I am following the below link for creating custom services/characteristics.
https://github.com/bjornspockeli/nRF52-Bluetooth-Course
Now I am adding the second characteristic in that service but unable to see in the nRF app.
I have added 2nd custom_value_char_add_2 function for 2nd characteristics.
uint32_t err_code;
ble_gatts_char_md_t char_md;
ble_gatts_attr_md_t cccd_md;
ble_gatts_attr_t attr_char_value;
ble_uuid_t ble_uuid;
ble_gatts_attr_md_t attr_md;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read = 1;
char_md.char_props.write = 1;
char_md.char_props.notify = 0;
char_md.p_char_user_desc = NULL;
char_md.p_char_pf = NULL;
char_md.p_user_desc_md = NULL;
char_md.p_cccd_md = NULL;
char_md.p_sccd_md = NULL;
memset(&attr_md, 0, sizeof(attr_md));
attr_md.read_perm = p_cus_init->custom_value_char_attr_md.read_perm;
attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm;
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 0;
attr_md.wr_auth = 0;
attr_md.vlen = 0;
/* This code belongs in custom_value_char_add() in ble_cus.c*/
ble_uuid.type = p_cus->uuid_type;
ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID;
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid = &ble_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len = sizeof(uint8_t);
attr_char_value.init_offs = 0;
attr_char_value.max_len = sizeof(uint8_t);
err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md,
&attr_char_value,
&p_cus->custom_value_handles);
if (err_code != NRF_SUCCESS)
return err_code;
return NRF_SUCCESS;
And also call this function in ble_cus_init.
uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
if (p_cus == NULL || p_cus_init == NULL)
return NRF_ERROR_NULL;
uint32_t err_code;
// Initialize service structure
p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
// Add Custom Service UUID
ble_uuid128_t base_uuid = {CUSTOM_SERVICE_UUID_BASE};
err_code = sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type);
VERIFY_SUCCESS(err_code);
ble_uuid.uuid = CUSTOM_SERVICE_UUID;
// Add the Custom Service
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle);
return err_code;
// Add Custom Value characteristic
return custom_value_char_add(p_cus, p_cus_init);
return custom_value_char_add_2(p_cus, p_cus_init);
/* This code belongs in ble_cus.c*/
#include "sdk_common.h"
#include "ble_srv_common.h"
#include "ble_cus.h"
#include <string.h>
#include "nrf_gpio.h"
#include "boards.h"
#include "nrf_log.h"
/**@brief Function for initializing the Custom Service.
* @param[out] p_cus Custom Service structure. This structure will have to be supplied by
* the application. It will be initialized by this function, and will later
* be used to identify this particular service instance.
* @param[in] p_cus_init Information needed to initialize the service.
* @return NRF_SUCCESS on successful initialization of service, otherwise an error code.
uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init);
uint32_t custom_value_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init);
uint32_t custom_value_char_add_2(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init);
void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context);
uint32_t err_code;
return err_code;
/**@brief Function for adding the Custom Value characteristic.
* @param[in] p_cus Custom Service structure.
* @return NRF_SUCCESS on success, otherwise an error code.
uint32_t err_code;
attr_md.vlen = 0;
&attr_char_value,
return err_code;
return NRF_SUCCESS;
uint32_t err_code;
attr_md.vlen = 0;
&attr_char_value,
return err_code;
return NRF_SUCCESS;
/**@brief Function for handling the Connect event.
* @param[in] p_ble_evt Event received from the BLE stack.
void on_connect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
/**@brief Function for handling the Disconnect event.
void on_disconnect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
UNUSED_PARAMETER(p_ble_evt);
/**@brief Function for handling the Write event.
void on_write(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
ble_gatts_evt_write_t *p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
// Check if the handle passed with the event matches the Custom Value Characteristic handle.
if (p_evt_write->handle == p_cus->custom_value_handles.value_handle)
NRF_LOG_INFO("Data Write");
nrf_gpio_pin_toggle(LED_4);
ble_cus_t * p_cus = (ble_cus_t *) p_context;
if (p_cus == NULL || p_ble_evt == NULL)
return;
case BLE_GAP_EVT_CONNECTED:
on_connect(p_cus, p_ble_evt);
on_disconnect(p_cus, p_ble_evt);
case BLE_GATTS_EVT_WRITE:
on_write(p_cus, p_ble_evt);
// No implementation needed.
