COUNT 100 //100 000
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t m_ppi_channel;
static uint32_t m_adc_evt_counter;
void timer_handler(nrf_timer_event_t event_type, void * p_context)
ret_code_t err_code;
/* setup m_timer for compare event every 400ms */
uint32_t ticks = nrf_drv_timer_us_to_ticks(&m_timer, 10); // Trigger sample task every 10 us
NRF_TIMER_CC_CHANNEL0,
ticks,
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
false);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
timer_compare_event_addr,
saadc_sample_task_addr);
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
int i;
NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
// for (i = 0; i < SAMPLES_IN_BUFFER; i++)
// NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
m_adc_evt_counter++;
if(m_adc_evt_counter == TOTAL_BUFFER_EVENT_COUNT)
nrf_drv_ppi_channel_disable(m_ppi_channel); // Disable events from TIMER to trigger SAADC SAMPLE
nrf_drv_timer_disable(&m_timer); // Stop timer
void saadc_init(void)
nrf_saadc_channel_config_t channel_config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
channel_config.acq_time = NRF_SAADC_ACQTIME_5US;
err_code = nrf_drv_saadc_init(NULL, saadc_callback);
err_code = nrf_drv_saadc_channel_init(0, &channel_config);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
uint32_t err_code = NRF_LOG_INIT(NULL);
ret_code_t ret_code = nrf_pwr_mgmt_init();
APP_ERROR_CHECK(ret_code);
saadc_init();
saadc_sampling_event_init();
NRF_LOG_INFO("SAADC HAL simple example started.");
while (1)
nrf_pwr_mgmt_run();
NRF_LOG_FLUSH();
Jørgen
Thank you for the code. It works.
I found that if one connects A0 input to VDD on the board the values in the first buffer is much lower than in the subsequent buffers.
It does not happened if I connect ADC input to VDD internally, i.e. replace NRF_SAADC_INPUT_AIN0 with NRF_SAADC_INPUT_VDD.
Here is my modifications:
for (i = 0; i < 2; i++)
and here is prinout when usnig NRF_SAADC_INPUT_AIN0 :
<info> app: SAADC HAL simple example started.
<info> app: ADC event number: 0
<info> app: 35
<info> app: 39
<info> app: ADC event number: 1
<info> app: 169
<info> app: 169
<info> app: ADC event number: 2
<info> app: 171
<info> app: 167
<info> app: ADC event number: 3
Can you explain this?
Mike
I'm not sure exactly what is causing this, but it could be related to charging of the internal capacitor when the input is floating. When the pin has not been sampled for a while, it may take longer for the capacitor to be changed than it does for the subsequent samplings that are performed almost back-to-back. Note that this is purely speculations, there could be other reasons for this as well. As long as you are not planning to sample floating inputs, and the first sample does not show this behavior when the inputs are connected, I do not see this as an issue.
