For a Bluetooth Mesh device, or 'provisioned node', does provisioning happen more than once for a established network? Will this device ever need to be re-provisioned once it leaves the factory?
A Bluetooth Mesh device should, in theory, only need to be provisioned once. There are some cases you need to reprovision the device(from the spec):
- If the number and structure of elements changes, for example due to a firmware update, the node must be reprovisioned.
- A node that is away from a network for longer than 48 weeks must be reprovisioned.
Interesting, thank you! We are addressing mesh integration for a distributed utilities service in remote locations, your 48 weeks notice is appreciated
If the elements change, will the device still remain on the network? If the device has elements "A" & "B" with an update to "A", will "B" still work before reprovisioning?
let us know of the "A"/"B" question, when available
