Error modifying ble_app_beacon in SES. (Tx power modification).
I am a complete noob. I don't have any programming experience and I am just playing around with NRF52 DK.
I want to modify the Tx power of the NRF52 DK with the ble_app_beacon application.
I setup the Segger Embedded studio. I opened the ble_app_beacon project.
I was able to successfully compile and upload the unedited version to the NRF52 DK.
But when I tried adding the function for the Tx power, I got different problems.
First I added this just before the main() function.
uint32_t sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_adv_handle, 4);
And I got this error.
expected ')' before numeric constant
After that I tried to use a variable for the tx_power value.
int8_t tx_power1 = 4;
uint32_t sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_adv_handle, txpower1);
And I got these three errors this time.
a. parameter names (without types) in function declaration
b. conflicting types for 'sd_ble_gap_tx_power_set'
c. an argument type that has a default promotion can't match an empty parameter name list declaration
 * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_app_beacon_main main.c
 * @ingroup ble_sdk_app_beacon
 * @brief Beacon Transmitter Sample Application main file.
 * This file contains the source code for an Beacon transmitter sample application.
#include <stdbool.h>
#include <stdint.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                  /**< A tag identifying the SoftDevice BLE configuration. */
#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE                 0x02                               /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI               0xC3                               /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER          0x0059                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE                 0x01, 0x02                         /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE                 0x03, 0x04                         /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                        0x45, 0x56, 0x67, 0x78, \
                                        0x89, 0x9a, 0xab, 0xbc, \
                                        0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
#define DEAD_BEEF                       0xDEADBEEF                         /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                 /**< Position of the MSB of the Major Value in m_beacon_info array. */
#define UICR_ADDRESS                    0x10001080                         /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = NULL,
        .len    = 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                         // implementation.
    APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                         // manufacturer specific data in this implementation.
    APP_BEACON_UUID,     // 128 bit UUID value.
    APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
    APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
    APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                         // this implementation.
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    uint32_t      err_code;
    ble_advdata_t advdata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
    m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration        = 0;       // Never time out.
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    ret_code_t err_code;
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing LEDs. */
static void leds_init(void)
    ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
/**@brief Function for initializing timers. */
static void timers_init(void)
        nrf_pwr_mgmt_run();
 * @brief Function for application main entry.
    // Initialize.
    log_init();
    timers_init();
    leds_init();
    power_management_init();
    ble_stack_init();
    advertising_init();
    // Start execution.
    NRF_LOG_INFO("Beacon example started.");
    advertising_start();
    // Enter main loop.
    for (;; )
        idle_state_handle();
I intend to use softdevice 112.
Running Windows 10
NRF52 DK says: PCA10040;   1.2.4;   2019.8
  • Hi.
    Sorry about the delay here.
    So you are not making a call to the sd_ble_gap_tx_power_set() function when added like that before main().
    The sd_ble_gap_tx_power_set() function uses the softdevice to change the tx power, so you should wait until the softdevice is initialized before calling the function.
    The softdevice is initialized inside ble_stack_inti() inside main().
    For the BLE_GAP_TX_POWER_ROLE_ADV, you should set the advertising handle after the advertising_init() function.
    If you have any further questions, please let me know.
    Br,
    Joakim
