Unable to adverstise scanned data again using ble_app_hrs_rscs_relay example.
I am using nrf5832 sdk 14.2 where I am trying to scan the data and advertise same data with some modifications. I have used Central and Peripheral example ble_app_hrs_rscs_relay. Here I am able to scan the data from other advertising device and collecting it into a buffer but unable to advertise the buffer again. I have tried updating manufacturing specific data as well scanned-response data but fail to do so. Although My device is advertising as a beacon without buffer data.
TIA
    Can you post the code you used to update the advertising data?
    Are you getting any error codes when trying to update the advertising data?
    Jørgen
  • Hi Jorgen, I am using the following api for advertising and in my case advertising is also happening but the data is not visible when I tried in NRF Connect App just like when we flash the beacon example code. Beside that I am not getting any error.
    ret_code_t err_code;
    ble_advertising_init_t init;
    init.advdata.name_type = BLE_ADVDATA_NO_NAME;
    init.advdata.include_appearance = true;
    init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids = m_adv_uuids;
    init.advdata.p_manuf_specific_data->data.p_data = (uint8_t *) m_beacon_info;
    init.advdata.p_manuf_specific_data->data.size = APP_BEACON_INFO_LENGTH;
    // init.srdata.p_service_data_array->data.p_data = Data_str;
    // init.srdata.p_service_data_array->data.size = sizeof(Data_str)/sizeof(uint8_t);
    init.config.ble_adv_fast_enabled = true;
    init.config.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS;
  • Do you call advertising_init each time you update the buffer? The advertising data is copied into an internal buffer. Simply updating your data in m_beacon_info will not affect the data being advertised until you call the correct functions to update the data.
  • To update the buffer I have different functions which I am calling.
    Here in the above snippet only static data using m_beacon_info I am trying to advertise by calling advertising_init   every 50ms in main() after scan.
  • Could you maybe post the full project? That would make it easier to get the full overview of what you are doing to update the data, and also to reproduce/debug the issue. If you do not want to post the project in public, I can convert the case to private.
