nrf_drv_clock_init()
.\_build\nrf52840_xxaa.axf: Error: L6218E: Undefined symbol nrf_drv_clock_init (referred from main.o).
.\_build\nrf52840_xxaa.axf: Error: L6218E: Undefined symbol nrf_drv_clock_lfclk_request (referred from main.o).
Not enough information to list image symbols.
Not enough information to list load addresses in the image map.
i am getting this error. Got to know that this can be due to the incorrect paths, but paths provided are correct.
how to debug this? as i am working on nrf52840 DK
    Have you added the nrf_drv_clock.c file to your project? And set NRF_CLOCK_ENABLED to 1 in the projects sdk_config.h?
  • Was a small typo in my last response. If you can't find it, add these clock settings to the sdk_config.h:
    // <e> NRF_CLOCK_ENABLED - nrf_drv_clock - CLOCK peripheral driver - legacy layer
    #ifndef NRF_CLOCK_ENABLED
    #define NRF_CLOCK_ENABLED 1
    // <o> CLOCK_CONFIG_LF_SRC  - LF Clock Source
    // <0=> RC
    // <1=> XTAL
    // <2=> Synth
    // <131073=> External Low Swing
    // <196609=> External Full Swing
    #ifndef CLOCK_CONFIG_LF_SRC
    #define CLOCK_CONFIG_LF_SRC 1
    // <o> CLOCK_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef CLOCK_CONFIG_IRQ_PRIORITY
    #define CLOCK_CONFIG_IRQ_PRIORITY 6
    // </e>
  • after including this piece of code, i got more errors
    .\_build\nrf52840_xxaa.axf: Error: L6218E: Undefined symbol nrfx_clock_disable (referred from nrf_drv_clock.o).
    .\_build\nrf52840_xxaa.axf: Error: L6218E: Undefined symbol nrfx_clock_enable (referred from nrf_drv_clock.o).
    .\_build\nrf52840_xxaa.axf: Error: L6218E: Undefined symbol nrfx_clock_hfclk_start (referred from nrf_drv_clock.o).
    .\_build\nrf52840_xxaa.axf: Error: L6218E: Undefined symbol nrfx_clock_hfclk_stop (referred from nrf_drv_clock.o).
    .\_build\nrf52840_xxaa.axf: Error: L6218E: Undefined symbol nrfx_clock_init (referred from nrf_drv_clock.o).
    .\_build\nrf52840_xxaa.axf: Error: L6218E: Undefined symbol nrfx_clock_lfclk_start (referred from nrf_drv_clock.o).
    .\_build\nrf52840_xxaa.axf: Error: L6218E: Undefined symbol nrfx_clock_lfclk_stop (referred from nrf_drv_clock.o).
    .\_build\nrf52840_xxaa.axf: Error: L6218E: Undefined symbol nrfx_clock_uninit (referred from nrf_drv_clock.o).
  • Can you try setting this NRFX_CLOCK_ENABLED to 1 if it aren't set to 1 already?
    How did you include the paths and what is your path?
  • Hi!
    I have a similar problem
    Expected expression problem in nrf_power_clock.h
        if (!NRFX_IRQ_IS_ENABLED(nrfx_get_irq_number(NRF_CLOCK)))
    I have no idea what the problem is should I insert a new post on this?
    cheers
    JH
    I suggest you make a new ticket including more details about your setup and issue.
