nRF52840 DK, implementing Board Button event handler, but no response on button press.
I am trying to do some tasks based on a particular button press, below attached is the buttons_init() function and the button_evt_handler() function. Code compiles and runs successfully, but nothing happens on button press. Please let me know if I am missing out on something.
Thanks in advance.
static void buttons_init(void)
    uint32_t err_code;
    static app_button_cfg_t buttons[] =
        {BSP_BUTTON_0, false, BUTTON_PULL, button_evt_handler},
        {BSP_BUTTON_1, false, BUTTON_PULL, button_evt_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DEBOUNCE_DELAY);
    err_code = app_button_enable();
static void button_evt_handler(uint8_t pin_no, uint8_t button_action)
    if(button_action == APP_BUTTON_PUSH)
        switch(pin_no)
            case BSP_BUTTON_0:
                NRF_LOG_INFO("Sending blood pressure data\r\n");
            case BSP_BUTTON_1:
                NRF_LOG_INFO("Sending temperature data\r\n");
                NRF_LOG_INFO("Default case\r\n");
  • Sure, i have added to the ble_app_template example, here is the main.c:
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdint.h>
    #include <string.h>
    #include "our_service.h"
    #include "ble_srv_common.h"
    #include "app_error.h"
    #include "SEGGER_RTT.h"
    /** @file
     * @defgroup ble_sdk_app_template_main main.c
     * @ingroup ble_sdk_app_template
     * @brief Template project main file.
     * This file contains a template for creating a new application. It has the code necessary to wakeup
     * from button, advertise, get a connection restart advertising on disconnect and if no new
     * connection created go back to system-off mode.
     * It can easily be used as a starting point for creating a new application, the comments identified
     * with 'YOUR_JOB' indicates where and how you can customize.
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "fds.h"
    #include "peer_manager.h"
    #include "bsp_btn_ble.h"
    #include "sensorsim.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME                     "OurService"                            /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME               "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL                50                                      /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define BUTTON_DEBOUNCE_DELAY           APP_TIMER_TICKS(50)
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    // STEP 1: Declare a ble_os_t service structure for our application
    ble_os_t m_our_service;
    // STEP 5: Declare variable holding our service UUID
    static ble_uuid_t m_adv_uuids[] =
            BLE_UUID_OUR_SERVICE_UUID,
            BLE_UUID_TYPE_VENDOR_BEGIN
    static void advertising_start(bool erase_bonds);
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        // Create timers.
        /* YOUR_JOB: Create any timers to be used by the application.
                     Below is an example of how to create a timer.
                     For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                     one.
           ret_code_t err_code;
           err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
           APP_ERROR_CHECK(err_code); */
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        switch (p_evt->evt_id)
            case PM_EVT_BONDED_PEER_CONNECTED:
                NRF_LOG_INFO("Connected to a previously bonded device.");
            } break;
            case PM_EVT_CONN_SEC_SUCCEEDED:
                NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                /* Often, when securing fails, it shouldn't be restarted, for security reasons.
                 * Other times, it can be restarted directly.
                 * Sometimes it can be restarted, but only after changing some Security Parameters.
                 * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
                 * Sometimes it is impossible, to secure the link, or the peer device does not support it.
                 * How to handle this error is highly application dependent. */
            } break;
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Reject pairing request from an already bonded peer.
                pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
                pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
            } break;
            case PM_EVT_STORAGE_FULL:
                // Run garbage collection on the flash.
                err_code = fds_gc();
                if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                    // Retry.
            } break;
                advertising_start(false);
            } break;
            case PM_EVT_PEER_DATA_UPDATE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
            } break;
            case PM_EVT_PEER_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
            } break;
            case PM_EVT_PEERS_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
            } break;
            case PM_EVT_ERROR_UNEXPECTED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
            } break;
            case PM_EVT_CONN_SEC_START:
            case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            case PM_EVT_PEER_DELETE_SUCCEEDED:
            case PM_EVT_LOCAL_DB_CACHE_APPLIED:
            case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
                // This can happen when the local DB has changed.
            case PM_EVT_SERVICE_CHANGED_IND_SENT:
            case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    /**@brief Function for handling the YYY Service events.
     * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
     * @details This function will be called for all YY Service events which are passed to
     *          the application.
     * @param[in]   p_yy_service   YY Service structure.
     * @param[in]   p_evt          Event received from the YY Service.
    static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                           ble_yy_service_evt_t * p_evt)
        switch (p_evt->evt_type)
            case BLE_YY_NAME_EVT_WRITE:
                APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
                // No implementation needed.
        APP_ERROR_HANDLER(nrf_error);
        // STEP 2: Add code to initialize the services used by the application.
        our_service_init(&m_our_service);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail config parameter, but instead we use the event
     *                handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
    /**@brief Function for starting timers.
    static void application_timers_start(void)
        /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
           err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
        // Prepare wakeup buttons.
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising.");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        ret_code_t err_code = NRF_SUCCESS;
                NRF_LOG_INFO("Disconnected.");
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected.");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
        NRF_SDH_BLE_OBSERVER(m_our_service_observer, APP_BLE_OBSERVER_PRIO, ble_our_service_on_ble_evt, (void *)&m_our_service);
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
     * @param[in]   event   Event generated when button is pressed.
    /*static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
                break; // BSP_EVENT_SLEEP
            case BSP_EVENT_DISCONNECT:
                break; // BSP_EVENT_DISCONNECT
            case BSP_EVENT_WHITELIST_OFF:
                break; // BSP_EVENT_KEY_0
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    	// STEP 6: Declare and instantiate the scan response
        init.srdata.uuids_complete.p_uuids = m_adv_uuids;
    void send_string()
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
      switch(pin_no)
       case BUTTON_1:
         if(button_action == APP_BUTTON_PUSH) {
            //Send BP data
         else if(button_action == APP_BUTTON_RELEASE) {
            NRF_LOG_INFO("button1 released.");
       case BUTTON_2:
            int32_t temperature = 0;
            sd_temp_get(&temperature);
            our_temperature_characteristic_update(&m_our_service, &temperature);
            NRF_LOG_INFO("button2 released.");
       case BUTTON_3:
            send_string();
            NRF_LOG_INFO("button3 released.");
       case BUTTON_4:
            NRF_LOG_INFO("button4 pressed.");
            NRF_LOG_INFO("button4 released.");
            return; // no implementation needed
        bsp_event_t startup_event;
        /*err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
        APP_ERROR_CHECK(err_code);*/
    static const app_button_cfg_t buttons[BUTTONS_NUMBER] =
        {BUTTON_1, BUTTONS_ACTIVE_STATE, BUTTON_PULL, button_event_handler},
        {BUTTON_2, BUTTONS_ACTIVE_STATE, BUTTON_PULL, button_event_handler},
        {BUTTON_3, BUTTONS_ACTIVE_STATE, BUTTON_PULL, button_event_handler},
        {BUTTON_4, BUTTONS_ACTIVE_STATE, BUTTON_PULL, button_event_handler}
        err_code = app_button_init((app_button_cfg_t *)buttons, BUTTONS_NUMBER, BUTTON_DEBOUNCE_DELAY);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    /**@brief Function for application main entry.
        bool erase_bonds;
        nrf_gpio_pin_dir_set(LED_1, NRF_GPIO_PIN_DIR_OUTPUT);
        // Initialize.
        log_init();
    	timers_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        NRF_LOG_INFO("started.");
        application_timers_start();
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
            idle_state_handle();
    2. our_service.c: For a custom service and characteristics:
    #include <stdint.h>
    #include <string.h>
    void ble_our_service_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
      	ble_os_t * p_our_service =(ble_os_t *) p_context;
    		// OUR_JOB: Step 3.D Implement switch case handling BLE events related to our service.
                    p_our_service->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
                    p_our_service->conn_handle = BLE_CONN_HANDLE_INVALID;
    /**@brief Function for adding our new characterstic to "Our service" that we initiated in the previous tutorial.
     * @param[in]   p_our_service        Our Service structure.
    static uint32_t our_char_add(ble_os_t * p_our_service)
        // OUR_JOB: Step 2.A, Add a custom characteristic UUID
        uint32_t          err_code;
        ble_uuid_t        char_uuid;
        ble_uuid128_t     base_uuid = BLE_UUID_OUR_BASE_UUID;
        char_uuid.uuid = BLE_UUID_OUR_CHARACTERISTC_UUID;
        err_code = sd_ble_uuid_vs_add(&base_uuid, &char_uuid.type);
        // OUR_JOB: Step 2.F Add read/write properties to our characteristic
        ble_gatts_char_md_t char_md;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.read = 1;
        char_md.char_props.write = 1;
        // OUR_JOB: Step 3.A, Configuring Client Characteristic Configuration Descriptor metadata and add to char_md structure
        ble_gatts_attr_md_t cccd_md;
        memset(&cccd_md, 0, sizeof(cccd_md));
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
        cccd_md.vloc = BLE_GATTS_VLOC_STACK;
        char_md.p_cccd_md = &cccd_md;
        char_md.char_props.notify = 1;
        // OUR_JOB: Step 2.B, Configure the attribute metadata
        ble_gatts_attr_md_t attr_md;
        memset(&attr_md, 0, sizeof(attr_md));
        attr_md.vloc = BLE_GATTS_VLOC_STACK;
        // OUR_JOB: Step 2.G, Set read/write security levels to our characteristic
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
        // OUR_JOB: Step 2.C, Configure the characteristic value attribute
        ble_gatts_attr_t    attr_char_value;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid = &char_uuid;
        attr_char_value.p_attr_md = &attr_md;
        // OUR_JOB: Step 2.H, Set characteristic length in number of bytes
        attr_char_value.max_len = 4;
        attr_char_value.init_len = 4;
        uint8_t value[4] = {0x12, 0x34, 0x56, 0x78};
        attr_char_value.p_value = value;
        // OUR_JOB: Step 2.E, Add our new characteristic to the service
        err_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle, &char_md, &attr_char_value, &p_our_service->char_handles);
        return NRF_SUCCESS;
    static uint32_t our_char_bp_add(ble_os_t * p_our_service)
        uint32_t          err_code;
        char_uuid.uuid = BLE_UUID_BP_CHARACTERISTIC;
        err_code = sd_ble_gatts_characteristic_add(p_our_service->service_handle, &char_md, &attr_char_value, &p_our_service->char_bp_handles);
        return NRF_SUCCESS;
    /**@brief Function for initiating our new service.
    void our_service_init(ble_os_t * p_our_service)
        // STEP 3: Declare 16 bit service and 128 bit base UUIDs and add them to BLE stack table
        uint32_t      err_code;
        ble_uuid_t    service_uuid;
        service_uuid.uuid = BLE_UUID_OUR_SERVICE_UUID;
        err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid.type);
        // OUR_JOB: Step 3.B, Set our service connection handle to default value. I.e. an invalid handle since we are not yet in a connection.
    	// STEP 4: Add our service
        err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &service_uuid, &p_our_service->service_handle);
        our_char_add(p_our_service);
        our_char_bp_add(p_our_service);
        // Print messages to Segger Real Time Terminal
        // UNCOMMENT THE FOUR LINES BELOW AFTER INITIALIZING THE SERVICE OR THE EXAMPLE WILL NOT COMPILE.
    //    SEGGER_RTT_WriteString(0, "Executing our_service_init().\n"); // Print message to RTT to the application flow
    //    SEGGER_RTT_printf(0, "Service UUID: 0x%#04x\n", service_uuid.uuid); // Print service UUID should match definition BLE_UUID_OUR_SERVICE
    //    SEGGER_RTT_printf(0, "Service UUID type: 0x%#02x\n", service_uuid.type); // Print UUID type. Should match BLE_UUID_TYPE_VENDOR_BEGIN. Search for BLE_UUID_TYPES in ble_types.h for more info
    //    SEGGER_RTT_printf(0, "Service handle: 0x%#04x\n", p_our_service->service_handle); // Print out the service handle. Should match service handle shown in MCP under Attribute values
    void our_temperature_characteristic_update(ble_os_t *p_our_service, int32_t *temperature_value)
    // OUR_JOB: Step 3.E, Update characteristic value
        if (p_our_service->conn_handle != BLE_CONN_HANDLE_INVALID)
    	uint16_t               len = 4;
    	ble_gatts_hvx_params_t hvx_params;
    	memset(&hvx_params, 0, sizeof(hvx_params));
    	hvx_params.handle = p_our_service->char_handles.value_handle;
    	hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
    	hvx_params.offset = 0;
    	hvx_params.p_len  = &len;
    	hvx_params.p_data = (uint8_t*)temperature_value;
    	sd_ble_gatts_hvx(p_our_service->conn_handle, &hvx_params);
    void our_bp_characteristic_update(ble_os_t *p_our_service, int32_t *bp_value)
    	uint16_t               len = 4;
    	hvx_params.handle = p_our_service->char_bp_handles.value_handle;
    	hvx_params.p_data = (uint8_t*)bp_value;
    3. our_service.h: Header for custom service and characteristics:
    5633.our_service.h
    Thanks again,
    Paarth
  • Hi Paarth
    What pins are your buttons (1-4) configured to? The onboard buttons on the nRF52840 DK are connected to pins P0.11, P0.12, P0.24, and P0.25.
    Simon
  • Hi ,
    Sorry for the delay.
    Well, you have a lot of issues in your ble service and characteristics. And I think this is where the issue come from.
    I have fixed lot of issues there, also added a function to get the SOC temperature and send it over the temperature characteristic. Also added another characteristic, I called it the command char, it can be used to send commands from the central to the application.
    The temperature char has the notify and the read property enabled, and can be used to send temperature values to the connected and subscribed central device.
    The command char has the write property enabled, and can be used to receive data from the central device.
    Try to use the UART, to see the application logging.
    Please find the project files in this github repos.
    rmptxf
  • Hi again,
    Thanks for the help, I was following a tutorial for creating a custom service and characteristic. I ll have a look at the code, thanks a lot again for this!
    Paarth
