Bootloader and SoftDevice update using Thread Secure DFU
nRF5 SDK for Thread and Zigbee v4.1.0 documentation states that only application can be updated over Thread Secure DFU.
However, nRF5 SDK for Thread and Zigbee v2.0.0 documentation says:
"Thread Secure DFU accepts images that contain a new bootloader or application, which contains the Thread network stack":
Does something changed in SDK 4.1 which is causing that bootloader can no longer be updated?
Is there any way to update bootloader and SoftDevice using Thread Secure DFU?
    I'm checking with our Thread team what your options are and what is supported in the SDK. I will get back to you as soon as I receive their response.
    Jørgen
    Sorry for the slow response to this. I checked with our developers and they did not see any reasons that bootloader updates should not be possible over the Thread network.
    I verified this by doing a bootloader update and check that the updates are received. I followed the instructions on this page, however in step 5, I did the following changes:
    • Add the line "LEDS_ON(BSP_LED_3_MASK);" after "leds_init();" in main() function of Thread Secure Bootloader project.
    • Modify sdk_config.h file of Thread Secure Bootloader project to set "#define NRF_BL_DFU_ENTER_METHOD_BUTTON 1".
    • Generate DFU packet using following command:
      nrfutil pkg generate --hw-version 52 --sd-req 0x00 --bootloader-version 2 --bootloader bootloader\pca10056\blank\armgcc\_build\nrf52840_xxaa.hex --key-file priv.pem bl_dfu_package.zip
    When the DFU is completed in step 7, hold Button 4 of the board while power cycling it. This will enter the bootloader, and you should observe that LED4 is lit up.
    I will create an internal ticket for getting the documentation revised to avoid confusion.
    Jørgen
    Thank you for your answer.
    I've performed the upgrade test but unfortunately it failed...
    Scenario:
    1. Flash bootloader and application
    2. Perform bootloader DFU
    3. Perform application DFU
    Above scenario works fine but only when all software components comes from the same SDK version, i.e. all from SDK 2.0 or all from SDK 4.1.
    However it does not work when upgrading from SDK 2.0 to SDK 4.1 like in below scenario:
    1. Flash bootloader and application based on SDK 2.0
    2. Perform bootloader DFU based on SDK 4.1
    3. Perform application DFU based on SDK 4.1
    In step 2. bootloader has been flashed and started successfully - which was indicated by LED3 being lit up, when bootloader started.
    In step 3. the application has been downloaded and reset after DFU was performed, however the application was not activated by bootloader for some reason, and old application was started (the new application should lit up LED2, but it was not there is in this case).
    Below you can see all instructions which you can just copy-paste it in order to reproduce this issue.
    1. Download SDK 2.0 and 4.1 a extract them in corresponding folders (e.g. sdk-2.0 and sdk-4.1).
    2. Go to SDK 2.0 DFU folder
      cd <your-path>/sdk-2.0
      cd examples/thread/dfu
    3. Create cryptographic keys
      nrfutil keys generate priv.pem
      nrfutil keys display --key pk --format code priv.pem --out_file dfu_public_key.c
      cp dfu_public_key.c ../../dfu/
    4. Install micro-ecc
      pushd ../../../external/micro-ecc
      git clone https://github.com/kmackay/micro-ecc
      pushd nrf52hf_armgcc/armgcc
      make
      popd
      popd
    5. Build bootloader
      make -C bootloader/pca10056/blank/armgcc
    6. Prepare the DFU Client
      sed -i.backup 's/#define BACKGROUND_DFU_CONFIG_LOG_LEVEL 3/#define BACKGROUND_DFU_CONFIG_LOG_LEVEL 4/g' client/pca10056/blank/config/sdk_config.h
      make -C client/pca10056/blank/armgcc
      nrfutil settings generate --family NRF52840 --application client/pca10056/blank/armgcc/_build/nrf52840_xxaa.hex --application-version 1 --bootloader-version 1 --bl-settings-version 1 settings.hex
      mergehex -m client/pca10056/blank/armgcc/_build/nrf52840_xxaa.hex settings.hex -o dfu_client.hex
    7. Flash
      nrfjprog -f nrf52 --eraseall
      nrfjprog -f nrf52 -r --program ../../../components/softdevice/mbr/nrf52840/hex/mbr_nrf52_2.3.0_mbr.hex --chiperase
      nrfjprog -f nrf52 -r --program bootloader/pca10056/blank/armgcc/_build/nrf52840_xxaa_mbr.hex --sectoranduicrerase
      nrfjprog -f nrf52 -r --program dfu_client.hex --sectorerase
    8. Go to SDK 4.1 DFU folder
      cd <your-path>/sdk-4.1
    9. Copy cryptographic keys created in SDK 2.0
      cp ../../../../sdk-2.0/examples/thread/dfu/dfu_public_key.c ../../dfu/
      cp ../../../../sdk-2.0/examples/thread/dfu/priv.pem .
    10. Install micro-ecc
      make
      popd
      popd
    11. Prepare app firmware package
      sed -i.backup 's/thread_bsp_init();/thread_bsp_init(); LEDS_ON(BSP_LED_1_MASK);/g' client/main.c
      nrfutil pkg generate --hw-version 52 --sd-req 0x00 --application-version 2 --application client/pca10056/blank/armgcc/_build/nrf52840_xxaa.hex --key-file priv.pem app_dfu_package.zip
    12. Prepare bootloader firmware package
      sed -i.backup 's/leds_init();/leds_init(); LEDS_ON(BSP_LED_3_MASK);/g' bootloader/main.c
      sed -i.backup 's/#define NRF_BL_DFU_ENTER_METHOD_BUTTON 0/#define NRF_BL_DFU_ENTER_METHOD_BUTTON 1/g' bootloader/pca10056/blank/config/sdk_config.h
      nrfutil pkg generate --hw-version 52 --sd-req 0x00 --bootloader-version 2 --bootloader bootloader/pca10056/blank/armgcc/_build/nrf52840_xxaa_mbr.hex --key-file priv.pem bl_dfu_package.zip
    13. Perform bootloader DFU
    14. Perform application DFU
    I can send you logs from the whole process if you want.
    Could you please check if this scenario is working for you? This is important for us, since it blocks us from upgrading to SDK 4.1.
    Could you also tell if it's possible to downgrade bootloader and application from SDK 4.1 to SDK 2.0?
    Krzysztof
    I tested following your instructions, but I'm not able to update the bootloader/firmware correctly.
    Will test more tomorrow with more debugging enabled, and will also compare the flash content to see what happens.
    Jørgen
    Thank you for looking into this.
    Please just let me know if you need some assistance with above setup.
    Krzysztof
