NRF_LOG_HEXDUMP_* raises Data Access Violation Fault if a large buffer is used
Hi to all,
I have found that using SDK17.0.0 on NRF52832, whenever I try to use NRF_LOG_HEXDUMP_DEBUG for a large buffer (more than a 1000 elements), I get a Data Access Violation Fault.
I understand that since the NRF_LOG is deferred and my buffer is allocated in stack, I can get the buffer pointer to be corrupted.
Aware of that, after calling the NRF_LOG_HEXDUMP_DEBUG I call the NRF_LOG_FINAL_FLUSH, in order to fully flush the logs.
I have also changed the NRF_LOG_BUFSIZE to 4096, in order to fully store my buffer (1800 bytes)
I have also noticed that the output of my calls to NRF_LOG_HEXDUMP_DEBUG are capped at 80 bytes (8 columns x 10 rows), even if the buffer contains more data and and the length argument of the NRF_LOG_HEXDUMP_DEBUG call is more than 80 bytes.
Below is a code snippet. I have tried to dump the buffer immediately after creation (even if it is all zeroes), just to remove the possibility of errors in functions that manipulate the buffer contents. Still getting Data Access Violation Fault.
uint8_t cert_buffer[1800] = {0};
NRF_LOG_HEXDUMP_INFO(cert_buffer, 1800);
NRF_LOG_FINAL_FLUSH();
Am I missing something or is this a bug? Can anyone reproduce this behavior?
Thanks in advance,
Pedro
  • Thank you for the quick response, .
    Please ping me when you have news.
    Pedro
  • Hi Pedro
    He did some experiments trying to increase the NRF_LOG_MSGPOOL_ELEMENT_COUNT parameter in sdk_config.h.
    First he tested with 40 which seemed to work fine, but increasing it much beyond this didn't seem to provide stable results.
    In order to print 1800 bytes you would need to set this parameter to 90, but this doesn't seem to work properly, there is still some other limit somewhere preventing all the bytes from being written.
    Could you try to change this value as well and see how it affect the output?
    Best regards
    Torbjørn
  • Hi @ovrebekk,
    Some updates from my side.
    I have created a simple project which uses the sdk_configs.h I shared. It has a main loop that only dumps the buffer. The buffer is still being declared inside main, so, its allocated on the stack, as in the previous tests.
    I have tried with different values of NRF_LOG_MSGPOOL_ELEMENT_COUNT. Below is a summary
    NRF_LOG_MSGPOOL_ELEMENT_COUNT Bytes printed Error received
    8 80 Non-Maskable Interrupt
    16 104 Non-Maskable Interrupt.
    32 208 Data Access Violation escalates to Hard Fault
    40 280 Data Access Violation escalates to Hard Fault
    64 384 Data Access Violation escalates to Hard Fault
    90 512 Data Access Violation escalates to Hard Fault
    128 464 Data Access Violation escalates to Hard Fault
    A screenshot of the call stack in one of the cases:
    Also, during my tests, I noticed that the Data Access Violation occurs because, somehow, the flushing of the logs attempts to access addresses that are impossible, like 0x616E696D (value when NRF_LOG_MSGPOOL_ELEMENT_COUNT = 128).
    I couldn't duplicate. My tests always cause some erroneous condition that prevents me from printing the buffer.
    Can you please analyze the data above? I think I narrowed it down to the flushing of the logs, but I am not sure yet if the problem resides on the NRF_LOG module or the backend module the NRF_LOG uses to flush the logs...
  • Hi
    The developer found a workaround by writing the data in smaller chunks, and flushing the buffers in between.
    He used the following configuration:
    NRF_LOG_MSGPOOL_ELEMENT_SIZE 20
    NRF_LOG_MSGPOOL_ELEMENT_COUNT 110
    NRF_LOG_BUFSIZE 4096
    and then he wrote the buffer like this:
    for (int i = 0; i < 1800; i += 600)
        NRF_LOG_HEXDUMP_INFO(cert_buffer + i, 600);
        NRF_LOG_FLUSH();
    Can you give this a go and see if it works better?
    It's also important to note that the NRF_LOG_FINAL_FLUSH() function should not be used in normal operation. This one is only meant to be used inside error handlers (running in interrupt context). Please use NRF_LOG_FLUSH() instead.
    Best regards
    Torbjørn
  • Hi ,
    It works better. I am able to print 135 lines, with 8 bytes each. So I get 1080 bytes from the 1800 bytes.
    Please note one thing. I am aware that I can create workarounds to fully print the entire certificate (1800 bytes), by printing it in steps or by dumping the variable contents to file through a debugger.
    On this issue I would like the discussion not be focused on getting workaround. Instead, I would prefer to address these two things:
    1. Why NRF_LOG_HEXDUMP_* prints less bytes than requested and does not output any error messages
    2. Why, when an error message is received, is a hardly recoverable Data Access Violation. Are there no verification steps inside NRF_LOG_HEXDUMP_* ?
    To my awareness, there are also no documented size limitations of the NRF_LOG_HEXDUMP_*.
    Can you please address the two topics above? If you need more debug data/help from my side, please advice.
