GPIO Config Issue
I am working on nRF52840 DK.
C:\Nordic\SDK\nRF5SDK17009d13099\nRF5_SDK_17.0.0_9d13099\examples\peripheral\uart
I am sending data from Arduino and showing it on PuTTY.
I am configuring the P0.0 pin as output but unable to turn On/Off.
I am attaching my code(With red color).
Can you please mention where I am making mistake.
Thanks.
* Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup uart_example_main main.c
* @ingroup uart_example
* @brief UART Example Application main file.
* This file contains the source code for a sample application using UART.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "nrf_gpio.h"
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#define LED1_PIN 0
//#define ENABLE_LOOPBACK_TEST /**< if defined, then this example will be a loopback test, which means that TX should be connected to RX to get data loopback. */
#define MAX_TEST_DATA_BYTES (15U) /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
void uart_error_handle(app_uart_evt_t * p_event)
if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
else if (p_event->evt_type == APP_UART_FIFO_ERROR)
#ifdef ENABLE_LOOPBACK_TEST
/* Use flow control in loopback test. */
#define UART_HWFC APP_UART_FLOW_CONTROL_ENABLED
/** @brief Function for setting the @ref ERROR_PIN high, and then enter an infinite loop.
static void show_error(void)
bsp_board_leds_on();
while (true)
// Do nothing.
/** @brief Function for testing UART loop back.
* @details Transmitts one character at a time to check if the data received from the loopback is same as the transmitted data.
* @note @ref TX_PIN_NUMBER must be connected to @ref RX_PIN_NUMBER)
static void uart_loopback_test()
uint8_t * tx_data = (uint8_t *)("\r\nLOOPBACK_TEST\r\n");
uint8_t rx_data;
// Start sending one byte and see if you get the same
for (uint32_t i = 0; i < MAX_TEST_DATA_BYTES; i++)
uint32_t err_code;
while (app_uart_put(tx_data[i]) != NRF_SUCCESS);
nrf_delay_ms(10);
err_code = app_uart_get(&rx_data);
if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS))
show_error();
return;
#else
/* When UART is used for communication with the host do not use flow control.*/
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
uint32_t err_code;
nrf_gpio_cfg_output(LED1_PIN);
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
UART_HWFC,
false,
NRF_UART_BAUDRATE_115200
#else
NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_error_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
#ifndef ENABLE_LOOPBACK_TEST
printf("\r\nUART example started.\r\n");
while (true)
uint8_t cr;
while (app_uart_get(&cr) != NRF_SUCCESS);
while (app_uart_put(cr) != NRF_SUCCESS);
if (cr == 'q' || cr == 'Q')
printf(" \r\nExit!\r\n");
while (true)
// Do nothing.
if (cr == '1')
nrf_gpio_pin_set(LED1_PIN);
printf(" \r\nLED ON\r\n");
else if (cr == '0')
//bsp_board_led_off(LEDBUTTON_LED);
nrf_gpio_pin_clear(LED1_PIN);
printf(" \r\nLED OFF\r\n");
#else
// This part of the example is just for testing the loopback .
while (true)
uart_loopback_test();
  • Hi
    P0.00 and P0.01 are, by default, used for the external LF CLOCK (32.768 kHz crystal) on the nRF52 series. When using a DK, you can't use these pins as GPIOs unless you disconnect the external crystal. On the DK, this can be done by cutting solder bridges SB1 and SB2, and soldering SB3 and SB4. This should disconnect the external crystal, and connect them to the GPIO outputs on your DK.
    You will also have to configure your application to use the internal RC oscillator instead of the external LF clock if you want to use these GPIOs. This can be done by editing the following defines in your sdk_config.h file:
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC  - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i>  if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY  - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
    We strongly recommend using any other GPIOs if you have the opportunity, as it will save you a lot of work, and using the 32kHz crystal will give you much lower average current consumption than using the RC oscillator.
    Simon
    I have changed the pin and try to use pin P0.05 but still not working.
    #define LED1_PIN 5
    Any suggestions, please?
  • Hi
    If you take a look at the back side of your nRF52840 DK, you can see that P0.05 is used for UART communication (RTS pin) by default. What is this pin supposed to do anyway? Is it just a LED or an output to the PuTTY terminal?
    You can try using one of the free GPIOs mentioned in the DK user guide (any pins on header P2 and P3).
    Simon
  • Thanks I have used P0.31 and its working now.
    How can I use port 1 pins means how can I define them? (For example, how can I define P1.08?)
    #define LED1_PIN ??
  • Hi
    You can use the NRF_GPIO_PIN_MAP to set port and pin number.
    Simon
