Bootloader and SoftDevice update using Thread Secure DFU
nRF5 SDK for Thread and Zigbee v4.1.0 documentation states that only application can be updated over Thread Secure DFU.
However, nRF5 SDK for Thread and Zigbee v2.0.0 documentation says:
"Thread Secure DFU accepts images that contain a new bootloader or application, which contains the Thread network stack":
Does something changed in SDK 4.1 which is causing that bootloader can no longer be updated?
Is there any way to update bootloader and SoftDevice using Thread Secure DFU?
    Unfortunately we have not been able to create a working application for the middle update before Christmas vacation. Our developers will continue to look into this after the holidays, and we hope to get this done soon.
    Jørgen
    We have now been successful in creating an application that allows you to update from SDK 2.0.0 to SDK 4.1.0.
    Starting out with the Thread DFU client example in SDK 2.0.0, replace the following two files:
       * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
       * All rights reserved.
      #include "nrf_dfu_settings.h"
      #include <stddef.h>
      #include <string.h>
      #include "nrf_dfu_flash.h"
      #include "nrf_soc.h"
      #include "crc32.h"
      #include "nrf_nvmc.h"
      #include "sdk_config.h"
      #define DFU_SETTINGS_INIT_COMMAND_OFFSET        offsetof(nrf_dfu_settings_t, init_command)          //<! Offset in the settings struct where the InitCommand is located.
      #define NRF_LOG_MODULE_NAME nrf_dfu_settings
      #include "nrf_log.h"
      NRF_LOG_MODULE_REGISTER();
      /**@brief   This variable reserves a page in flash for bootloader settings
       *          to ensure the linker doesn't place any code or variables at this location.
      #if defined (__CC_ARM )
          uint8_t m_dfu_settings_buffer[BOOTLOADER_SETTINGS_PAGE_SIZE]
              __attribute__((at(BOOTLOADER_SETTINGS_ADDRESS)))
              __attribute__((used));
      #elif defined ( __GNUC__ ) || defined ( __SES_ARM )
              __attribute__((section(".bootloader_settings_page")))
      #elif defined ( __ICCARM__ )
          __no_init __root uint8_t m_dfu_settings_buffer[BOOTLOADER_SETTINGS_PAGE_SIZE]
              @ BOOTLOADER_SETTINGS_ADDRESS;
      #else
          #error Not a valid compiler/linker for m_dfu_settings placement.
      #endif // Compiler specific
      #if defined(NRF52_SERIES)
      /**@brief   This variable reserves a page in flash for MBR parameters
      #if defined ( __CC_ARM )
          uint8_t m_mbr_params_page[NRF_MBR_PARAMS_PAGE_SIZE]
              __attribute__((at(NRF_MBR_PARAMS_PAGE_ADDRESS)))
              __attribute__((section(".mbr_params_page")))
          __no_init uint8_t m_mbr_params_page[NRF_MBR_PARAMS_PAGE_SIZE]
              @ NRF_MBR_PARAMS_PAGE_ADDRESS;
      #else
          #error Not a valid compiler/linker for m_mbr_params_page placement.
      uint8_t * mp_dfu_settings_backup_buffer = &m_mbr_params_page[0];
      #ifndef NRF_DFU_SETTINGS_IN_APP
      #define NRF_DFU_SETTINGS_IN_APP 0
      #if !defined(BL_SETTINGS_ACCESS_ONLY) && !NRF_DFU_SETTINGS_IN_APP
      /**@brief   This variable has the linker write the MBR parameters page address to the
       *          UICR register. This value will be written in the HEX file and thus to the
       *          UICR when the bootloader is flashed into the chip.
          uint32_t const m_uicr_mbr_params_page_address
              __attribute__((at(NRF_UICR_MBR_PARAMS_PAGE_ADDRESS))) = NRF_MBR_PARAMS_PAGE_ADDRESS;
              __attribute__ ((section(".uicr_mbr_params_page")))
              __attribute__ ((used)) = NRF_MBR_PARAMS_PAGE_ADDRESS;
          __root uint32_t const m_uicr_mbr_params_page_address
              @ NRF_UICR_MBR_PARAMS_PAGE_ADDRESS = NRF_MBR_PARAMS_PAGE_ADDRESS;
      #else
      #endif // #ifndef BL_SETTINGS_ACCESS_ONLY
      #endif // #if defined( NRF52_SERIES )
      nrf_dfu_settings_t s_dfu_settings;
      static uint32_t settings_crc_get(nrf_dfu_settings_t const * p_settings)
          ASSERT(offsetof(nrf_dfu_settings_t, crc) == 0);
          // The crc is calculated from the s_dfu_settings struct, except the crc itself and the init command
          return crc32_compute((uint8_t*)(p_settings) + 4, DFU_SETTINGS_INIT_COMMAND_OFFSET  - 4, NULL);
      static bool crc_ok(nrf_dfu_settings_t const * p_settings)
          if (p_settings->crc != 0xFFFFFFFF)
              // CRC is set. Content must be valid
              uint32_t crc = settings_crc_get(p_settings);
              if (crc == p_settings->crc)
                  return true;
          return false;
      static bool settings_crc_ok(void)
          nrf_dfu_settings_t const * p_settings = (nrf_dfu_settings_t const *)m_dfu_settings_buffer;
          return crc_ok(p_settings);
      static bool settings_backup_crc_ok(void)
          nrf_dfu_settings_t const * p_settings = (nrf_dfu_settings_t const *)mp_dfu_settings_backup_buffer;
      static bool settings_region_compare_to_backup(uint32_t  start_offset,
                                                    uint32_t  end_offset,
                                                    uint8_t * p_compare_addr)
          ASSERT(end_offset >= start_offset);
          return (0 == memcmp((uint8_t const *)(mp_dfu_settings_backup_buffer + start_offset),
                              (uint8_t const *)(p_compare_addr + start_offset),
                               end_offset - start_offset));
      static bool settings_forbidden_parts_equal_to_backup(uint8_t * p_compare_addr)
      #if NRF_DFU_SETTINGS_ALLOW_UPDATE_FROM_APP || NRF_DFU_SETTINGS_IN_APP
          return (settings_region_compare_to_backup(4, offsetof(nrf_dfu_settings_t, app_version), p_compare_addr))
             &&  (settings_region_compare_to_backup(offsetof(nrf_dfu_settings_t, bank_layout), offsetof(nrf_dfu_settings_t, bank_1), p_compare_addr));
      #else
          bool forbidden_region_1_equal = settings_region_compare_to_backup(
                  4,
                  offsetof(nrf_dfu_settings_t, enter_buttonless_dfu),
                  p_compare_addr);
          bool forbidden_region_2_equal = settings_region_compare_to_backup(
                  offsetof(nrf_dfu_settings_t, enter_buttonless_dfu) + 4,
                  offsetof(nrf_dfu_settings_t, init_command) + INIT_COMMAND_MAX_SIZE,
                  p_compare_addr);
          return (forbidden_region_1_equal && forbidden_region_2_equal);
      ret_code_t nrf_dfu_settings_init(bool sd_irq_initialized)
          NRF_LOG_DEBUG("Calling nrf_dfu_settings_init()...");
          ret_code_t err_code = nrf_dfu_flash_init(sd_irq_initialized);
          if (err_code != NRF_SUCCESS)
              NRF_LOG_ERROR("nrf_dfu_flash_init() failed with error: %x", err_code);
              return NRF_ERROR_INTERNAL;
          bool settings_valid        = settings_crc_ok();
          bool settings_backup_valid = settings_backup_crc_ok();
          if (settings_valid &&
              settings_backup_valid &&
              !settings_forbidden_parts_equal_to_backup(m_dfu_settings_buffer))
              NRF_LOG_WARNING("Restoring settings from backup since the off-limit parts "
                              "of the settings page have been tampered with.");
              memcpy(&s_dfu_settings,
                     mp_dfu_settings_backup_buffer,
                     sizeof(nrf_dfu_settings_t));
          else if (!settings_valid)
              if (settings_backup_valid)
                  NRF_LOG_INFO("Restoring settings from backup since the settings page contents are "
                               "invalid (CRC error).");
                  NRF_LOG_WARNING("Resetting bootloader settings since neither the settings page nor the "
                                  "backup are valid (CRC error).");
                  memset(&s_dfu_settings, 0x00, sizeof(nrf_dfu_settings_t));
                  s_dfu_settings.settings_version = NRF_DFU_SETTINGS_VERSION;
              NRF_LOG_DEBUG("Settings OK");
              memcpy(&s_dfu_settings, m_dfu_settings_buffer, sizeof(nrf_dfu_settings_t));
          err_code = nrf_dfu_settings_write_and_backup(NULL);
              NRF_LOG_ERROR("nrf_dfu_settings_write_and_backup() failed with error: %x", err_code);
          return NRF_SUCCESS;
      static ret_code_t settings_write(void                   * p_dst,
                                       void const             * p_src,
                                       nrf_dfu_flash_callback_t callback,
                                       nrf_dfu_settings_t     * p_dfu_settings_buffer)
          ret_code_t err_code;
          if (memcmp(p_dst, p_src, sizeof(nrf_dfu_settings_t)) == 0)
              NRF_LOG_DEBUG("Destination settings are identical to source, write not needed. Skipping.");
              if (callback != NULL)
                  callback(NULL);
              return NRF_SUCCESS;
          if (NRF_DFU_SETTINGS_IN_APP && !settings_forbidden_parts_equal_to_backup((uint8_t *)&s_dfu_settings) && s_dfu_settings.settings_version !=2)
              NRF_LOG_WARNING("Settings write aborted since it tries writing to forbidden settings.");
              // Assuming NRF_DFU_SETTINGS_ALLOW_UPDATE_FROM_APP is configured the same as in bootloader.
              return NRF_ERROR_FORBIDDEN;
          NRF_LOG_DEBUG("Writing settings...");
          NRF_LOG_DEBUG("Erasing old settings at: 0x%08x", p_dst);
          // Not setting the callback function because ERASE is required before STORE
          // Only report completion on successful STORE.
          err_code = nrf_dfu_flash_erase((uint32_t)p_dst, 1, NULL);
              NRF_LOG_ERROR("Could not erase the settings page!");
          ASSERT(p_dfu_settings_buffer != NULL);
          memcpy(p_dfu_settings_buffer, p_src, sizeof(nrf_dfu_settings_t));
          err_code = nrf_dfu_flash_store((uint32_t)p_dst,
                                         sizeof(nrf_dfu_settings_t),
                                         callback);
              NRF_LOG_ERROR("Could not write the DFU settings page!");
          return NRF_SUCCESS;
      ret_code_t nrf_dfu_settings_write(nrf_dfu_flash_callback_t callback)
          static nrf_dfu_settings_t dfu_settings_buffer;
          s_dfu_settings.crc = settings_crc_get(&s_dfu_settings);
          return settings_write(m_dfu_settings_buffer,
                                &s_dfu_settings,
                                callback,
                                &dfu_settings_buffer);
      void settings_backup(nrf_dfu_flash_callback_t callback, void * p_src)
      #if NRF_DFU_SETTINGS_IN_APP
          NRF_LOG_INFO("Settings backup not available from app.");
      #else
          NRF_LOG_INFO("Backing up settings page to address 0x%x.", mp_dfu_settings_backup_buffer);
          ASSERT(settings_crc_ok());
          ret_code_t err_code = settings_write(mp_dfu_settings_backup_buffer,
                                               p_src,
                                               callback,
              NRF_LOG_ERROR("Could not perform backup of bootloader settings! Error: 0x%x", err_code);
      void nrf_dfu_settings_backup(nrf_dfu_flash_callback_t callback)
          settings_backup(callback, m_dfu_settings_buffer);
      ret_code_t nrf_dfu_settings_write_and_backup(nrf_dfu_flash_callback_t callback)
          ret_code_t err_code = nrf_dfu_settings_write(callback);
      #else
          ret_code_t err_code = nrf_dfu_settings_write(NULL);
          if (err_code == NRF_SUCCESS)
              settings_backup(callback, &s_dfu_settings);
          return err_code;
      __WEAK ret_code_t nrf_dfu_settings_additional_erase(void)
          NRF_LOG_WARNING("No additional data erased");
          return NRF_SUCCESS;
       * Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
      #include <stdbool.h>
      #include "nrf_dfu_types.h"
      #include "nrf_dfu_utils.h"
      #include "nrf_bootloader_info.h"
      #include "pb.h"
      #include "pb_common.h"
      #include "pb_decode.h"
      #include "dfu-cc.pb.h"
      #include "crc32.h"
      #include "nrf_crypto.h"
      #include "nrf_crypto_shared.h"
      #include "nrf_assert.h"
      #include "nrf_dfu_validation.h"
      #include "nrf_dfu_ver_validation.h"
      #define NRF_LOG_MODULE_NAME nrf_dfu_validation
      #include "nrf_log_ctrl.h"
      #ifndef DFU_REQUIRES_SOFTDEVICE
      #ifndef BLE_STACK_SUPPORT_REQD
      #define DFU_REQUIRES_SOFTDEVICE 0
      #else
      #define DFU_REQUIRES_SOFTDEVICE 1
      #define EXT_ERR(err) (nrf_dfu_result_t)((uint32_t)NRF_DFU_RES_CODE_EXT_ERROR + (uint32_t)err)
      /* Whether a complete init command has been received and prevalidated, but the firmware
       * is not yet fully transferred. This value will also be correct after reset.
      static bool               m_valid_init_cmd_present = false;
      static dfu_packet_t       m_packet                 = DFU_PACKET_INIT_DEFAULT;
      static uint8_t*           m_init_packet_data_ptr   = 0;
      static uint32_t           m_init_packet_data_len   = 0;
      static pb_istream_t       m_pb_stream;
      static nrf_crypto_ecdsa_verify_context_t        m_verify_context = {0};
      static nrf_crypto_hash_context_t                m_hash_context = {0};
      __ALIGN(4) extern const uint8_t pk[64];
      /** @brief Value length structure holding the public key.
       * @details The pk value pointed to is the public key present in dfu_public_key.c
      static nrf_crypto_ecc_public_key_t                  m_public_key;
      /** @brief Structure to hold a signature
      static nrf_crypto_ecdsa_secp256r1_signature_t       m_signature;
      /** @brief Structure to hold the hash for the init packet
      static nrf_crypto_hash_sha256_digest_t              m_init_packet_hash;
      /** @brief Structure to hold the hash for the firmware image
      static nrf_crypto_hash_sha256_digest_t              m_fw_hash;
      static void pb_decoding_callback(pb_istream_t *str,
                                       uint32_t tag,
                                       pb_wire_type_t wire_type,
                                       void *iter)
          pb_field_iter_t* p_iter = (pb_field_iter_t *) iter;
          // Match the beginning of the init command.
          if (p_iter->pos->ptr == &dfu_init_command_fields[0])
              uint8_t  * ptr  = (uint8_t *)str->state;
              uint32_t   size = str->bytes_left;
              // Remove tag byte.
              ptr++;
              size--;
              // Store the info in init_packet_data.
              m_init_packet_data_ptr = ptr;
              m_init_packet_data_len = size;
              NRF_LOG_DEBUG("PB: Init packet data len: %d", size);
      /** @brief Function for decoding byte stream into variable.
       *  @retval true   If the stored init command was successfully decoded.
       *  @retval false  If there was no stored init command, or the decoding failed.
      static bool stored_init_cmd_decode(void)
          m_pb_stream = pb_istream_from_buffer(s_dfu_settings.init_command,
                                               s_dfu_settings.progress.command_size);
          // Attach our callback to follow the field decoding.
          m_pb_stream.decoding_callback = pb_decoding_callback;
          m_init_packet_data_ptr = NULL;
          if (!pb_decode(&m_pb_stream, dfu_packet_fields, &m_packet))
              NRF_LOG_ERROR("Handler: Invalid protocol buffer m_pb_stream");
              return false;
          return true;
      void nrf_dfu_validation_init(void)
          uint8_t    pk_copy[sizeof(pk)];
          // If the command is stored to flash, init command was valid.
          if (   (s_dfu_settings.progress.command_size != 0)
              &&  stored_init_cmd_decode()
              && (s_dfu_settings.bank_1.image_size != 0))
              m_valid_init_cmd_present = true;
          err_code = nrf_crypto_init();
          ASSERT(err_code == NRF_SUCCESS);
          UNUSED_PARAMETER(err_code);
          // Convert public key to big-endian format for use in nrf_crypto.
          nrf_crypto_internal_double_swap_endian(pk_copy, pk, sizeof(pk) / 2);
          err_code = nrf_crypto_ecc_public_key_from_raw(&g_nrf_crypto_ecc_secp256r1_curve_info,
                                                        &m_public_key,
                                                        pk_copy,
                                                        sizeof(pk));
      nrf_dfu_result_t nrf_dfu_validation_init_cmd_create(uint32_t size)
          nrf_dfu_result_t ret_val = NRF_DFU_RES_CODE_SUCCESS;
          if (size == 0)
              ret_val = NRF_DFU_RES_CODE_INVALID_PARAMETER;
          else if (size > INIT_COMMAND_MAX_SIZE)
              ret_val = NRF_DFU_RES_CODE_INSUFFICIENT_RESOURCES;
              // Set DFU to uninitialized.
              // Reset all progress.
              s_dfu_settings.write_offset = 0;
              memset(&s_dfu_settings.progress, 0x00, sizeof(dfu_progress_t));
              // Set the init command size.
              s_dfu_settings.progress.command_size = size;
          return ret_val;
      nrf_dfu_result_t nrf_dfu_validation_init_cmd_append(uint8_t const * p_data, uint32_t length)
          if ((length + s_dfu_settings.progress.command_offset) > s_dfu_settings.progress.command_size)
              NRF_LOG_ERROR("Init command larger than expected.");
              // Copy the received data to RAM, update offset and calculate CRC.
              memcpy(&s_dfu_settings.init_command[s_dfu_settings.progress.command_offset],
                      p_data,
                      length);
              s_dfu_settings.progress.command_offset += length;
              s_dfu_settings.progress.command_crc = crc32_compute(p_data,
        length,
        &s_dfu_settings.progress.command_crc);
          return ret_val;
      void nrf_dfu_validation_init_cmd_status_get(uint32_t * p_offset,
                                                  uint32_t * p_crc,
                                                  uint32_t * p_max_size)
          *p_offset   = s_dfu_settings.progress.command_offset;
          *p_crc      = s_dfu_settings.progress.command_crc;
          *p_max_size = INIT_COMMAND_MAX_SIZE;
      bool nrf_dfu_validation_init_cmd_present(void)
          return m_valid_init_cmd_present;
      // Function determines if init command signature is obligatory.
      static bool signature_required(dfu_fw_type_t fw_type_to_be_updated)
          bool result = true;
          if ((!DFU_REQUIRES_SOFTDEVICE && (fw_type_to_be_updated == DFU_FW_TYPE_SOFTDEVICE)) ||
                  (fw_type_to_be_updated == DFU_FW_TYPE_APPLICATION))
              result = NRF_DFU_REQUIRE_SIGNED_APP_UPDATE;
          return result;
      // Function to perform signature check if required.
      static nrf_dfu_result_t signature_check(dfu_fw_type_t                          fw_type,
                                              dfu_signature_type_t                   signature_type,
                                              dfu_signed_command_signature_t const * p_signature)
          size_t     hash_len = NRF_CRYPTO_HASH_SIZE_SHA256;
          if (!signature_required(fw_type))
              return NRF_DFU_RES_CODE_SUCCESS;
          NRF_LOG_INFO("Signature required. Checking signature.")
          if (p_signature == NULL)
              NRF_LOG_WARNING("No signature found.");
              return EXT_ERR(NRF_DFU_EXT_ERROR_SIGNATURE_MISSING);
          if (signature_type != DFU_SIGNATURE_TYPE_ECDSA_P256_SHA256)
              NRF_LOG_INFO("Invalid signature type");
              return EXT_ERR(NRF_DFU_EXT_ERROR_WRONG_SIGNATURE_TYPE);
          NRF_LOG_INFO("Calculating init packet hash (init packet len: %d)", m_init_packet_data_len);
          err_code = nrf_crypto_hash_calculate(&m_hash_context,
                                               &g_nrf_crypto_hash_sha256_info,
                                               m_init_packet_data_ptr,
                                               m_init_packet_data_len,
                                               m_init_packet_hash,
                                               &hash_len);
              return NRF_DFU_RES_CODE_OPERATION_FAILED;
          if (sizeof(m_signature) != p_signature->size)
          // Prepare the signature received over the air.
          memcpy(m_signature, p_signature->bytes, p_signature->size);
          // Calculate the signature.
          NRF_LOG_INFO("Verify signature");
          // The signature is in little-endian format. Change it to big-endian format for nrf_crypto use.
          nrf_crypto_internal_double_swap_endian_in_place(m_signature, sizeof(m_signature) / 2);
          err_code = nrf_crypto_ecdsa_verify(&m_verify_context,
                                             &m_public_key,
                                             m_init_packet_hash,
                                             hash_len,
                                             m_signature,
                                             sizeof(m_signature));
              NRF_LOG_ERROR("Signature failed (err_code: 0x%x)", err_code);
              NRF_LOG_DEBUG("Signature:");
              NRF_LOG_HEXDUMP_DEBUG(m_signature, sizeof(m_signature));
              NRF_LOG_DEBUG("Hash:");
              NRF_LOG_HEXDUMP_DEBUG(m_init_packet_hash, hash_len);
              NRF_LOG_DEBUG("Public Key:");
              NRF_LOG_HEXDUMP_DEBUG(pk, sizeof(pk));
              NRF_LOG_FLUSH();
              return NRF_DFU_RES_CODE_INVALID_OBJECT;
          NRF_LOG_INFO("Image verified");
      // Function to calculate the total size of the firmware(s) in the update.
      static nrf_dfu_result_t update_data_size_get(dfu_init_command_t const * p_init, uint32_t * p_size)
          nrf_dfu_result_t ret_val = EXT_ERR(NRF_DFU_EXT_ERROR_INIT_COMMAND_INVALID);
          uint32_t         fw_sz   = 0;
          if ((p_init->type == DFU_FW_TYPE_APPLICATION) && (p_init->has_app_size == true))
              fw_sz = p_init->app_size;
              if ((p_init->type & DFU_FW_TYPE_SOFTDEVICE) && (p_init->has_sd_size == true))
                  fw_sz = p_init->sd_size;
              if ((p_init->type & DFU_FW_TYPE_BOOTLOADER) && (p_init->has_bl_size == true))
                  if (p_init->bl_size <= BOOTLOADER_SIZE)
                      fw_sz += p_init->bl_size;
                      NRF_LOG_ERROR("BL size (%d) over limit (%d)", p_init->bl_size, BOOTLOADER_SIZE);
                      fw_sz   = 0;
          if (fw_sz)
              *p_size = fw_sz;
              NRF_LOG_ERROR("Init packet does not contain valid firmware size");
          return ret_val;
       * @brief Function to check if single bank update should be used.
       * @param new_fw_type Firmware type.
      static bool use_single_bank(dfu_fw_type_t new_fw_type)
          bool result = false;
          if (((new_fw_type == DFU_FW_TYPE_APPLICATION) || (new_fw_type == DFU_FW_TYPE_SOFTDEVICE)) &&
              NRF_DFU_SINGLE_BANK_APP_UPDATES)
              result = true;
          return result;
      // Function to determine whether the new firmware needs a SoftDevice to be present.
      static bool update_requires_softdevice(dfu_init_command_t const * p_init)
          return ((p_init->sd_req_count > 0) && (p_init->sd_req[0] != SD_REQ_APP_OVERWRITES_SD));
      // Function to determine whether the SoftDevice can be removed during the update or not.
      static bool keep_softdevice(dfu_init_command_t const * p_init)
          UNUSED_PARAMETER(p_init); // It's unused when DFU_REQUIRES_SOFTDEVICE is true.
          return DFU_REQUIRES_SOFTDEVICE || update_requires_softdevice(p_init);
      /**@brief Function to determine where to temporarily store the incoming firmware.
       *        This also checks whether the update will fit, and deletes existing
       *        firmware to make room for the new firmware.
       * @param[in]  p_init   Init command.
       * @param[in]  fw_size  The size of the incoming firmware.
       * @param[out] p_addr   The address at which to initially store the firmware.
       * @retval NRF_DFU_RES_CODE_SUCCESS                 If the size check passed and
       *                                                  an address was found.
       * @retval NRF_DFU_RES_CODE_INSUFFICIENT_RESOURCES  If the size check failed.
      static nrf_dfu_result_t update_data_addr_get(dfu_init_command_t const * p_init,
                                                   uint32_t                   fw_size,
                                                   uint32_t                 * p_addr)
          ret_code_t err_code = nrf_dfu_cache_prepare(fw_size,
                                                      use_single_bank(p_init->type),
                                                      NRF_DFU_FORCE_DUAL_BANK_APP_UPDATES,
                                                      keep_softdevice(p_init));
              NRF_LOG_ERROR("Can't find room for update");
              *p_addr = nrf_dfu_bank1_start_addr();
              NRF_LOG_DEBUG("Write address set to 0x%08x", *p_addr);
          return ret_val;
      nrf_dfu_result_t nrf_dfu_validation_init_cmd_execute(uint32_t * p_dst_data_addr,
                                                           uint32_t * p_data_len)
          if (s_dfu_settings.progress.command_offset != s_dfu_settings.progress.command_size)
              // The object wasn't the right (requested) size.
              NRF_LOG_ERROR("Execute with faulty offset");
              ret_val = NRF_DFU_RES_CODE_OPERATION_NOT_PERMITTED;
          else if (m_valid_init_cmd_present)
              *p_dst_data_addr = nrf_dfu_bank1_start_addr();
              *p_data_len      = s_dfu_settings.bank_1.image_size;
          else if (stored_init_cmd_decode() &&
                  (m_packet.has_signed_command || m_packet.has_command))
              dfu_command_t const * p_command = &m_packet.command;
              dfu_signature_type_t             signature_type = (dfu_signature_type_t) 0; // Placeholder.
              dfu_signed_command_signature_t * p_signature    = NULL;
              *p_dst_data_addr = 0;
              *p_data_len      = 0;
              if (m_packet.has_signed_command)
                  p_command = &m_packet.signed_command.command;
                  signature_type =  m_packet.signed_command.signature_type;
                  p_signature    = &m_packet.signed_command.signature;
              // Validate signature.
              ret_val = signature_check(p_command->init.type, signature_type, p_signature);
              // Validate versions.
              if (ret_val == NRF_DFU_RES_CODE_SUCCESS)
                  ret_val = nrf_dfu_ver_validation_check(&p_command->init);
              // Get size of binary.
                  ret_val = update_data_size_get(&p_command->init, p_data_len);
              //Get address where to flash the binary.
                  ret_val = update_data_addr_get(&p_command->init, *p_data_len, p_dst_data_addr);
              NRF_LOG_ERROR("Failed to decode init packet");
              ret_val = NRF_DFU_RES_CODE_INVALID_OBJECT;
          return ret_val;
      // Function to check the hash received in the init command against the received firmware.
      static bool fw_hash_ok(dfu_init_command_t const * p_init, uint32_t fw_start_addr, uint32_t fw_size)
          bool       result   = true;
          uint8_t    hash_be[NRF_CRYPTO_HASH_SIZE_SHA256];
          ASSERT(p_init != NULL);
          // Convert to hash to big-endian format for use in nrf_crypto.
          nrf_crypto_internal_swap_endian(hash_be,
                                          (uint8_t *)p_init->hash.hash.bytes,
                                          NRF_CRYPTO_HASH_SIZE_SHA256);
          NRF_LOG_DEBUG("Hash verification. Firmware start address: 0x%x, size: 0x%x",
                        fw_start_addr,
                        fw_size);
                                               (uint8_t*)fw_start_addr,
                                               fw_size,
                                               m_fw_hash,
                                               &hash_len);
              NRF_LOG_ERROR("Could not run hash verification (err_code 0x%x).", err_code);
              result = false;
          else if (memcmp(m_fw_hash, hash_be, NRF_CRYPTO_HASH_SIZE_SHA256) != 0)
              NRF_LOG_WARNING("Hash verification failed.");
              NRF_LOG_DEBUG("Expected FW hash:")
              NRF_LOG_HEXDUMP_DEBUG(p_init->hash.hash.bytes, NRF_CRYPTO_HASH_SIZE_SHA256);
              NRF_LOG_DEBUG("Actual FW hash:")
              NRF_LOG_HEXDUMP_DEBUG(m_fw_hash, NRF_CRYPTO_HASH_SIZE_SHA256);
              NRF_LOG_FLUSH();
              result = false;
          return result;
      // Function to check whether the update contains a SoftDevice and, if so, if it is of a different
      // major version than the existing SoftDevice.
      static bool is_major_softdevice_update(uint32_t new_sd_addr)
          // True if there is no SD right now, but there is a new one coming. This counts as a major update.
          bool result = !SD_PRESENT && (SD_MAGIC_NUMBER_GET(new_sd_addr) == SD_MAGIC_NUMBER);
          if (SD_PRESENT && (SD_MAGIC_NUMBER_GET(new_sd_addr) == SD_MAGIC_NUMBER))
              // Both SoftDevices are present.
              uint32_t current_SD_major = SD_MAJOR_VERSION_EXTRACT(SD_VERSION_GET(MBR_SIZE));
              uint32_t new_SD_major     = SD_MAJOR_VERSION_EXTRACT(SD_VERSION_GET(new_sd_addr));
              result = (current_SD_major != new_SD_major);
              NRF_LOG_INFO("SoftDevice update is a %s version update. Current: %d. New: %d.",
                           result ? "major" : "minor",
                           current_SD_major,
                           new_SD_major);
          return result;
      /**@brief Validate the SoftDevice size and magic number in structure found at 0x2000 in received SoftDevice.
       * @param[in]  sd_start_addr  Start address of received SoftDevice.
       * @param[in]  sd_size        Size of received SoftDevice in bytes.
      static bool softdevice_info_ok(uint32_t sd_start_addr, uint32_t sd_size)
          bool result = true;
          if (SD_MAGIC_NUMBER_GET(sd_start_addr) != SD_MAGIC_NUMBER)
              NRF_LOG_ERROR("The SoftDevice does not contain the magic number identifying it as a SoftDevice.");
              result = false;
          else if (SD_SIZE_GET(sd_start_addr) < ALIGN_TO_PAGE(sd_size + MBR_SIZE))
              // The size in the info struct should be rounded up to a page boundary
              // and be larger than the actual size + the size of the MBR.
              NRF_LOG_ERROR("The SoftDevice size in the info struct is too small compared with the size reported in the init command.");
              result = false;
          return result;
      static void postvalidate_app(dfu_init_command_t * p_init)
          s_dfu_settings.bank_1.bank_code = NRF_DFU_BANK_VALID_APP;
          if (!DFU_REQUIRES_SOFTDEVICE && !update_requires_softdevice(p_init))
               // App does not need SD, so it should be placed where SD is.
               nrf_dfu_softdevice_invalidate();
          if (!NRF_DFU_DEBUG ||
                      (NRF_DFU_DEBUG && (p_init->has_is_debug == false || p_init->is_debug == false)))
              s_dfu_settings.app_version = p_init->fw_version;
      // Function to check a received SoftDevice or Bootloader firmware, or both,
      // before it is copied into place.
      static bool postvalidate_sd_bl(dfu_init_command_t * p_init,
                                     bool                 with_sd,
                                     bool                 with_bl,
                                     uint32_t             start_addr)
          if (with_sd)
              if (!softdevice_info_ok(start_addr, p_init->sd_size))
                  return false;
              if (is_major_softdevice_update(start_addr))
                  NRF_LOG_WARNING("Invalidating app because it is incompatible with the SoftDevice.");
                  if (DFU_REQUIRES_SOFTDEVICE && !with_bl)
                      NRF_LOG_ERROR("Major SD update but no BL. Abort to avoid incapacitating the BL.");
                      return false;
                  // Invalidate app since it may not be compatible with new SD.
                  nrf_dfu_bank_invalidate(&s_dfu_settings.bank_0);
              // Mark the update as valid.
              s_dfu_settings.bank_1.bank_code = with_bl ? NRF_DFU_BANK_VALID_SD_BL
                                                        : NRF_DFU_BANK_VALID_SD;
              s_dfu_settings.sd_size = p_init->sd_size;
              s_dfu_settings.bank_1.bank_code = NRF_DFU_BANK_VALID_BL;
          if (with_bl &&
              (!NRF_DFU_DEBUG ||
              (NRF_DFU_DEBUG && (p_init->has_is_debug == false || p_init->is_debug == false))))
              // If the update contains a bootloader, update the version.
              // Unless the update is a debug packet.
              s_dfu_settings.bootloader_version = p_init->fw_version;
          return true;
      nrf_dfu_result_t nrf_dfu_validation_post_data_execute(uint32_t src_addr, uint32_t data_len)
          dfu_init_command_t * p_init  = m_packet.has_signed_command ?
                                           &m_packet.signed_command.command.init : &m_packet.command.init;
          if (!fw_hash_ok(p_init, src_addr, data_len))
              ret_val = EXT_ERR(NRF_DFU_EXT_ERROR_VERIFICATION_FAILED);
              if (p_init->type == DFU_FW_TYPE_APPLICATION)
      #if defined(NRF_DFU_SUPPORTS_EXTERNAL_APP) && NRF_DFU_SUPPORTS_EXTERNAL_APP == 1
                  switch (nrf_dfu_validation_post_external_app_execute(p_init, false))
                      case NRF_DFU_RES_CODE_INVALID:
                          postvalidate_app(p_init);
                      case NRF_DFU_RES_CODE_SUCCESS:
                          s_dfu_settings.bank_1.bank_code = NRF_DFU_BANK_VALID_EXT_APP;
      #else
                  bool with_sd = p_init->type & DFU_FW_TYPE_SOFTDEVICE;
                  bool with_bl = p_init->type & DFU_FW_TYPE_BOOTLOADER;
                  if (!postvalidate_sd_bl(p_init, with_sd, with_bl, src_addr))
                      if (with_sd && !DFU_REQUIRES_SOFTDEVICE &&
                          (src_addr == nrf_dfu_softdevice_start_address()))
              if(s_dfu_settings.settings_version == 1)
                  // Store CRC32 for image.
                  s_dfu_settings.bank_1.image_crc = s_dfu_settings.progress.firmware_image_crc;
                  s_dfu_settings.bank_1.image_size = data_len;
              else if(s_dfu_settings.settings_version == 2)
                  s_dfu_settings.bank_current = NRF_DFU_CURRENT_BANK_1;
              nrf_dfu_bank_invalidate(&s_dfu_settings.bank_1);
              // Set the progress to zero and remove the last command.
              memset(&s_dfu_settings.progress, 0, sizeof(dfu_progress_t));
              memset(s_dfu_settings.init_command, 0xFF, DFU_SIGNED_COMMAND_SIZE);
              s_dfu_settings.progress.update_start_address = src_addr;
          return ret_val;
      bool nrf_dfu_validation_valid_external_app(void)
          return s_dfu_settings.bank_1.bank_code == NRF_DFU_BANK_VALID_EXT_APP;
      ret_code_t nrf_dfu_validation_invalidate_external_app(nrf_dfu_flash_callback_t callback)
          return nrf_dfu_settings_write(callback);
    I have tested that I'm able to perform DFU using the following steps:
    1. Flash original bootloader and DFU client from SDK 2.0.0
    2. Upgrade application to "middle application", built from SDK 2.0.0 with the above files.
    3. Upgrade bootloader to SDK 4.1.0.
    4. Upgrade application to DFU client from SDK 4.1.0.
    Let me know if you are not able to upgrade using these files.
    Jørgen
