Dear Team,
I am try to customize the some of the parameter of HTS221 temperature and humidity sensor used in thingy52 board, However if I change any of the parameter then I am not able any output of the temperature sensor in thingy aap
Dear Team,
What parameters did you change ?
Thanks for reply!,
By default sensor is running with following configuration:
AV_CONF(10h) : 0x1B
CTRL_REG1(20h) : 00
I want use (HTS221) sensor with following configuration:
AV_CONF (10h) = 0x1F
CTRL_REG1 (20h) = 0x87
It might be the CTRL_REG1 that is causing the issue.
If you only change AV_CONF to 1F, and keep CTRL_REG1 at 00, does it work then ?
Yes it is working
Ok. The Thingy:52 humidity driver is doing one-shot readings, see this link. So it looks like your configuration of the CTRL_REG1 register is not compatible with the way the Thingy:52 humidity driver is designed to work.
