Upograded from SDK 15.0 to SDK 17.0
We are using today SDK 15.0 and are upgrading to SDK 17.0 for development of our system.
In our application, we use BLE communication.
While comparing SDK_config.h file of the example: "ble_nfc_pairing_reference". I saw that there are many differences between the files.
The question is how should we handle these changes?
option 1: Take all the changes?
option 2: Take only specific changes.
In the case of option 2, I would appreciate if you can describe which changes I should take.
I have attached 2 files to this question, you can compare them to further see my point.
1. nRF5_SDK_17.0.0_9d13099-org\examples\ble_peripheral\experimental\ble_nfc_pairing_reference\pca10056\s140\config
2. nRF5_SDK_15.0.0_a53641a-org\examples\ble_peripheral\experimental\ble_nfc_pairing_reference\pca10056\s140\config
3. At the bottom of this message is a summery of the differences.
I appreciate you'r support.
Alon Barak
SW development team
Qcore medical
sdk_config-17.hsdk_config-15.h
the dfinition change
PM_FLASH_BUFFERS changed from 2 to 4
NRF_MPU_ENABLED changed to  NRF_MPU_LIB_ENABLED
NRF_MPU_CLI_CMDS changed to NRF_MPU_LIB_CLI_CMDS
NRF_CRYPTO_BACKEND_CC310_BL_HASH_LITTLE_ENDIAN_DIGEST_ENABLED removed
NRF_CRYPTO_BACKEND_CC310_ENABLED changed to 1
#define NRF_CRYPTO_BACKEND_CC310_BL_ECC_LITTLE_ENDIAN_ENABLED 0 changed to #define NRF_CRYPTO_BACKEND_CC310_BL_INTERRUPTS_ENABLED 1
#define NRF_CRYPTO_BACKEND_MICRO_ECC_PUBLIC_KEY_TRUSTED_ENABLED 0 removed
#define NRF_CRYPTO_BACKEND_MICRO_ECC_LITTLE_ENDIAN_ENABLED 0 removed
#define NRF_CRYPTO_BACKEND_NRF_SW_HASH_LITTLE_ENDIAN_DIGEST_ENABLED 1 removed
COMP_CONFIG_IRQ_PRIORITY changed from 7 to 6
GPIOTE_CONFIG_IRQ_PRIORITY changed from 7 to 6
I2S_CONFIG_IRQ_PRIORITY changed from 7 to 6
LPCOMP_CONFIG_IRQ_PRIORITY changed from 7 to 6
#define NRFX_CLOCK_CONFIG_IRQ_PRIORITY 7 chagned from 7 to 6
NRFX_COMP_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_GPIOTE_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_I2S_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_LPCOMP_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_PDM_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_PWM_DEFAULT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_QDEC_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_QSPI_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_RNG_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_RTC_DEFAULT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_SAADC_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_SPIM_DEFAULT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_SPIS_DEFAULT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_SPI_DEFAULT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_TIMER_ENABLED chagned from 7 to 6
NRFX_TIMER4_ENABLED chagned from 7 to 6
NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_TWIM_DEFAULT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_TWI_DEFAULT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_UARTE_DEFAULT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_UART_DEFAULT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
NRFX_WDT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
POWER_CONFIG_IRQ_PRIORITY chagned from 7 to 6
TIMER_ENABLED from 0 to 1
TIMER4_ENABLED changed from 0 to 1
TWIS_DEFAULT_CONFIG_IRQ_PRIORITY chagned from 7 to 6
USBD_CONFIG_IRQ_PRIORITY chagned from 7 to 6
APP_TIMER_CONFIG_RTC_FREQUENCY changed from 0 to 1
APP_TIMER_CONFIG_IRQ_PRIORITY chagned from 7 to 6
APP_USBD_CDC_ACM_ENABLED removed
APP_USBD_CONFIG_MAX_POWER changed from 500 to 100
APP_USBD_CONFIG_LOG_ENABLED removed
APP_USBD_CONFIG_INFO_COLOR Removed
APP_USBD_CONFIG_DEBUG_COLOR Removed
#define HARDFAULT_HANDLER_GDB_PSP_BACKTRACE 1 changed to #define HARDFAULT_HANDLER_ENABLED 0
MEM_MANAGER_ENABLED changed from 0 to 1
NRF_FPRINTF_ENABLED removed
NRF_SORTLIST_ENABLED changed from 0 to 1
#define BLE_ADV_SOC_OBSERVER_PRIO 1 Removed
Added Items
// <q> PM_LESC_ENABLED  - Enable/disable LESC support in Peer Manager.
// <i> If set to true, you need to call nrf_ble_lesc_request_handler() in the main loop to respond to LESC-related BLE events. If LESC support is not required, set this to false to save code space.
#ifndef PM_LESC_ENABLED
#define PM_LESC_ENABLED 1
// <e> PM_RA_PROTECTION_ENABLED - Enable/disable protection against repeated pairing attempts in Peer Manager.
#ifndef PM_RA_PROTECTION_ENABLED
#define PM_RA_PROTECTION_ENABLED 0
// <o> PM_RA_PROTECTION_TRACKED_PEERS_NUM - Maximum number of peers whose authorization status can be tracked.
#ifndef PM_RA_PROTECTION_TRACKED_PEERS_NUM
#define PM_RA_PROTECTION_TRACKED_PEERS_NUM 8
// <o> PM_RA_PROTECTION_MIN_WAIT_INTERVAL - Minimum waiting interval (in ms) before a new pairing attempt can be initiated.
#ifndef PM_RA_PROTECTION_MIN_WAIT_INTERVAL
#define PM_RA_PROTECTION_MIN_WAIT_INTERVAL 4000
// <o> PM_RA_PROTECTION_MAX_WAIT_INTERVAL - Maximum waiting interval (in ms) before a new pairing attempt can be initiated.
#ifndef PM_RA_PROTECTION_MAX_WAIT_INTERVAL
#define PM_RA_PROTECTION_MAX_WAIT_INTERVAL 64000
// <o> PM_RA_PROTECTION_REWARD_PERIOD - Reward period (in ms).
// <i> The waiting interval is gradually decreased when no new failed pairing attempts are made during reward period.
#ifndef PM_RA_PROTECTION_REWARD_PERIOD
#define PM_RA_PROTECTION_REWARD_PERIOD 10000
// </e>
// <o> PM_HANDLER_SEC_DELAY_MS - Delay before starting security.
// <i>  This might be necessary for interoperability reasons, especially as peripheral.
#ifndef PM_HANDLER_SEC_DELAY_MS
#define PM_HANDLER_SEC_DELAY_MS 0
// <q> NRF_CRYPTO_BACKEND_CC310_ECC_CURVE25519_ENABLED  - Enable the Curve25519 curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_CURVE25519_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_CURVE25519_ENABLED 1
// <q> NRF_CRYPTO_BACKEND_CC310_ECC_ED25519_ENABLED  - Enable the Ed25519 curve support using CC310.
#ifndef NRF_CRYPTO_BACKEND_CC310_ECC_ED25519_ENABLED
#define NRF_CRYPTO_BACKEND_CC310_ECC_ED25519_ENABLED 1
#define NRF_CRYPTO_BACKEND_CC310_INTERRUPTS_ENABLED 1
// <e> NRF_CRYPTO_BACKEND_OPTIGA_ENABLED - Enable the nrf_crypto Optiga Trust X backend.
// <i> Enables the nrf_crypto backend for Optiga Trust X devices.
#ifndef NRF_CRYPTO_BACKEND_OPTIGA_ENABLED
#define NRF_CRYPTO_BACKEND_OPTIGA_ENABLED 0
// <q> NRF_CRYPTO_BACKEND_OPTIGA_RNG_ENABLED  - Optiga backend support for RNG
// <i> The Optiga backend provide external chip RNG.
#ifndef NRF_CRYPTO_BACKEND_OPTIGA_RNG_ENABLED
#define NRF_CRYPTO_BACKEND_OPTIGA_RNG_ENABLED 0
// <q> NRF_CRYPTO_BACKEND_OPTIGA_ECC_SECP256R1_ENABLED  - Optiga backend support for ECC secp256r1
// <i> The Optiga backend provide external chip ECC using secp256r1.
#ifndef NRF_CRYPTO_BACKEND_OPTIGA_ECC_SECP256R1_ENABLED
#define NRF_CRYPTO_BACKEND_OPTIGA_ECC_SECP256R1_ENABLED 1
// </e>
// <q> NRF_CRYPTO_CURVE25519_BIG_ENDIAN_ENABLED  - Big-endian byte order in raw Curve25519 data
// <i> Enable big-endian byte order in Curve25519 API, if set to 1. Use little-endian, if set to 0.
#ifndef NRF_CRYPTO_CURVE25519_BIG_ENDIAN_ENABLED
#define NRF_CRYPTO_CURVE25519_BIG_ENDIAN_ENABLED 0
// </e>
// <h> nrf_crypto_rng - RNG Configuration
// <q> NRF_CRYPTO_RNG_STATIC_MEMORY_BUFFERS_ENABLED  - Use static memory buffers for context and temporary init buffer.
// <i> Always recommended when using the nRF HW RNG as the context and temporary buffers are small. Consider disabling if using the CC310 RNG in a RAM constrained application. In this case, memory must be provided to nrf_crypto_rng_init, or it can be allocated internally provided that NRF_CRYPTO_ALLOCATOR does not allocate memory on the stack.
#ifndef NRF_CRYPTO_RNG_STATIC_MEMORY_BUFFERS_ENABLED
#define NRF_CRYPTO_RNG_STATIC_MEMORY_BUFFERS_ENABLED 1
// <q> NRF_CRYPTO_RNG_AUTO_INIT_ENABLED  - Initialize the RNG module automatically when nrf_crypto is initialized.
// <i> Automatic initialization is only supported with static or internally allocated context and temporary memory.
#ifndef NRF_CRYPTO_RNG_AUTO_INIT_ENABLED
#define NRF_CRYPTO_RNG_AUTO_INIT_ENABLED 1
// </h>
// <e> NRFX_USBD_ENABLED - nrfx_usbd - USBD peripheral driver
#ifndef NRFX_USBD_ENABLED
#define NRFX_USBD_ENABLED 0
// <o> NRFX_USBD_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef NRFX_USBD_CONFIG_IRQ_PRIORITY
#define NRFX_USBD_CONFIG_IRQ_PRIORITY 6
// <o> NRFX_USBD_CONFIG_DMASCHEDULER_MODE  - USBD DMA scheduler working scheme
// <0=> Prioritized access
// <1=> Round Robin
#ifndef NRFX_USBD_CONFIG_DMASCHEDULER_MODE
#define NRFX_USBD_CONFIG_DMASCHEDULER_MODE 0
// <q> NRFX_USBD_CONFIG_DMASCHEDULER_ISO_BOOST  - Give priority to isochronous transfers
// <i> This option gives priority to isochronous transfers.
// <i> Enabling it assures that isochronous transfers are always processed,
// <i> even if multiple other transfers are pending.
// <i> Isochronous endpoints are prioritized before the usbd_dma_scheduler_algorithm
// <i> function is called, so the option is independent of the algorithm chosen.
#ifndef NRFX_USBD_CONFIG_DMASCHEDULER_ISO_BOOST
#define NRFX_USBD_CONFIG_DMASCHEDULER_ISO_BOOST 1
// <q> NRFX_USBD_CONFIG_ISO_IN_ZLP  - Respond to an IN token on ISO IN endpoint with ZLP when no data is ready
// <i> If set, ISO IN endpoint will respond to an IN token with ZLP when no data is ready to be sent.
// <i> Else, there will be no response.
#ifndef NRFX_USBD_CONFIG_ISO_IN_ZLP
#define NRFX_USBD_CONFIG_ISO_IN_ZLP 0
// </e>
// <o> NRFX_WDT_CONFIG_NO_IRQ  - Remove WDT IRQ handling from WDT driver
// <0=> Include WDT IRQ handling
// <1=> Remove WDT IRQ handling
#ifndef NRFX_WDT_CONFIG_NO_IRQ
#define NRFX_WDT_CONFIG_NO_IRQ 0
// <q> USBD_CONFIG_DMASCHEDULER_ISO_BOOST  - Give priority to isochronous transfers
#ifndef USBD_CONFIG_DMASCHEDULER_ISO_BOOST
#define USBD_CONFIG_DMASCHEDULER_ISO_BOOST 1
// <q> USBD_CONFIG_ISO_IN_ZLP  - Respond to an IN token on ISO IN endpoint with ZLP when no data is ready
// <i> NOTE: This option does not work on Engineering A chip.
#ifndef USBD_CONFIG_ISO_IN_ZLP
#define USBD_CONFIG_ISO_IN_ZLP 0
// <o> APP_TIMER_SAFE_WINDOW_MS - Maximum possible latency (in milliseconds) of handling app_timer event.
// <i> Maximum possible timeout that can be set is reduced by safe window.
// <i> Example: RTC frequency 16384 Hz, maximum possible timeout 1024 seconds - APP_TIMER_SAFE_WINDOW_MS.
// <i> Since RTC is not stopped when processor is halted in debugging session, this value
// <i> must cover it if debugging is needed. It is possible to halt processor for APP_TIMER_SAFE_WINDOW_MS
// <i> without corrupting app_timer behavior.
#ifndef APP_TIMER_SAFE_WINDOW_MS
#define APP_TIMER_SAFE_WINDOW_MS 300000
// <o> APP_USBD_DEVICE_VER_SUB - Sub-minor device version  <0-9>
// <i> Sub-minor device version, will be converted automatically to BCD notation. Use just decimal values.
#ifndef APP_USBD_DEVICE_VER_SUB
#define APP_USBD_DEVICE_VER_SUB 0
// <q> APP_USBD_CONFIG_SELF_POWERED  - Self-powered device, as opposed to bus-powered.
#ifndef APP_USBD_CONFIG_SELF_POWERED
#define APP_USBD_CONFIG_SELF_POWERED 1
// <o> APP_USBD_CONFIG_MAX_POWER - MaxPower field in configuration descriptor in milliamps.  <0-500>
#ifndef APP_USBD_CONFIG_MAX_POWER
#define APP_USBD_CONFIG_MAX_POWER 100
// <q> APP_USBD_CONFIG_POWER_EVENTS_PROCESS  - Process power events.
// <i> Enable processing power events in USB event handler.
#ifndef APP_USBD_CONFIG_POWER_EVENTS_PROCESS
#define APP_USBD_CONFIG_POWER_EVENTS_PROCESS 1
// <e> APP_USBD_CONFIG_EVENT_QUEUE_ENABLE - Enable event queue.
// <i> This is the default configuration when all the events are placed into internal queue.
// <i> Disable it when an external queue is used like app_scheduler or if you wish to process all events inside interrupts.
// <i> Processing all events from the interrupt level adds requirement not to call any functions that modifies the USBD library state from the context higher than USB interrupt context.
// <i> Functions that modify USBD state are functions for sleep, wakeup, start, stop, enable, and disable.
#ifndef APP_USBD_CONFIG_EVENT_QUEUE_ENABLE
#define APP_USBD_CONFIG_EVENT_QUEUE_ENABLE 1
// <o> APP_USBD_CONFIG_EVENT_QUEUE_SIZE - The size of the event queue.  <16-64>
// <i> The size of the queue for the events that would be processed in the main loop.
#ifndef APP_USBD_CONFIG_EVENT_QUEUE_SIZE
#define APP_USBD_CONFIG_EVENT_QUEUE_SIZE 32
// <o> APP_USBD_CONFIG_SOF_HANDLING_MODE  - Change SOF events handling mode.
// <i> Normal queue   - SOF events are pushed normally into the event queue.
// <i> Compress queue - SOF events are counted and binded with other events or executed when the queue is empty.
// <i>                  This prevents the queue from filling up with SOF events.
// <i> Interrupt      - SOF events are processed in interrupt.
// <0=> Normal queue
// <1=> Compress queue
// <2=> Interrupt
#ifndef APP_USBD_CONFIG_SOF_HANDLING_MODE
#define APP_USBD_CONFIG_SOF_HANDLING_MODE 1
// </e>
// <q> APP_USBD_CONFIG_SOF_TIMESTAMP_PROVIDE  - Provide a function that generates timestamps for logs based on the current SOF.
// <i> The function app_usbd_sof_timestamp_get is implemented if the logger is enabled.
// <i> Use it when initializing the logger.
// <i> SOF processing is always enabled when this configuration parameter is active.
// <i> Note: This option is configured outside of APP_USBD_CONFIG_LOG_ENABLED.
// <i> This means that it works even if the logging in this very module is disabled.
#ifndef APP_USBD_CONFIG_SOF_TIMESTAMP_PROVIDE
#define APP_USBD_CONFIG_SOF_TIMESTAMP_PROVIDE 0
// <o> APP_USBD_CONFIG_DESC_STRING_SIZE - Maximum size of the NULL-terminated string of the string descriptor.  <31-254>
// <i> 31 characters can be stored in the internal USB buffer used for transfers.
// <i> Any value higher than 31 creates an additional buffer just for descriptor strings.
#ifndef APP_USBD_CONFIG_DESC_STRING_SIZE
#define APP_USBD_CONFIG_DESC_STRING_SIZE 31
// <q> APP_USBD_CONFIG_DESC_STRING_UTF_ENABLED  - Enable UTF8 conversion.
// <i> Enable UTF8-encoded characters. In normal processing, only ASCII characters are available.
#ifndef APP_USBD_CONFIG_DESC_STRING_UTF_ENABLED
#define APP_USBD_CONFIG_DESC_STRING_UTF_ENABLED 0
// <s> APP_USBD_STRINGS_LANGIDS - Supported languages identifiers.
// <i> Note: This value is not editable in Configuration Wizard.
// <i> Comma-separated list of supported languages.
#ifndef APP_USBD_STRINGS_LANGIDS
#define APP_USBD_STRINGS_LANGIDS APP_USBD_LANG_AND_SUBLANG(APP_USBD_LANG_ENGLISH, APP_USBD_SUBLANG_ENGLISH_US)
// <e> APP_USBD_STRING_ID_MANUFACTURER - Define manufacturer string ID.
// <i> Setting ID to 0 disables the string.
#ifndef APP_USBD_STRING_ID_MANUFACTURER
#define APP_USBD_STRING_ID_MANUFACTURER 1
// <q> APP_USBD_STRINGS_MANUFACTURER_EXTERN  - Define whether @ref APP_USBD_STRINGS_MANUFACTURER is created by macro or declared as a global variable.
#ifndef APP_USBD_STRINGS_MANUFACTURER_EXTERN
#define APP_USBD_STRINGS_MANUFACTURER_EXTERN 0
// <s> APP_USBD_STRINGS_MANUFACTURER - String descriptor for the manufacturer name.
// <i> Comma-separated list of manufacturer names for each defined language.
// <i> Use @ref APP_USBD_STRING_DESC macro to create string descriptor from a NULL-terminated string.
// <i> Use @ref APP_USBD_STRING_RAW8_DESC macro to create string descriptor from comma-separated uint8_t values.
// <i> Use @ref APP_USBD_STRING_RAW16_DESC macro to create string descriptor from comma-separated uint16_t values.
// <i> Alternatively, configure the macro to point to any internal variable pointer that already contains the descriptor.
// <i> Setting string to NULL disables that string.
// <i> The order of manufacturer names must be the same like in @ref APP_USBD_STRINGS_LANGIDS.
#define APP_USBD_STRINGS_MANUFACTURER APP_USBD_STRING_DESC("Nordic Semiconductor")
// </e>
// <e> APP_USBD_STRING_ID_PRODUCT - Define product string ID.
#ifndef APP_USBD_STRING_ID_PRODUCT
#define APP_USBD_STRING_ID_PRODUCT 2
// <q> APP_USBD_STRINGS_PRODUCT_EXTERN  - Define whether @ref APP_USBD_STRINGS_PRODUCT is created by macro or declared as a global variable.
#ifndef APP_USBD_STRINGS_PRODUCT_EXTERN
#define APP_USBD_STRINGS_PRODUCT_EXTERN 0
// <s> APP_USBD_STRINGS_PRODUCT - String descriptor for the product name.
// <i> List of product names that is defined the same way like in @ref APP_USBD_STRINGS_MANUFACTURER.
#define APP_USBD_STRINGS_PRODUCT APP_USBD_STRING_DESC("nRF52 USB Product")
// </e>
// <e> APP_USBD_STRING_ID_SERIAL - Define serial number string ID.
#ifndef APP_USBD_STRING_ID_SERIAL
#define APP_USBD_STRING_ID_SERIAL 3
// <q> APP_USBD_STRING_SERIAL_EXTERN  - Define whether @ref APP_USBD_STRING_SERIAL is created by macro or declared as a global variable.
#ifndef APP_USBD_STRING_SERIAL_EXTERN
#define APP_USBD_STRING_SERIAL_EXTERN 0
// <s> APP_USBD_STRING_SERIAL - String descriptor for the serial number.
// <i> Serial number that is defined the same way like in @ref APP_USBD_STRINGS_MANUFACTURER.
#define APP_USBD_STRING_SERIAL APP_USBD_STRING_DESC("000000000000")
// </e>
// <e> APP_USBD_STRING_ID_CONFIGURATION - Define configuration string ID.
#ifndef APP_USBD_STRING_ID_CONFIGURATION
#define APP_USBD_STRING_ID_CONFIGURATION 4
// <q> APP_USBD_STRING_CONFIGURATION_EXTERN  - Define whether @ref APP_USBD_STRINGS_CONFIGURATION is created by macro or declared as global variable.
#ifndef APP_USBD_STRING_CONFIGURATION_EXTERN
#define APP_USBD_STRING_CONFIGURATION_EXTERN 0
// <s> APP_USBD_STRINGS_CONFIGURATION - String descriptor for the device configuration.
// <i> Configuration string that is defined the same way like in @ref APP_USBD_STRINGS_MANUFACTURER.
#ifndef APP_USBD_STRINGS_CONFIGURATION
#define APP_USBD_STRINGS_CONFIGURATION APP_USBD_STRING_DESC("Default configuration")
// </e>
// <s> APP_USBD_STRINGS_USER - Default values for user strings.
// <i> This value stores all application specific user strings with the default initialization.
// <i> The setup is done by X-macros.
// <i> Expected macro parameters:
// <i> @code
// <i> X(mnemonic, [=str_idx], ...)
// <i> @endcode
// <i> - @c mnemonic: Mnemonic of the string descriptor that would be added to
// <i>                @ref app_usbd_string_desc_idx_t enumerator.
// <i> - @c str_idx : String index value, can be set or left empty.
// <i>                For example, WinUSB driver requires descriptor to be present on 0xEE index.
// <i>                Then use X(USBD_STRING_WINUSB, =0xEE, (APP_USBD_STRING_DESC(...)))
// <i> - @c ...     : List of string descriptors for each defined language.
#ifndef APP_USBD_STRINGS_USER
#define APP_USBD_STRINGS_USER X(APP_USER_1, , APP_USBD_STRING_DESC("User 1"))
// </e>
// <e> APP_USBD_HID_ENABLED - app_usbd_hid - USB HID class
#ifndef APP_USBD_HID_ENABLED
#define APP_USBD_HID_ENABLED 0
// <o> APP_USBD_HID_DEFAULT_IDLE_RATE - Default idle rate for HID class.   <0-255>
// <i> 0 means indefinite duration, any other value is multiplied by 4 milliseconds. Refer to Chapter 7.2.4 of HID 1.11 Specification.
#ifndef APP_USBD_HID_DEFAULT_IDLE_RATE
#define APP_USBD_HID_DEFAULT_IDLE_RATE 0
// <o> APP_USBD_HID_REPORT_IDLE_TABLE_SIZE - Size of idle rate table.   <1-255>
// <i> Must be higher than the highest report ID used.
#ifndef APP_USBD_HID_REPORT_IDLE_TABLE_SIZE
#define APP_USBD_HID_REPORT_IDLE_TABLE_SIZE 4
// </e>
// <q> APP_USBD_CDC_ACM_ENABLED  - Enabling USBD CDC ACM Class library
#ifndef APP_USBD_CDC_ACM_ENABLED
#define APP_USBD_CDC_ACM_ENABLED 0
// <q> APP_USBD_CDC_ACM_ZLP_ON_EPSIZE_WRITE  - Send ZLP on write with same size as endpoint
// <i> If enabled, CDC ACM class will automatically send a zero length packet after transfer which has the same size as endpoint.
// <i> This may limit throughput if a lot of binary data is sent, but in terminal mode operation it makes sure that the data is always displayed right after it is sent.
#ifndef APP_USBD_CDC_ACM_ZLP_ON_EPSIZE_WRITE
#define APP_USBD_CDC_ACM_ZLP_ON_EPSIZE_WRITE 1
// </h>
// <q> NRF_CLI_METAKEYS_ENABLED  - Enable additional control keys for CLI commands like ctrl+a, ctrl+e, ctrl+w, ctrl+u
#ifndef NRF_CLI_METAKEYS_ENABLED
#define NRF_CLI_METAKEYS_ENABLED 0
// <h> nrf_fprintf - fprintf function.
// <q> NRF_FPRINTF_ENABLED  - Enable/disable fprintf module.
#ifndef NRF_FPRINTF_ENABLED
#define NRF_FPRINTF_ENABLED 1
// <q> NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED  - For each printed LF, function will add CR.
#ifndef NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED
#define NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 1
// <q> NRF_FPRINTF_DOUBLE_ENABLED  - Enable IEEE-754 double precision formatting.
#ifndef NRF_FPRINTF_DOUBLE_ENABLED
#define NRF_FPRINTF_DOUBLE_ENABLED 0
// </h>
