NRF52810 Unable to get GPIO output on P0.15.
Part - NRF52810-QFAA-R7
I've tried two chips, reflowed and checked under microscope. I have a connection to the track the pin connects to.
Errata is applied via SystemInit();
Straight after this the pin is set high. It has a 470k pull down resistor but otherwise no load.
  NRF_GPIO->PIN_CNF[CFG_PIN_SHUTDOWN_AWAKE] = pinDisconnectInputBuffer | (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos);
  NRF_GPIO->OUTSET = 1 << CFG_PIN_SHUTDOWN_AWAKE;
However the pin remains low. I've checked that it's not used by default by any peripherals or set in conflicting code.
I did find something about debug and tracemode though this was for the 832. I tried it anyway but it made no difference.
  CoreDebug->DEMCR &= ~CoreDebug_DEMCR_TRCENA_Msk;
Anything else?
Cheers, Andrew
  • Hello Andrew,
    What are the parameters:
    CFG_PIN_SHUTDOWN_AWAKE, pinDisconnectInputBuffer?
    Does your implementation work on other pins? Or is it only pin 15 it doesn't work on?
    What errata do you refer to?
    Are you sure the pin isn't used by anything else? It is by default the pin for button 3. Do you call
    I have a project that I use to test small things like these. This worked for me:
    custom_pin_test()
        NRF_GPIO->PIN_CNF[15] = (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos);
        NRF_GPIO->PIN_CNF[17] = (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos);
        NRF_GPIO->OUTSET = (1 << 15) | (1 << 17);
    If you want to test this in an application, you can test this main.c file in the ble_app_uart example from SDK17.0.0:
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(7.5, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    volatile uint32_t m_test_counter = 0;
    volatile uint32_t m_parity = 0;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    APP_TIMER_DEF(m_test_timer_id);
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    static void my_adv_stop(void)
        NRF_LOG_INFO("stop advertising");
        //uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        ret_code_t err_code;
        uint8_t my_adv_handle = m_advertising.adv_handle;
        err_code = sd_ble_gap_adv_stop(my_adv_handle);
    static void my_adv_start(void)
        NRF_LOG_INFO("start advertising");
    static void my_timeout_handler(void * p_context)
        m_test_counter++;
        if (m_test_counter%2 == 0)
            NRF_GPIO->OUTCLR = (1 << 15) | (1 << 17);
        NRF_LOG_INFO("Timer timeout number %d", m_test_counter);
        if (m_test_counter%10 == 0)
            if ((m_test_counter/10)%2 == 1)
                my_adv_stop();
                my_adv_start();
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
        err_code = app_timer_create(&m_test_timer_id, APP_TIMER_MODE_REPEATED, my_timeout_handler);
        err_code = app_timer_start(m_test_timer_id, APP_TIMER_TICKS(1000), NULL);
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            //NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on UART.");
            //NRF_LOG_HEXDUMP_DEBUG(p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            uint8_t * rcv_data = (uint8_t *)p_evt->params.rx_data.p_data;
            uint16_t rcv_len = (uint16_t)p_evt->params.rx_data.length;
            err_code = ble_nus_data_send(&m_nus, rcv_data, &rcv_len, p_evt->conn_handle);
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
            case BSP_EVENT_KEY_3:
                NRF_LOG_INFO("button 4 pressed");
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    static void custom_pin_test(void)
        NRF_LOG_INFO("customm_pin_test");
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        //buttons_leds_init(&erase_bonds);
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        custom_pin_test();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    NB: If you want to run examples from the SDK on an actual nRF52811, please remember to remove the preprocessor definition: DEVELOP_IN_NRF52832
    The example file will toggle the pins 17 and 15 every 1s. It is done in the callback: my_timeout_handler() near the top of the main.c file.
    Also note that I commented out buttons_leds_init() in main(), because these will use the pins for the LEDs and buttons by default. If this is not commented out, none of the pins will work as intended.
    BR,
    Edvin
  • I'm not using the SDK and I use the same approach as yourself, plus it works for other pins. It's a strange one, but I've reflowed a second chip with the same outcome. It's as if there's a peripheral using it by default, something that I haven't specifically set. I will remove the chip tomorrow and inspect the board pin, it's all I can think off.
  • I've threw everything at it. I'm 100% sure the pin has reflow soldered correctly and I have a trace on the line which suggests it's driven low. I'm not using any of the SDK functionality so the only pin management code I have is -
    #define CFG_PIN_SHUTDOWN_AWAKE 15
    #define pinDisconnectInputBuffer GPIO_PIN_CNF_INPUT_Disconnect << GPIO_PIN_CNF_INPUT_Pos
    I've also tried swapping the chip.
    The only thing I can think off is it's used by default or by debugging by default in some way.
    Preprocessor defs are
    NRF_LOG_ENABLED=1
    DEBUG
    DEBUG_NRF
    INITIALIZE_USER_SECTIONS
    FLOAT_ABI_SOFT
    NO_VTOR_CONFIG
    NRF52810_XXAA
    NRF_SD_BLE_API_VERSION=7
    S112
    SOFTDEVICE_PRESENT
    APP_TIMER_V2
    APP_TIMER_V2_RTC1_ENABLED
    FLASH_APPSETTINGS_START=0x00027000
    FLASH_APPSETTINGS_END=0x00028000
    FLASH_BOOTLOADERSETTINGS_START=0x0002F000
