Reading ADC value in nrf52805
I want to read ADC values from AIN2 (P0.04), and AIN3 (P0.05) channels of nrf52805. I am using S112, and I have the following code found in the internet.
float readADC(uint8_t channel)
    volatile int16_t result = 0;
  volatile float precise_result = 0;
  // Start HFCLK from crystal oscillator, this will give the SAADC higher accuracy
  while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
  // Configure SAADC singled-ended channel, Internal reference (0.6V) and 1/6 gain.
  NRF_SAADC->CH[channel].CONFIG = (SAADC_CH_CONFIG_GAIN_Gain1_6    << SAADC_CH_CONFIG_GAIN_Pos) |
                            (SAADC_CH_CONFIG_MODE_SE         << SAADC_CH_CONFIG_MODE_Pos) |
                            (SAADC_CH_CONFIG_REFSEL_Internal << SAADC_CH_CONFIG_REFSEL_Pos) |
                            (SAADC_CH_CONFIG_RESN_Bypass     << SAADC_CH_CONFIG_RESN_Pos) |
                            (SAADC_CH_CONFIG_RESP_Bypass     << SAADC_CH_CONFIG_RESP_Pos) |
                            (SAADC_CH_CONFIG_TACQ_3us        << SAADC_CH_CONFIG_TACQ_Pos);
  // Configure the SAADC channel with VDD as positive input, no negative input(single ended).
  NRF_SAADC->CH[channel].PSELP = SAADC_CH_PSELP_PSELP_VDD << SAADC_CH_PSELP_PSELP_Pos;
  NRF_SAADC->CH[channel].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos;
  // Configure the SAADC resolution.
  NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_14bit << SAADC_RESOLUTION_VAL_Pos;
  // Configure result to be put in RAM at the location of "result" variable.
  NRF_SAADC->RESULT.MAXCNT = 1;
  NRF_SAADC->RESULT.PTR = (uint32_t)&result;
  // No automatic sampling, will trigger with TASKS_SAMPLE.
  NRF_SAADC->SAMPLERATE = SAADC_SAMPLERATE_MODE_Task << SAADC_SAMPLERATE_MODE_Pos;
  // Enable SAADC (would capture analog pins if they were used in CH[0].PSELP)
  NRF_SAADC->ENABLE = SAADC_ENABLE_ENABLE_Enabled << SAADC_ENABLE_ENABLE_Pos;
  // Calibrate the SAADC (only needs to be done once in a while)
  NRF_SAADC->TASKS_CALIBRATEOFFSET = 1;
  while (NRF_SAADC->EVENTS_CALIBRATEDONE == 0);
  NRF_SAADC->EVENTS_CALIBRATEDONE = 0;
  while (NRF_SAADC->STATUS == (SAADC_STATUS_STATUS_Busy <<SAADC_STATUS_STATUS_Pos));
  // Start the SAADC and wait for the started event.
  NRF_SAADC->TASKS_START = 1;
  while (NRF_SAADC->EVENTS_STARTED == 0);
  NRF_SAADC->EVENTS_STARTED = 0;
  // Do a SAADC sample, will put the result in the configured RAM buffer.
  NRF_SAADC->TASKS_SAMPLE = 1;
  while (NRF_SAADC->EVENTS_END == 0);
  NRF_SAADC->EVENTS_END = 0;
  // Convert the result to voltage
  // Result = [V(p) - V(n)] * GAIN/REFERENCE * 2^(RESOLUTION)
  // Result = (VDD - 0) * ((1/6) / 0.6) * 2^14
  // VDD = Result / 4551.1
  precise_result = (float)result / 4551.1f;
  // Stop the SAADC, since it's not used anymore.
  NRF_SAADC->TASKS_STOP = 1;
  while (NRF_SAADC->EVENTS_STOPPED == 0);
  NRF_SAADC->EVENTS_STOPPED = 0;
    return precise_result;
 * @brief Function for application main entry.
    ret_code_t err_code;
      timers_init();
     power_management_init();
      float value1 = readADC(2);
      float value2 = readADC(3);
    // Enter main loop.
    for (;; )
        idle_state_handle();
The voltage input on both channels is 1.2V.
value1 reads -0.012 (which fluctuates around 0) and value2 shows 2.4V.
I am not sure why value2 = Actual voltage * 2 but I can live with it as it is consistent.
Why am I not getting ADC value from AIN2?
I tested this with multiple nrf52805 chips but the same result.
    Here is a simpler SAADC example to look into for configuring channels, and read adc measurements also converting that to voltage measurements.
    https://github.com/rmptxf/nrf52_saadc_simplified
    rmptxf
    Where is this code from?
    How have you verified / set this up? Have you measured the voltage input to the channels with an external multimeter / oscilloscope?
    It seems to me that you are never setting the channels to point to your AIN2 and AIN3 pins - you are using different channels, but both channels are set up to measure VDD.
    What is your VDD, by the way?
    Is there a particular reason for why you would like to manipulate the registers directly, instead of using the nrfx driver or legacy driver?
    I would highly recommend making use of the drivers, since they do all this ground work for you - so that you do not have to look into every register yourself.
    For future reference, please use the "Insert -> Code" option when sharing code in the forum for increased readability.
    Karl
