Tool to generate secured gazell pairing data for pre-paired secured gazell devices using only cables in production
To the kind attention of Nordic support team,
we are using secured gazell library in our devices. We would like to pre-pair couple of devices (host-device) using valid secured gazell data for both,
without doing the actual pairing over the air. We would like to write pairing data in gazell flah memory areas using usb cables during production,
so to avoid any problem. Is there a simple way, maybe a tool, that is able to generate data valid to pair a couple of devices?
Should we build it on our own, after studying the key generation algorithm that is used for secured gazell library pairing?
Is there any tool that you could suggest? Any idea you have in mind to speed up this thing?
Thank you for your precious suggestions,
Best regards
