app_uart_put
Hi everyone
I am using app_uart_put() method for sending data via UART. The problem is that when I send each byte I get each byte back to its event handler in APP_UART_DATA_READY state. I would like to get only received data on APP_UART_DATA_READY state. I will appreciate for help in advance.
    The APP_UART_DATA_READY is used to alert the application that data has been received and placed in the RX buffer.
    Are you performing a loopback test? Or, is your TX pin connected to your RX pin?
    If not, please elaborate on how you device is connected, and to what it is connected.
    Is it possible that the other device you are transmitting to is just transmitting anything it receives?
    Is your project based on any of the examples from the SDK? If so, which example, and what modifications have you made to it?
    Looking forward to resolving this issue together,
    Karl
  • Our ble module is connected to the cellular module via UART.  If I send the commands from RealTerm I get the following response (in this case ble module is disconnected):
    +CEREG=5
    OK
    +CHTTPCREATE="">http://xxxxxxxxx"
    +CHTTPCREATE: 0
    OK
    if the connect the same cellular modul on the ble module I get:
    AT+CEREG=5
    OK
    AT+CHTTPCREATE="http://xxxxxxxxx"
     +CHTTPCREATE: 0
    Why AT prefix is added in both commands, the same is true for other commands as well? The code for UART I copy/past from UART ble example for a peripheral unit.
    What do you mean when you are saying that the BLE module is disconnected? Is it not the nRF device you are sending UART commands from?
    The log you have provided does not tell me much. Which direction is the messages send, and how does the response differ from what you had expected?
    AT Commands are instructions used to control a modem, which by the looks of it is what you are trying to do. You can read an introduction to them here.
    From your original ticket, it seemed you had a problem with getting the UART peripheral to function properly. Is this no longer the case - is the UART behavior now as expected, and you have encountered new issues with the results of the commands sent over UART?
    Karl
  • It seems that I was a little bit quicker. We have the cellular module which can be connected via UART
    1) directly on PC
    or
    2) directly on nrf52811.
    In the first case, I send AT commands AT+CEREG=5 and AT+CHTTPCREATE="xxxxxxxxx" via PC on the cellular module. For this purpose, I used RealTerm and I got a response as shown in the previous post. In the second case, I try to send the same commands via UART from nrf52811 on the cellular module and I got a different response for the same commands. When the commands are sent via nrf52811 I get back on APP_UART_DATA_READY entire command as you can see from the previous post. Every time I get prefix AT. This is not true if the commands are sent via the RealTerm. Due to this fact, I suspect that app_uart_put() method maybe cause some problems.
    Thanks in advance
    Samo
  • Hello Samo,
    Thank you for clarifying.
    Do you have access to a logic analyzer, so that you may see what is happening on the UART pins?
    Is the behavior of the cellular modem as expected when you send the command from your RealTerm terminal?
    Could you share the code you have implemented for sending the UART commands from the nRF52811?
    How is your UART pins connected to the modem? Have you made sure that you have not enabled the loopback testing in the UART peripheral example?
    It sounds very strange to me that you are immediately receiving the same UART transmission that the device itself sent - so either it is in loopback, or the other device is deliberately sending the same command back again, which also would be unexpected.
    Karl
