Flash FDS initialization failure until 4 reset with nRF5 SDK for Thread and Zigbee v4.1.0
Hi everyone.
I have an application using BLE and OpenThread dynamicaly.
I am working with nRF52840 chip with nRF5 SDK for Thread and Zigbee v4.1.0 (Release Date: Week 18, 2020)
In order to store the advertising data and some mesh parameters, I need to use the flash.
I first try to implement a solution with nrf_fstorage module, but I had a lot of issues with it so I changed for FDS module.
I manage to implement a working solution exept that the first time the chip is programmed (after a full erase), I need to do 3 to 4 resets befor the program starts.
I have been investigating in debug mode. It seems I am stuck somewhere into sd_app_evt_wait();
Here is my code to init the flash :
static bool volatile fdsInitialized;
static bool writeTerminated;
/************************************* fds_evt_handler ***************************************/
* @Brief Simple event handler to handle errors during initialization.
static void fds_evt_handler(fds_evt_t const * p_evt)
		switch (p_evt->id){
			case FDS_EVT_INIT:
					if (p_evt->result == FDS_SUCCESS){
						 fdsInitialized = true;
			case FDS_EVT_WRITE:
						 writeTerminated = true;
			case FDS_EVT_UPDATE:
						 if(netStr2Save.netReset == 1){
								//Restar tne Mesh Network with the new name
								NVIC_SystemReset();
			case FDS_EVT_DEL_RECORD:
			 case FDS_EVT_GC:
						 flash_save_config(&netStr2Save);
void flash_init(void){
	ret_code_t ret = fds_register(fds_evt_handler);
	if (ret != FDS_SUCCESS)
    	return ret;
	ret = fds_init();
		return ret;
    while (!fdsInitialized){
        sd_app_evt_wait();
The flash init function is called after ble_stack_init in the main.
Here is the SDK config I  have got :
/ <e> FDS_ENABLED - fds - Flash data storage module
#ifndef FDS_ENABLED
#define FDS_ENABLED 1
// <h> Pages - Virtual page settings
// <i> Configure the number of virtual pages to use and their size.
// <o> FDS_VIRTUAL_PAGES - Number of virtual flash pages to use.
// <i> One of the virtual pages is reserved by the system for garbage collection.
// <i> Therefore, the minimum is two virtual pages: one page to store data and one page to be used by the system for garbage collection.
// <i> The total amount of flash memory that is used by FDS amounts to @ref FDS_VIRTUAL_PAGES * @ref FDS_VIRTUAL_PAGE_SIZE * 4 bytes.
#ifndef FDS_VIRTUAL_PAGES
#define FDS_VIRTUAL_PAGES 3
// <o> FDS_VIRTUAL_PAGE_SIZE  - The size of a virtual flash page.
// <i> Expressed in number of 4-byte words.
// <i> By default, a virtual page is the same size as a physical page.
// <i> The size of a virtual page must be a multiple of the size of a physical page.
// <1024=> 1024
// <2048=> 2048
#ifndef FDS_VIRTUAL_PAGE_SIZE
#define FDS_VIRTUAL_PAGE_SIZE 1024
// <o> FDS_VIRTUAL_PAGES_RESERVED - The number of virtual flash pages that are used by other modules.
// <i> FDS module stores its data in the last pages of the flash memory.
// <i> By setting this value, you can move flash end address used by the FDS.
// <i> As a result the reserved space can be used by other modules.
#ifndef FDS_VIRTUAL_PAGES_RESERVED
#define FDS_VIRTUAL_PAGES_RESERVED 4
// </h>
// <h> Backend - Backend configuration
// <i> Configure which nrf_fstorage backend is used by FDS to write to flash.
// <o> FDS_BACKEND  - FDS flash backend.
// <i> NRF_FSTORAGE_SD uses the nrf_fstorage_sd backend implementation using the SoftDevice API. Use this if you have a SoftDevice present.
// <i> NRF_FSTORAGE_NVMC uses the nrf_fstorage_nvmc implementation. Use this setting if you don't use the SoftDevice.
// <1=> NRF_FSTORAGE_NVMC
// <2=> NRF_FSTORAGE_SD
#ifndef FDS_BACKEND
#define FDS_BACKEND 2
I found a few posts on the forum about similar issues, but none of them solved mine.
Would you have any ideas where it could come from ?
Best regards.
    I just had a quick glance in the ble_zigbee_fynamic_door_lock_nus example, and I see that FDS_VIRTUAL_PAGES_RESERVED is set to:
    #define FDS_VIRTUAL_PAGES_RESERVED ((ZIGBEE_NVRAM_PAGE_SIZE * ZIGBEE_NVRAM_PAGE_COUNT + ZIGBEE_NVRAM_CONFIG_PAGE_SIZE * ZIGBEE_NVRAM_CONFIG_PAGE_COUNT)/(FDS_VIRTUAL_PAGE_SIZE * 4))
    Which in this case gives FDS_VIRTUAL_PAGES_RESERVED = 9
    While in your sdk_config.h it is set to 4.
    Can you please try to use the macro from the ble_zigbee_dynamic_door_lock_nus example? If you can use the macros, then it will automatically adjust to your project, rather than just assuming it is 9 in your case as well.
    Based on your description above, you are stuck in flash_init() -> sd_app_evt_wait(), right?
    Where do you call flash_init() from? From your main() function, or an interrupt?
    I am also not sure about your implementation. What happens if you check fdsInitialized, which is false, and then you get the interrupt setting it to true right before you call sd_app_evt_wait()? You would have to wait for another interrupt then. Just for debugging purposes, try to comment out sd_app_evt_wait() in flash_init(). Does it behave the same?
    Also, could it be that you receive the FDS_EVT_INIT event, but the result != NRF_SUCCESS? Try to ignore the p_evt->result and see if it still behaves the same.
    Do you have any logging from the FDS module? If so, does it say anything?
    BR,
    Edvin
  • Hi Edvin,
    Thank for your quick answer.
    I tried the macro you wrote but most of the ZIGBEE macro are not defined in my case. I tried with 9 instead of 4 but it did not solve the issue.
    My program seems indeed stuck into sd_app_evt_wait(). I do not know where exactly since it is a precompiled function. I just know when I stop the program, it does not show me where I am. (I am using keil uVision 5).
    flash_init() is called in the main, juste after ble_stack_init(). fdsInitialized is set to true, but I all the example I read wrote it that way.
    I do not know about the sd_app_evt_wait() called after fdsInitialized is set to true. It was impliemented like this in the example I have. And since it works all the time exept at the very first start of the device, I guess it is not the problem cause.
    I did try to comment sd_app_evt_wait(), and I still have the same issue.
    However, you were right about FDS_EVT_INIT event --> result != NRF_SUCCESS
    So i just added this :
    case FDS_EVT_INIT:
    								#if defined(BOARD_PCA10056) || defined(BOARD_PCA10059)
    									m_light_changed(LIGHT_TOGGLE);
    					else{
    						fds_init();
    and the issue seems corrected.
    I might change a bit my code not to call fds_init in fds_evt_handler() but I think we have a solution.
    Thanks a lot.
    Best regards
  • False alarm.
    In fact it does not work. I guess I was in the 4th try.
    It looks like no event is ever generated by the softdevice once the fds_init() has been called.
  • This means that every ~4 times you reset the device, it works, and the FDS event handler is called with FDS_INIT status OK?
    Is there any way for me to reproduce this on a DK? Is it possible to zip the project and send it here?
    I see that FDS is used in the example:
    SDK4.1.0\examples\multiprotocol\ble_zigbee\ble_zigbee_dynamic_door_lock_nus without modifications.
    Can you please try one thing for me in the meantime:
    If you erase the chip completely (nrfjprog --eraseall), and then program the softdevice. Modify your application to not call storage_init(). Then run the application and read out the flash. You can use the command "nrfjprog --readcode my_flash_dump.hex", or the nRF Connect for Desktop --> Programmer application to get a visual representation. What I want to know is what kind of data, and mainly where it is stored.
    E.g. if I comment out storage_init() in the ble_zigbee_dynamic_door_lock_nus example, it looks like this:
    While if I include storage_init(), it looks like this:
    As you can see, the last page of the FDS pages is from 0x000F6000->0x000F6FFF. The reason it is not starting at the top of the flash is that in this case 9 pages of 0x1000 (4096) bytes is reserved.
    So can you check without storage_init() what the flash looks like? Where is the bottom green line near the top of the flash starting?
    BR,
    Edvin
  • And in case you haven't tried, erase the chip completely before you program anything on it. Perhaps there is some old flash content in the flash area
