nRF52840 DK, implementing Board Button event handler, but no response on button press.
I am trying to do some tasks based on a particular button press, below attached is the buttons_init() function and the button_evt_handler() function. Code compiles and runs successfully, but nothing happens on button press. Please let me know if I am missing out on something.
Thanks in advance.
static void buttons_init(void)
    uint32_t err_code;
    static app_button_cfg_t buttons[] =
        {BSP_BUTTON_0, false, BUTTON_PULL, button_evt_handler},
        {BSP_BUTTON_1, false, BUTTON_PULL, button_evt_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DEBOUNCE_DELAY);
    err_code = app_button_enable();
static void button_evt_handler(uint8_t pin_no, uint8_t button_action)
    if(button_action == APP_BUTTON_PUSH)
        switch(pin_no)
            case BSP_BUTTON_0:
                NRF_LOG_INFO("Sending blood pressure data\r\n");
            case BSP_BUTTON_1:
                NRF_LOG_INFO("Sending temperature data\r\n");
                NRF_LOG_INFO("Default case\r\n");
  • Hi ,
    Here is a better way to do it!
    #define UART_PRINTING_ENABLED   // comment it to disable the uart logging
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
      ret_code_t err_code;
      switch(pin_no)
       case BUTTON_1:
         if(button_action == APP_BUTTON_PUSH) {
            #ifdef UART_PRINTING_ENABLED
            NRF_LOG_INFO("button1 pressed.");
         else if(button_action == APP_BUTTON_RELEASE) {
            NRF_LOG_INFO("button1 released.");
       case BUTTON_2:
            NRF_LOG_INFO("button2 pressed.");
            NRF_LOG_INFO("button2 released.");
       case BUTTON_3:
            NRF_LOG_INFO("button3 pressed.");
            NRF_LOG_INFO("button3 released.");
       case BUTTON_4:
            NRF_LOG_INFO("button4 pressed.");
            NRF_LOG_INFO("button4 released.");
            return; // no implementation needed
    /**@brief Function for buttons configuration.
    static const app_button_cfg_t app_buttons[BUTTONS_NUMBER] =
    // BUTTONS_NUMBER,
    // BUTTON_PIN,
    // BUTTONS_ACTIVE_STATE,
    // BUTTON_PULL,
    // are all declared in your components/boards/Ppca10056.h file
        {BUTTON_1, BUTTONS_ACTIVE_STATE, BUTTON_PULL, button_event_handler},
        {BUTTON_2, BUTTONS_ACTIVE_STATE, BUTTON_PULL, button_event_handler},
        {BUTTON_3, BUTTONS_ACTIVE_STATE, BUTTON_PULL, button_event_handler},
        {BUTTON_4, BUTTONS_ACTIVE_STATE, BUTTON_PULL, button_event_handler}
    /**@brief Function for initializing the buttons with the app_button library.
     void buttons_init(){
    // BUTTONS_NUMBER  is declared in your components/boards/Ppca10056.h file
        err_code = app_button_init((app_button_cfg_t *)app_buttons,
                                                    BUTTONS_NUMBER,
                                             BUTTON_DETECTION_TIME);
    Make sure you initialize the timer before calling the buttons_init() in the main.
     *@brief Function for initialising the timers.
     * It is necessary for the buttons to work when using the app_button library.
    static void timers_init(void)
        // Initialize timer module.
        timers_init();
        leds_init();
        buttons_init();
    Also make sure to enable the app button module in the sdk_config.h file.
    // <q> BUTTON_ENABLED  - Enables Button module
    #ifndef BUTTON_ENABLED
    #define BUTTON_ENABLED 1
    And here is 4 key keyboard based off the nRF52840-DK. You can test it, or just re-use the button handling part for your case.
    The github repos
    rmptxf
    Thanks for your response, I tried to implement it using the code snippets you have provided. But still no response on button press. I have tried the following:
    1. Changed the button_event_handler as per the above.
    2. Changed the app_button_cfg_t structure to as defined above
    3. Called timer_init() before buttons_init()
    4. BUTTON_ENABLED was already set.
    Also, as a footnote, I am implementing this button handler along with a bsp_event_handler already defined, would it be affecting this handler or are they completely independent? Please let me know.
    Thanks again,
    Paarth
    How do you check whether a button is responding or not ? I mean, in the code snippet you provided, you're using the nRF logging. Is the uart logging already working ?
    What bsp events the bsp_event_handler is used for ?  for handling the buttons events too ?
    regards,
    rmptxf
    The bsp_event_handler is handling BSP_EVENT_SLEEP,  BSP_EVENT_DISCONNECT and BSP_EVENT_WHITELIST_OFF.
    I am only using the nRF logs for debugging.
    Thanks again,
    Paarth
    Would you mind sending your project files here, or email them. To look into the issue ?
