Erasing UICR doesn't work on S130
SDK 7.2 S130 Alpha 0.9
I'm using the UICR customer register address 0x10001080 to stare a single 32 bit number. The code below is a bit of "brute force" to demonstrate what I'm trying to do:
static void write_uicr_customer_register(uint32_t * data, uint32_t offset)
uint32_t* cust_data = (uint32_t*)(NRF_UICR_BASE + 0x80 + offset);
if(*cust_data != 0xFFFFFFFF)
	NRF_NVMC->CONFIG = 2; //erase enable
	while(NRF_NVMC->READY == NVMC_READY_READY_Busy);//busy
	NRF_NVMC->ERASEUICR = 1; //perform erase of UICR only
	while(NRF_NVMC->READY == NVMC_READY_READY_Busy || NRF_NVMC->ERASEUICR == 1);//busy
	while(*cust_data != 0xFFFFFFFF);
NRF_NVMC->CONFIG = 1; //write enabled
*cust_data = *data;
NRF_NVMC->CONFIG = 0; //read only
NVIC_SystemReset();
The first run, everything writes correctly. It just doesn't erase so I can re-write to it. Is there some trick to erase the UICR registers?
