Not able to read IKEA Trådfri bulb with nRF ZigBee
Hi
I read some threads about how to pair/read IKEA Trådfri.
I'm using nRF5840 dongle with the HEX code cli from SDK 17.0.0.
Using the terminal and send
bdb role zc
bdb start
bdb legacy enable
putting the bulb in "flickering mode, factory reset"
zdo match_desc 0xfff 0xffff 0xc05e 1 0 0
No result, the bulb is very very close to the dongle.
I feel stupid, because nothing happens.
What's wrong?
    The IKEA Trådfri uses the Home Automation (0x0104) profile, and not Zigbee Light Link. Could you try to use 0x0104 instead of 0xc05e with the zdo match_desc command and see if that solves your problem?
    If you're still having problems, could you please capture a sniffer log? You can see how to do this here.
    Marte
    If you want to get a better context on what's going on in the network, but do not have a Zigbee sniffer around/other DK, you may enable logging in the CLI example through the following command:
    log enable info
    Now you should be able to see the log message, indicating that the bulb has joined the CLI's network.
    Afterwards, there is a set of commands to query/discover the device's capabilities:
    • zdo match_desc
    • zdo simple_desc_req
    • zdo active_ep
    If you do not see the successful association inside logs, there is no other way around - you will need a sniffer and paste the traffic dump here.
    If everything works, but the device does not respond to the match descriptor request (both profile IDs), try using a different broadcast address (0xFFFD). I've seen devices, that did not respond to the 0xFFFF (all devices), but replied to the 0xFFFD (routers-only).
    Side note: in the default configuration every reset of the CLI example erases the network data. As a result, you have to modify the example by changing the ERASE_PERSISTENT_CONFIG setting or factory reset all devices with every CLI reboot.
    Tomchy
