6lowpan control with long range (extended scan and connect)
Hello there, I following the nRF IoT SDK getting started and after Connecting Devices to Router section I succeed in connecting devices to router.
After that, I edited the examples(clients) and my HCI host so that works with Coded PHY.
I can search my long range kit with HCI extended scan cmds. But after I type echo "connect xx:xx:xx:xx:xx:xx 1" .. to linux cmd, btmon says that it benefits from legacy scan and connection trials. How can I connect my devices to 6lowpan with a bt0 interface?  Any help will appreciated. Thanks in advance.
  • Hi, can you please post the full log output from btmon? Are you sure that the HCI controller is supporting the Bluetooth 5 spec, such as long range? Can you describe the HCI host hardware and software setup?
  • Hi again,
    On start-up, my btmon looks like this,
    @ MGMT Open: bluetoothd (privileged) version 1.14             {0x0001} 0.741114
    @ MGMT Open: btmon (privileged) version 1.14                  {0x0002} 0.741485
    = New Index: 00:00:00:00:00:00 (Primary,USB,hci0)               [hci0] 5.808338
    = Open Index: 00:00:00:00:00:00                                 [hci0] 5.809576
    < HCI Command: Reset (0x03|0x0003) plen 0                    #1 [hci0] 5.815632
    > HCI Event: Command Complete (0x0e) plen 4                  #2 [hci0] 5.817912
          Reset (0x03|0x0003) ncmd 1
            Status: Success (0x00)
    < HCI Command: Read Local Supported... (0x04|0x0003) plen 0  #3 [hci0] 5.818041
    > HCI Event: Command Complete (0x0e) plen 12                 #4 [hci0] 5.819972
          Read Local Supported Features (0x04|0x0003) ncmd 1
            Features: 0x00 0x00 0x00 0x00 0x60 0x00 0x00 0x00
              BR/EDR Not Supported
              LE Supported (Controller)
    < HCI Command: Read Local Version In.. (0x04|0x0001) plen 0  #5 [hci0] 5.820627
    > HCI Event: Command Complete (0x0e) plen 12                 #6 [hci0] 5.821901
          Read Local Version Information (0x04|0x0001) ncmd 1
            HCI version: Reserved (0x0b) - Revision 0 (0x0000)
            LMP version: Reserved (0x0b) - Subversion 65535 (0xffff)
            Manufacturer: The Linux Foundation (1521)
    < HCI Command: Read BD ADDR (0x04|0x0009) plen 0             #7 [hci0] 5.822577
    > HCI Event: Command Complete (0x0e) plen 10                 #8 [hci0] 5.823918
          Read BD ADDR (0x04|0x0009) ncmd 1
            Address: 00:00:00:00:00:00 (OUI 00-00-00)
    < HCI Command: LE Read Buffer Size (0x08|0x0002) plen 0      #9 [hci0] 5.827362
    > HCI Event: Command Complete (0x0e) plen 7                 #10 [hci0] 5.828924
          LE Read Buffer Size (0x08|0x0002) ncmd 1
            Data packet length: 251
            Num data packets: 19
    < HCI Command: LE Read Local Suppor.. (0x08|0x0003) plen 0  #11 [hci0] 5.830969
    > HCI Event: Command Complete (0x0e) plen 12                #12 [hci0] 5.831915
          LE Read Local Supported Features (0x08|0x0003) ncmd 1
            Features: 0xff 0x59 0x01 0x00 0x00 0x00 0x00 0x00
              LE Encryption
              Connection Parameter Request Procedure
              Extended Reject Indication
              Slave-initiated Features Exchange
              LE Ping
              LE Data Packet Length Extension
              LL Privacy
              Extended Scanner Filter Policies
              LE 2M PHY
              LE Coded PHY
              LE Extended Advertising
              Channel Selection Algorithm #2
              Minimum Number of Used Channels Procedure
    < HCI Command: LE Read Supported St.. (0x08|0x001c) plen 0  #13 [hci0] 5.832049
    > HCI Event: Command Complete (0x0e) plen 12                #14 [hci0] 5.833923
          LE Read Supported States (0x08|0x001c) ncmd 1
            States: 0x000003ffff3fffff
              Non-connectable Advertising State
              Scannable Advertising State
              Connectable Advertising State
              High Duty Cycle Directed Advertising State
              Passive Scanning State
              Active Scanning State
              Initiating State
                and Connection State (Master Role)
              Connection State (Slave Role)
                and Passive Scanning State
                and Active Scanning State
                and Initiating State
                and Connection State (Slave Role)
              Initiating State
                and Master Role & Master Role
              Low Duty Cycle Directed Advertising State
                and Master Role & Slave Role
                and Slave Role & Slave Role
              Initiating State
    < HCI Command: Read Local Supported.. (0x04|0x0002) plen 0  #15 [hci0] 5.834059
    > HCI Event: Command Complete (0x0e) plen 68                #16 [hci0] 5.835906
          Read Local Supported Commands (0x04|0x0002) ncmd 1
            Commands: 58 entries
              Disconnect (Octet 0 - Bit 5)
              Read Remote Version Information (Octet 2 - Bit 7)
              Set Event Mask (Octet 5 - Bit 6)
              Reset (Octet 5 - Bit 7)
              Read Transmit Power Level (Octet 10 - Bit 2)
              Read Local Version Information (Octet 14 - Bit 3)
              Read Local Supported Features (Octet 14 - Bit 5)
              Read BD ADDR (Octet 15 - Bit 1)
              Read RSSI (Octet 15 - Bit 5)
              Set Event Mask Page 2 (Octet 22 - Bit 2)
              LE Set Event Mask (Octet 25 - Bit 0)
              LE Read Buffer Size (Octet 25 - Bit 1)
              LE Read Local Supported Features (Octet 25 - Bit 2)
              LE Set Random Address (Octet 25 - Bit 4)
              LE Set Advertising Parameters (Octet 25 - Bit 5)
              LE Read Advertising Channel TX Power (Octet 25 - Bit 6)
              LE Set Advertising Data (Octet 25 - Bit 7)
              LE Set Scan Response Data (Octet 26 - Bit 0)
              LE Set Advertise Enable (Octet 26 - Bit 1)
              LE Set Scan Parameters (Octet 26 - Bit 2)
              LE Set Scan Enable (Octet 26 - Bit 3)
              LE Create Connection (Octet 26 - Bit 4)
              LE Create Connection Cancel (Octet 26 - Bit 5)
              LE Read White List Size (Octet 26 - Bit 6)
              LE Clear White List (Octet 26 - Bit 7)
              LE Add Device To White List (Octet 27 - Bit 0)
              LE Remove Device From White List (Octet 27 - Bit 1)
              LE Connection Update (Octet 27 - Bit 2)
              LE Set Host Channel Classification (Octet 27 - Bit 3)
              LE Read Channel Map (Octet 27 - Bit 4)
              LE Read Remote Used Features (Octet 27 - Bit 5)
              LE Encrypt (Octet 27 - Bit 6)
              LE Rand (Octet 27 - Bit 7)
              LE Start Encryption (Octet 28 - Bit 0)
              LE Long Term Key Request Reply (Octet 28 - Bit 1)
              LE Long Term Key Request Neg Reply (Octet 28 - Bit 2)
              LE Read Supported States (Octet 28 - Bit 3)
              Read Authenticated Payload Timeout (Octet 32 - Bit 4)
              Write Authenticated Payload Timeout (Octet 32 - Bit 5)
              LE Remote Connection Parameter Request Reply (Octet 33 - Bit 4)
              LE Remote Connection Parameter Request Negative Reply (Octet 33 - Bit 5)
              LE Set Data Length (Octet 33 - Bit 6)
              LE Read Suggested Default Data Length (Octet 33 - Bit 7)
              LE Write Suggested Default Data Length (Octet 34 - Bit 0)
              LE Add Device To Resolving List (Octet 34 - Bit 3)
              LE Remove Device From Resolving List (Octet 34 - Bit 4)
              LE Clear Resolving List (Octet 34 - Bit 5)
              LE Read Resolving List Size (Octet 34 - Bit 6)
              LE Read Peer Resolvable Address (Octet 34 - Bit 7)
              LE Read Local Resolvable Address (Octet 35 - Bit 0)
              LE Set Address Resolution Enable (Octet 35 - Bit 1)
              LE Set Resolvable Private Address Timeout (Octet 35 - Bit 2)
              LE Read Maximum Data Length (Octet 35 - Bit 3)
              LE Read PHY (Octet 35 - Bit 4)
              LE Set Default PHY (Octet 35 - Bit 5)
              LE Set PHY (Octet 35 - Bit 6)
              LE Read Transmit Power (Octet 38 - Bit 7)
              LE Set Privacy Mode (Octet 39 - Bit 2)
    < HCI Command: Set Event Mask (0x03|0x0001) plen 8          #17 [hci0] 5.836495
            Mask: 0x200080000204e890
              Disconnection Complete
              Encryption Change
              Read Remote Version Information Complete
              Command Complete
              Command Status
              Hardware Error
              Number of Completed Packets
              Data Buffer Overflow
              Encryption Key Refresh Complete
              LE Meta
    > HCI Event: Command Complete (0x0e) plen 4                 #18 [hci0] 5.838913
          Set Event Mask (0x03|0x0001) ncmd 1
    < HCI Command: LE Set Event Mask (0x08|0x0001) plen 8       #19 [hci0] 5.839087
            Mask: 0x00000000000a0c7f
              LE Connection Complete
              LE Advertising Report
              LE Connection Update Complete
              LE Read Remote Used Features Complete
              LE Data Length Change
              LE Direct Advertising Report
              LE PHY Update Complete
              LE Extended Advertising Set Terminated
              LE Channel Selection Algorithm
    > HCI Event: Command Complete (0x0e) plen 4                 #20 [hci0] 5.840963
          LE Set Event Mask (0x08|0x0001) ncmd 1
    < HCI Command: LE Read White List S.. (0x08|0x000f) plen 0  #21 [hci0] 5.841962
    > HCI Event: Command Complete (0x0e) plen 5                 #22 [hci0] 5.842905
          LE Read White List Size (0x08|0x000f) ncmd 1
    < HCI Command: LE Clear White List (0x08|0x0010) plen 0     #23 [hci0] 5.843152
    > HCI Event: Command Complete (0x0e) plen 4                 #24 [hci0] 5.844907
          LE Clear White List (0x08|0x0010) ncmd 1
    < HCI Command: LE Read Resolving Li.. (0x08|0x002a) plen 0  #25 [hci0] 5.845056
    > HCI Event: Command Complete (0x0e) plen 5                 #26 [hci0] 5.846015
          LE Read Resolving List Size (0x08|0x002a) ncmd 1
    < HCI Command: LE Clear Resolving L.. (0x08|0x0029) plen 0  #27 [hci0] 5.846114
    > HCI Event: Command Complete (0x0e) plen 4                 #28 [hci0] 5.847907
          LE Clear Resolving List (0x08|0x0029) ncmd 1
    < HCI Command: LE Read Maximum Data.. (0x08|0x002f) plen 0  #29 [hci0] 5.848452
    > HCI Event: Command Complete (0x0e) plen 12                #30 [hci0] 5.849899
          LE Read Maximum Data Length (0x08|0x002f) ncmd 1
            Max TX octets: 251
            Max TX time: 17040
            Max RX octets: 251
            Max RX time: 17040
    < HCI Command: LE Read Suggested De.. (0x08|0x0023) plen 0  #31 [hci0] 5.850001
    > HCI Event: Command Complete (0x0e) plen 8                 #32 [hci0] 5.850910
          LE Read Suggested Default Data Length (0x08|0x0023) ncmd 1
            TX octets: 27
            TX time: 328
    < HCI Command: LE Read Number of Su.. (0x08|0x003b) plen 0  #33 [hci0] 5.851042
    > HCI Event: Command Complete (0x0e) plen 5                 #34 [hci0] 5.853906
          LE Read Number of Supported Advertising Sets (0x08|0x003b) ncmd 1
            Num supported adv sets: 1
    < HCI Command: Set Event Mask Page 2 (0x03|0x0063) plen 8   #35 [hci0] 5.854065
            Mask: 0x0000000000800000
              Authenticated Payload Timeout Expired
    > HCI Event: Command Complete (0x0e) plen 4                 #36 [hci0] 5.855933
          Set Event Mask Page 2 (0x03|0x0063) ncmd 1
    < HCI Command: LE Write Suggested D.. (0x08|0x0024) plen 4  #37 [hci0] 5.856019
            TX octets: 251
            TX time: 17040
    > HCI Event: Command Complete (0x0e) plen 4                 #38 [hci0] 5.856896
          LE Write Suggested Default Data Length (0x08|0x0024) ncmd 1
    < HCI Command: LE Set Default PHY (0x08|0x0031) plen 3      #39 [hci0] 5.856972
            All PHYs preference: 0x00
            TX PHYs preference: 0x01
              LE 1M
            RX PHYs preference: 0x01
              LE 1M
    > HCI Event: Command Complete (0x0e) plen 4                 #40 [hci0] 5.858901
          LE Set Default PHY (0x08|0x0031) ncmd 1
    = Index Info: 00:00:00:00:00:00 (The Linux Foundation)          [hci0] 5.859451
    = Close Index: 00:00:00:00:00:00                                [hci0] 5.859664
    @ MGMT Event: Index Added (0x0004) plen 0              {0x0002} [hci0] 5.859773
    @ MGMT Event: Index Added (0x0004) plen 0              {0x0001} [hci0] 5.859773
    @ MGMT Command: Read Controller Inf.. (0x0004) plen 0  {0x0001} [hci0] 5.860057
    @ MGMT Event: Command Complete (0x0001) plen 283       {0x0001} [hci0] 5.860085
          Read Controller Information (0x0004) plen 280
            Version: Reserved (0x0b)
            Supported settings: 0x0001be1b
              Powered
              Connectable
              Discoverable
              Bondable
              Low Energy
              Advertising
              Secure Connections
              Debug Keys
              Privacy
              Static Address
              PHY Configuration
            Current settings: 0x00000200
              Low Energy
            Class: 0x000000
              Major class: Miscellaneous
              Minor class: 0x00
            Name:
            Short name:
    = bluetoothd: RFCOMM server failed for Headset Voice gateway: rfco..   5.868812
    @ MGMT Command: Remove UUID (0x0011) plen 16           {0x0001} [hci0] 5.896415
            UUID: 00000000-0000-0000-0000-000000000000
    @ MGMT Event: Command Complete (0x0001) plen 6         {0x0001} [hci0] 5.896456
          Remove UUID (0x0011) plen 3
            Class: 0x000000
              Minor class: 0x00
    @ MGMT Command: Remove Device (0x0034) plen 7          {0x0001} [hci0] 5.896704
            BR/EDR Address: 00:00:00:00:00:00 (OUI 00-00-00)
    @ MGMT Event: Command Complete (0x0001) plen 10        {0x0001} [hci0] 5.896820
    @ MGMT Command: Set Static Address (0x002b) plen 6     {0x0001} [hci0] 5.897025
            Address: E4:FB:38:EB:85:BE (Static)
    @ MGMT Event: Command Complete (0x0001) plen 7         {0x0001} [hci0] 5.897040
          Set Static Address (0x002b) plen 4
            Current settings: 0x00008200
              Low Energy
              Static Address
    @ MGMT Event: New Settings (0x0006) plen 4             {0x0002} [hci0] 5.897052
              Low Energy
              Static Address
    @ MGMT Command: Set Secure Connecti.. (0x002d) plen 1  {0x0001} [hci0] 5.897194
            Secure Connections: Enabled (0x01)
    @ MGMT Event: Command Complete (0x0001) plen 7         {0x0001} [hci0] 5.897567
          Set Secure Connections (0x002d) plen 4
            Current settings: 0x00008a00
              Low Energy
              Secure Connections
              Static Address
    @ MGMT Event: New Settings (0x0006) plen 4             {0x0002} [hci0] 5.897582
              Low Energy
              Secure Connections
              Static Address
    @ MGMT Command: Set Privacy (0x002f) plen 17           {0x0001} [hci0] 5.897803
            Privacy: Disabled (0x00)
            Key: 00000000000000000000000000000000
    @ MGMT Event: Command Complete (0x0001) plen 7         {0x0001} [hci0] 5.897821
          Set Privacy (0x002f) plen 4
              Low Energy
              Secure Connections
              Static Address
    @ MGMT Command: Set Bondable (0x0009) plen 1           {0x0001} [hci0] 5.898052
            Bondable: Enabled (0x01)
    @ MGMT Event: Command Complete (0x0001) plen 7         {0x0001} [hci0] 5.898066
          Set Bondable (0x0009) plen 4
            Current settings: 0x00008a10
              Bondable
              Low Energy
              Secure Connections
              Static Address
    @ MGMT Event: New Settings (0x0006) plen 4             {0x0002} [hci0] 5.898077
              Bondable
              Low Energy
              Secure Connections
              Static Address
    @ MGMT Command: Set IO Capability (0x0018) plen 1      {0x0001} [hci0] 5.898340
            Capability: KeyboardDisplay (0x04)
    @ MGMT Event: Command Complete (0x0001) plen 3         {0x0001} [hci0] 5.898355
          Set IO Capability (0x0018) plen 0
    @ MGMT Command: Add UUID (0x0010) plen 17              {0x0001} [hci0] 5.898583
            UUID: 00001800-0000-1000-8000-00805f9b34fb
            Service class: 0x00
    @ MGMT Event: Command Complete (0x0001) plen 6         {0x0001} [hci0] 5.898601
          Add UUID (0x0010) plen 3
            Class: 0x000000
              Minor class: 0x00
    @ MGMT Command: Add UUID (0x0010) plen 17              {0x0001} [hci0] 5.898844
            UUID: 00001801-0000-1000-8000-00805f9b34fb
            Service class: 0x00
    @ MGMT Event: Command Complete (0x0001) plen 6         {0x0001} [hci0] 5.899029
            Class: 0x000000
              Minor class: 0x00
    @ MGMT Command: Read Advertising Fe.. (0x003d) plen 0  {0x0001} [hci0] 5.899859
    @ MGMT Event: Command Complete (0x0001) plen 11        {0x0001} [hci0] 5.899927
          Read Advertising Features (0x003d) plen 8
            Flags: 0x000003ff
              Switch into Connectable mode
              Advertise as Discoverable
              Advertise as Limited Discoverable
              Add Flags field to Advertising Data
              Add TX Power field to Advertising Data
              Add Appearance field to Scan Response
              Add Local Name in Scan Response
              Advertise in 1M on Secondary channel
              Advertise in 2M on Secondary channel
              Advertise in CODED on Secondary channel
            Advertising data length: 31
            Scan response length: 31
            Max instances: 5
            Instances: 0
    @ MGMT Command: Set Powered (0x0005) plen 1            {0x0001} [hci0] 5.900114
            Powered: Enabled (0x01)
    = Open Index: 00:00:00:00:00:00                                 [hci0] 5.900552
    < HCI Command: Reset (0x03|0x0003) plen 0                   #41 [hci0] 5.901181
    > HCI Event: Command Complete (0x0e) plen 4                 #42 [hci0] 5.903911
    < HCI Command: Read Local Supported.. (0x04|0x0003) plen 0  #43 [hci0] 5.905454
    > HCI Event: Command Complete (0x0e) plen 12                #44 [hci0] 5.906934
    < HCI Command: Read Local Version I.. (0x04|0x0001) plen 0  #45 [hci0] 5.907071
    @ RAW Open: bluealsa (privileged) version 2.22                {0x0003} 5.907806
    @ RAW Close: bluealsa                                         {0x0003} 5.907861
    > HCI Event: Command Complete (0x0e) plen 12                #46 [hci0] 5.907913
    < HCI Command: Read BD ADDR (0x04|0x0009) plen 0            #47 [hci0] 5.909232
    > HCI Event: Command Complete (0x0e) plen 10                #48 [hci0] 5.909935
    < HCI Command: LE Read Buffer Size (0x08|0x0002) plen 0     #49 [hci0] 5.910540
    > HCI Event: Command Complete (0x0e) plen 7                 #50 [hci0] 5.911932
    < HCI Command: LE Read Local Suppor.. (0x08|0x0003) plen 0  #51 [hci0] 5.912467
    > HCI Event: Command Complete (0x0e) plen 12                #52 [hci0] 5.913912
              LE Encryption
              LE Ping
              LL Privacy
              LE 2M PHY
              LE Coded PHY
    < HCI Command: LE Read Supported St.. (0x08|0x001c) plen 0  #53 [hci0] 5.917665
    > HCI Event: Command Complete (0x0e) plen 12                #54 [hci0] 5.918907
              Initiating State
              Initiating State
              Initiating State
    < HCI Command: Read Local Supported.. (0x04|0x0002) plen 0  #55 [hci0] 5.918999
    > HCI Event: Command Complete (0x0e) plen 68                #56 [hci0] 5.921899
    < HCI Command: Set Event Mask (0x03|0x0001) plen 8          #57 [hci0] 5.922080
              Encryption Change
              Command Complete
              Command Status
              Hardware Error
              LE Meta
    > HCI Event: Command Complete (0x0e) plen 4                 #58 [hci0] 5.922921
    < HCI Command: LE Set Event Mask (0x08|0x0001) plen 8       #59 [hci0] 5.923048
    > HCI Event: Command Complete (0x0e) plen 4                 #60 [hci0] 5.924992
    < HCI Command: LE Read White List S.. (0x08|0x000f) plen 0  #61 [hci0] 5.925068
    > HCI Event: Command Complete (0x0e) plen 5                 #62 [hci0] 5.926901
    < HCI Command: LE Clear White List (0x08|0x0010) plen 0     #63 [hci0] 5.927005
    > HCI Event: Command Complete (0x0e) plen 4                 #64 [hci0] 5.927902
    < HCI Command: LE Read Resolving Li.. (0x08|0x002a) plen 0  #65 [hci0] 5.927983
    > HCI Event: Command Complete (0x0e) plen 5                 #66 [hci0] 5.929915
    < HCI Command: LE Clear Resolving L.. (0x08|0x0029) plen 0  #67 [hci0] 5.932649
    > HCI Event: Command Complete (0x0e) plen 4                 #68 [hci0] 5.933914
    < HCI Command: LE Read Maximum Data.. (0x08|0x002f) plen 0  #69 [hci0] 5.934045
    > HCI Event: Command Complete (0x0e) plen 12                #70 [hci0] 5.935905
            Max TX octets: 251
            Max TX time: 17040
            Max RX octets: 251
            Max RX time: 17040
    < HCI Command: LE Read Suggested De.. (0x08|0x0023) plen 0  #71 [hci0] 5.936024
    > HCI Event: Command Complete (0x0e) plen 8                 #72 [hci0] 5.937944
            TX octets: 27
            TX time: 328
    < HCI Command: LE Read Number of Su.. (0x08|0x003b) plen 0  #73 [hci0] 5.938072
    > HCI Event: Command Complete (0x0e) plen 5                 #74 [hci0] 5.939899
    < HCI Command: Set Event Mask Page 2 (0x03|0x0063) plen 8   #75 [hci0] 5.940168
    > HCI Event: Command Complete (0x0e) plen 4                 #76 [hci0] 5.941903
    < HCI Command: LE Write Suggested D.. (0x08|0x0024) plen 4  #77 [hci0] 5.942012
            TX octets: 251
            TX time: 17040
    > HCI Event: Command Complete (0x0e) plen 4                 #78 [hci0] 5.942901
    < HCI Command: LE Set Default PHY (0x08|0x0031) plen 3      #79 [hci0] 5.942984
              LE 1M
              LE 1M
    > HCI Event: Command Complete (0x0e) plen 4                 #80 [hci0] 5.944919
    = Index Info: 00:00:00:00:00:00 (The Linux Foundation)          [hci0] 5.945156
    < HCI Command: LE Set Extended Adv.. (0x08|0x0036) plen 25  #81 [hci0] 5.945372
            Handle: 0x00
            Properties: 0x0010
              Use legacy advertising PDUs: ADV_NONCONN_IND
            Min advertising interval: 1280.000 msec (0x0800)
            Max advertising interval: 1280.000 msec (0x0800)
            Channel map: 37, 38, 39 (0x07)
            Own address type: Random (0x01)
            Peer address type: Public (0x00)
            Peer address: 00:00:00:00:00:00 (OUI 00-00-00)
            Filter policy: Allow Scan Request from Any, Allow Connect Request from Any (0x00)
            TX power: 127 dbm (0x7f)
            Primary PHY: LE 1M (0x01)
            Secondary max skip: 0x00
            Secondary PHY: LE 1M (0x01)
            SID: 0x00
            Scan request notifications: Disabled (0x00)
    > HCI Event: Command Complete (0x0e) plen 5                 #82 [hci0] 5.946945
          LE Set Extended Advertising Parameters (0x08|0x0036) ncmd 1
            TX power (selected): 127 dbm (0x7f)
    < HCI Command: LE Set Advertising S.. (0x08|0x0035) plen 7  #83 [hci0] 5.947057
            Advertising handle: 0x00
            Advertising random address: 16:CF:2D:27:C9:39 (OUI 16-CF-2D)
    > HCI Event: Command Complete (0x0e) plen 4                 #84 [hci0] 5.947905
          LE Set Advertising Set Random Address (0x08|0x0035) ncmd 1
    < HCI Command: LE Set Extended Adv.. (0x08|0x0037) plen 35  #85 [hci0] 5.948018
            Handle: 0x00
            Operation: Complete extended advertising data (0x03)
            Fragment preference: Minimize fragmentation (0x01)
            Data length: 0x03
            Flags: 0x04
    @ MGMT Event: Command Complete (0x0001) plen 7         {0x0001} [hci0] 5.948083
          Set Powered (0x0005) plen 4
            Current settings: 0x00008a11
              Powered
              Bondable
              Low Energy
              Secure Connections
              Static Address
    @ MGMT Event: New Settings (0x0006) plen 4             {0x0002} [hci0] 5.948098
              Powered
              Bondable
              Low Energy
              Secure Connections
              Static Address
    > HCI Event: Command Complete (0x0e) plen 4                 #86 [hci0] 5.949917
          LE Set Extended Advertising Data (0x08|0x0037) ncmd 1
    @ MGMT Command: Set Local Name (0x000f) plen 260       {0x0001} [hci0] 5.978181
            Short name:
    = bluetoothd: Failed to set local name: Failed (0x03)           [hci0] 5.984446
    @ MGMT Command: Add UUID (0x0010) plen 17              {0x0001} [hci0] 5.978495
            UUID: 0000110e-0000-1000-8000-00805f9b34fb
            Service class: 0x00
    @ MGMT Event: Command Complete (0x0001) plen 6         {0x0001} [hci0] 5.978517
            Class: 0x000000
              Minor class: 0x00
    @ MGMT Command: Add UUID (0x0010) plen 17              {0x0001} [hci0] 5.978694
            UUID: 0000110c-0000-1000-8000-00805f9b34fb
            Service class: 0x00
    @ MGMT Event: Command Complete (0x0001) plen 6         {0x0001} [hci0] 5.978708
            Class: 0x000000
              Minor class: 0x00
    @ MGMT Command: Add UUID (0x0010) plen 17              {0x0001} [hci0] 5.978857
            UUID: 00001112-0000-1000-8000-00805f9b34fb
            Service class: 0x00
    @ MGMT Event: Command Complete (0x0001) plen 6         {0x0001} [hci0] 5.978872
            Class: 0x000000
              Minor class: 0x00
    @ MGMT Command: Add UUID (0x0010) plen 17              {0x0001} [hci0] 5.979014
            UUID: 0000111f-0000-1000-8000-00805f9b34fb
            Service class: 0x40
    @ MGMT Event: Command Complete (0x0001) plen 6         {0x0001} [hci0] 5.979028
            Class: 0x000000
              Minor class: 0x00
    @ MGMT Command: Add UUID (0x0010) plen 17              {0x0001} [hci0] 5.979168
            UUID: 00001108-0000-1000-8000-00805f9b34fb
            Service class: 0x00
    @ MGMT Event: Command Complete (0x0001) plen 6         {0x0001} [hci0] 5.979181
            Class: 0x000000
              Minor class: 0x00
    @ MGMT Command: Unblock Device (0x0027) plen 7         {0x0001} [hci0] 5.979323
    @ MGMT Event: Device Unblocked (0x0015) plen 7         {0x0002} [hci0] 5.979336
    @ MGMT Event: Command Complete (0x0001) plen 10        {0x0001} [hci0] 5.979361
    @ MGMT Command: Load Long Term Keys (0x0013) plen 2    {0x0001} [hci0] 5.979498
            Keys: 0
    @ MGMT Event: Command Complete (0x0001) plen 3         {0x0001} [hci0] 5.979511
          Load Long Term Keys (0x0013) plen 0
    @ MGMT Command: Load Identity Resol.. (0x0030) plen 2  {0x0001} [hci0] 5.979645
            Keys: 0
    @ MGMT Event: Command Complete (0x0001) plen 3         {0x0001} [hci0] 5.979661
          Load Identity Resolving Keys (0x0030) plen 0
    @ MGMT Command: Load Connection Par.. (0x0035) plen 2  {0x0001} [hci0] 5.979794
            Parameters: 0
    @ MGMT Event: Command Complete (0x0001) plen 3         {0x0001} [hci0] 5.979807
          Load Connection Parameters (0x0035) plen 0
    @ MGMT Command: Add UUID (0x0010) plen 17              {0x0001} [hci0] 5.979936
            UUID: 00001200-0000-1000-8000-00805f9b34fb
            Service class: 0x00
    @ MGMT Event: Command Complete (0x0001) plen 6         {0x0001} [hci0] 5.979949
            Class: 0x000000
              Minor class: 0x00
    @ MGMT Command: Set Device ID (0x0028) plen 8          {0x0001} [hci0] 5.980086
            Device ID: USB Implementer's Forum assigned (0x0002)
              Vendor: Linux Foundation (0x1d6b)
              Product: 0x0246
              Version: 5.3.6 (0x0536)
    @ MGMT Event: Command Complete (0x0001) plen 3         {0x0001} [hci0] 5.980104
          Set Device ID (0x0028) plen 0
    @ MGMT Command: Set Local Name (0x000f) plen 260       {0x0001} [hci0] 5.980235
            Short name:
    @ MGMT Event: Command Complete (0x0001) plen 263       {0x0001} [hci0] 5.980252
            Short name:
    = bluetoothd: Endpoint registered: sender=:1.23 path=/MediaEndpoin..   5.992581
    = bluetoothd: Endpoint registered: sender=:1.23 path=/MediaEndpoin..   5.992646
    = bluetoothd: Endpoint registered: sender=:1.7 path=/org/bluez/hci..   5.992774
    @ MGMT Command: Add UUID (0x0010) plen 17              {0x0001} [hci0] 5.983761
            UUID: 0000110a-0000-1000-8000-00805f9b34fb
            Service class: 0x08
    @ MGMT Event: Command Complete (0x0001) plen 6         {0x0001} [hci0] 5.983800
            Class: 0x000000
              Minor class: 0x00
    @ MGMT Command: Add UUID (0x0010) plen 17              {0x0001} [hci0] 5.984047
            UUID: 0000110b-0000-1000-8000-00805f9b34fb
            Service class: 0x04
    @ MGMT Event: Command Complete (0x0001) plen 6         {0x0001} [hci0] 5.984067
            Class: 0x000000
              Minor class: 0x00
    = bluetoothd: Endpoint registered: sender=:1.7 path=/org/bluez/hci..   6.011124
    @ RAW Open: hciconfig (privileged) version 2.22               {0x0003} 6.122053
    @ RAW Close: hciconfig                                        {0x0003} 6.122160
    @ RAW Open: hciconfig (privileged) version 2.22               {0x0003} 6.130207
    After that, I use some hci commands so that change PHY to Coded (0x04).
    hcitool cmd 0x08 0x0032 0x00 0x0 0x03 0x04 0x04 0x04 0x04
    < HCI Command: LE Set PHY (0x08|0x0032) plen 7             #53 [hci0] 18.607004
            Handle: 0
            All PHYs preference: 0x03
              No TX PHY preference
              No RX PHY preference
            TX PHYs preference: 0x04
              LE Coded
            RX PHYs preference: 0x04
              LE Coded
            PHY options preference: S8 CODED (0x0002)
    > HCI Event: Command Status (0x0f) plen 4                  #54 [hci0] 18.607710
          LE Set PHY (0x08|0x0032) ncmd 1
    @ RAW Close: hcitool                                  {0x0003} [hci0] 18.607940
    Set LE Extended Scan: hcitool cmd 0x08 0x0041 0x01 0x00 0x04 , btmon output of that code:
    < HCI Command: LE Set Extended Scan.. (0x08|0x0041) plen 3  #1 [hci0] 14.508034
            Filter policy: Accept all advertisement (0x00)
            PHYs: 0x04
            Entry 0: LE Coded
              Type: Reserved (0x02)
              Interval: 13.750 msec (0x0016)
              Window: 0.625 msec (0x0001)
    > HCI Event: Command Complete (0x0e) plen 4                 #2 [hci0] 14.510764
          LE Set Extended Scan Parameters (0x08|0x0041) ncmd 1
    @ RAW Close: hcitool                                  {0x0003} [hci0] 14.510916
    But all of those routines done via extended parameters. (I succeed on connecting after all).
    With 6lowpan controlling: for example commanded echo "connect 00:AA:BB:CC:DD:EE 1" > /sys/kernel/debug/bluetooth/6lowpan_control, btmon output looks like this:
    < HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7   #1 [hci0] 1.735299
            Type: Passive (0x00)
            Interval: 60.000 msec (0x0060)
            Window: 30.000 msec (0x0030)
            Filter policy: Ignore not in white list (0x01)
    > HCI Event: Command Complete (0x0e) plen 4                  #2 [hci0] 1.736202
          LE Set Scan Parameters (0x08|0x000b) ncmd 1
            Status: Command Disallowed (0x0c)
    @ MGMT Event: Connect Failed (0x000d) plen 8           {0x0002} [hci0] 1.736278
            LE Address: 00:AA:BB:CC:DD:EE (OUI 00-AA-BB)
            Status: Busy (0x0a)
    @ MGMT Event: Connect Failed (0x000d) plen 8           {0x0001} [hci0] 1.736278
            Status: Busy (0x0a)
    < HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7   #3 [hci0] 1.830396
    > HCI Event: Command Complete (0x0e) plen 4                  #4 [hci0] 1.831209
    As you can see, this command benefits from legacy scanning and connection, not extended. As a result of this, I cannot connect my devices 6lowpan via Coded Long-Range PHY:
    HCI Controller: NRF52840 Dongle or DK
    HCI Software: Zephyr HCI-USB Controller
