Failed to open AT socket (err:-12)
I developed board with NRF9160 chip and I am facing issue with "at_cmd: Failed to open AT socket (err:-12)", i am not able to communicate with modem. It is not working with any of examples and also asset_tracker application. I am able to update firmware in modem and flash the chip. The same examples works fine on NRF9160-DK Board, the only difference i noticed is that the DK board has NRF9160_xxAA_REV1, and my board is with NRF9160_xxAA_REV2. Did anyone faced the same issue?
Michal
  • Hello Michal,
    What version of NCS and modem fw are you running? The error message means:
    #define	ENOMEM		12	/* Out of memory */
    Øyvind
    I am using the 1.1.0 modem firmware ( due to certification for Deutsche Telekom ) and the same version of NCS v1.1.0
    Michal
  • Are you getting any error codes?
    Are you able to run a standard sample from NCS 1.3.0 on you custom board e.g. at_client?
    oKruszek said:
    I tried with the NCS 1.3.0 and newest firmware, the response is above yours.
     Did not see that comment while writing my previous response.
    Øyvind
    I just tried at_client, but i have ERROR on every AT commands, the output below:
    *** Booting Zephyr OS build v2.3.0-rc1-ncs1 ***
    Flash regions..Domain..Permissions
    00 00 0x00000 0x08000 .Secure..rwxl
    01 31 0x08000 0x100000 .Non-Secure.rwxl
    Non-secure callable region 0 placed in flash region 0 with size 32.
    SRAM region..Domain..Permissions
    00 07 0x00000 0x10000 .Secure..rwxl
    08 31 0x10000 0x40000 .Non-Secure.rwxl
    Peripheral..Domain..Status
    00 NRF_P0 Non-Secure.OK
    01 NRF_CLOCK Non-Secure.OK
    02 NRF_RTC0 Non-Secure.OK
    03 NRF_RTC1 Non-Secure.OK
    04 NRF_NVMC Non-Secure.OK
    05 NRF_UARTE1 Non-Secure.OK
    06 NRF_UARTE2 Secure..SKIP
    07 NRF_TWIM2 Non-Secure.OK
    08 NRF_SPIM3 Non-Secure.OK
    09 NRF_TIMER0 Non-Secure.OK
    10 NRF_TIMER1 Non-Secure.OK
    11 NRF_TIMER2 Non-Secure.OK
    12 NRF_SAADC Non-Secure.OK
    13 NRF_PWM0 Non-Secure.OK
    14 NRF_PWM1 Non-Secure.OK
    15 NRF_PWM2 Non-Secure.OK
    16 NRF_PWM3 Non-Secure.OK
    17 NRF_WDT Non-Secure.OK
    18 NRF_IPC Non-Secure.OK
    19 NRF_VMC Non-Secure.OK
    20 NRF_FPU Non-Secure.OK
    21 NRF_EGU1 Non-Secure.OK
    22 NRF_EGU2 Non-Secure.OK
    23 NRF_DPPIC Non-Secure.OK
    24 NRF_GPIOTE1 Non-Secure.OK
    25 NRF_REGULATORS Non-Secure.OK
    SPM: NS image at 0xc000
    SPM: NS MSP at 0x20027aa8
    SPM: NS reset vector at 0xd08d
    SPM: prepare to jump to Non-Secure image.
    The AT host sample started
    AT
    ERROR
  • Can you provide the full markings on the device you have? Have you had a review of your custom board? If not, I encourage you to register a support ticket to get a HW review. Have you verified that the board is sufficiently soldered? And that the layout is according to our reference (Hardware files) e.g. Thingy:91 or nRF9160DK ?
    Does your application, based on NCS 1.3.0, work with the DK running modem fw 1.1.0?
    Thanks for advice! I sent the our custom board for review, and also check if the NCS 1.3.0 works with FW 1.1.0 and it seems that everything works ok ( i checked connection, fota update, and interrupts )
    Michal
  • Great! While waiting it would be good if you can reheat you board to ensure that the SiP is correctly soldered.
    Øyvind
