nRF9160 Timer issue
Dear Sir.
I am using the Timer of nRF916 .
In a simple project the timer is working fine ( see attached code ).
A buzzer is connected to PWM output pin 12.
I can here the Buzzer beeps as expected .
 * Copyright (c) 2016 Intel Corporation
#include <nrf9160.h>
#include <zephyr.h>
#include <device.h>
#include <drivers/pwm.h>
#include <drivers/gpio.h>
//#define LED		12
#define PWM_IO		12
struct device *pwm_dev;
/* 1000 msec = 1 sec */
#define SLEEP_TIME	100
struct k_timer bz_timer;
void bz_func(struct k_timer *timer_id)
    static unsigned char k = 0;
    static unsigned int time = 0;
     // Siren
//     if(time == 0)
//       pwm_pin_set_usec(pwm_dev,PWM_IO, 260, 130,0);
//     if(time == 10)
//      pwm_pin_set_usec(pwm_dev,PWM_IO, 400, 200,0);
//     if(++time >= 20)
//       time = 0;
     // Short Beep
     if(time == 0)
     if(time == 7)
       pwm_pin_set_usec(pwm_dev,PWM_IO, 400, 0,0);
     if(++time >= 100)
       time = 0;
     // Long Beep
//     if(time == 0)
//     if(time == 20)
//       pwm_pin_set_usec(pwm_dev,PWM_IO, 400, 0,0);
//     if(++time >= 150)
//       time = 0;
       // Train
//       if(k < 100)
//         if(time == 0)
//         if(time == 5)
//         if(++time >= 20)
//           time = 0;
//           if(++k > 20)
//            k = 100;
void main(void)
	u32_t cnt = 0;
	struct device *dev_io;
        printk("PWM Application has started!\r\n");
        pwm_dev = device_get_binding("PWM_0");
        if (!pwm_dev) {
		printk("Cannot find %s!\n", "PWM_0");
		return;
        k_timer_init(&bz_timer, bz_func, NULL);
        k_timer_start(&bz_timer, K_SECONDS(1), K_MSEC(50));
        while(1)
            k_sleep(K_MSEC(800));
In another larger project , I insert the Timer code , and it behaves erratically .
The time between each entry to the timer is seconds.
What can cause this behavior ?.
Please Advise
    unsigned char k;
     // Siren
     if(time == 0)
     if(time == 10)
     if(++time >= 20)
       time = 0;
void main(void)
      int err;
      static unsigned int i = 0;
      k_work_init(&work_top, work_top_func);
      k_work_init(&work_spi, spi_work_func);
      k_work_init(&work_adp5360, adp5360_work_func);
      initStructures();
       // Ephraim 26_5_2020
       _AFE4900_AQUIRE_MODE.aquire_mode =  afe4900_aquire_sample;
      io_init();
      pwm_init();
      while(1) {
          k_sleep(K_MSEC(2000));
  • Hi.
    One more thing
    /* install my_isr() as interrupt handler for the device (not shown) */
    How do I set thid handler ?.
    Thanks
    In this case, my_isr() is equivalent to your k_timer handler (bz_func).
    Håkon
  • Hi.
    I stripped all unnecessary code .
    Still the same error ( reset over and over.)
    Please Advise
     * Copyright (c) 2018 Nordic Semiconductor ASA
     * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
    #include <zephyr.h>
    #include <stdio.h>
    #include <drivers/uart.h>
    #include <string.h>
    #include <stdlib.h>
    #include <main.h>
    #include <drivers/adc.h>
    #include <drivers/spi.h>
    #include <drivers/i2c.h>
    //#include <drivers/timer.h>
    #include <net/mqtt.h>
    #include <net/socket.h>
    #include <lte_lc.h>
    #if defined(CONFIG_LWM2M_CARRIER)
    #include <lwm2m_carrier.h>
    #include <kernel.h>
    #include <c:/zephyr/v1.2.0/zephyr/include/power/reboot.h>
    #include <MT25QL128ABA.h>
    #include <afe4900.h>
    #include <adp536x.h>
    #include <lis2dh12.h>
    #include <init.h>
    #include <hal/nrf_saadc.h>
    #include <stdarg.h>
    #define TIEMR_INTERVAL_SEC 1
    #define TIEMR_INTERVAL_mSEC 10
    struct device * pwm_dev;
    #define MY_STACK_SIZE 512
    #define MY_PRIORITY 5
    K_THREAD_STACK_DEFINE(my_stack_area, MY_STACK_SIZE);
    struct k_work_q my_work_q;
    struct device_info {
        struct k_work work;
        char name[16]
    } my_device;
         k_work_submit(&my_device.work);
    void activate_buzzer(struct k_work *item)
         unsigned char k;
        struct device_info *the_device =
            CONTAINER_OF(item, struct device_info, work);
         if(time == 0)
           printk("Fisrt PWM set \n" );
           SetLed(BLUE,ON);
           SetLed(GREEN,OFF);
        if(time == 10)
           printk("Second PWM set \n" );
           SetLed(BLUE,OFF);
           SetLed(GREEN,ON);
        if(++time >= 20)
           time = 0;
    void main(void)
          int err;
      //    initStructures();
      //     _AFE4900_AQUIRE_MODE.aquire_mode =  afe4900_aquire_sample;
          k_timer_start(&bz_timer, K_SECONDS(1), K_MSEC(100));
          k_work_q_start(&my_work_q, my_stack_area,
                  K_THREAD_STACK_SIZEOF(my_stack_area), MY_PRIORITY);
          strcpy(my_device.name, "FOO_dev");
          k_work_init(&my_device.work, activate_buzzer);
          io_init();
          pwm_init();
          while(1) {
    Could you try starting the timer instance after initializing io_init and pwm_init?
    Håkon
