Build Issue on nRF52840 : error: nrfx.h: No such file or directory
I am trying to develop an application on nRF52840 development kit board. When I am trying to build I am getting below error "nrfx.h: No such file or directory".
For your information, I am using SEGGER Embedded Studio IDE on Windows. I have checked out nRF-Connect code from https://github.com/nrfconnect
Please let me know the fix for this build issue?
Kalyan
ERROR:
Rebuilding ‘D:/Projects/SmartWristBand/git/sdk-zephyr/misc/empty_file.c’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘D:/Projects/SmartWristBand/git/sdk-zephyr/include/dt-bindings/gpio/gpio.h’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘D:/Projects/SmartWristBand/git/sdk-zephyr/include/dt-bindings/i2c/i2c.h’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/misc/generated/struct_tags.json’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/misc/generated/struct_tags.json’
Rebuilding ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/CMakeFiles/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/parse_syscalls_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/driver-validation.h’
Rebuilding ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/kobj-types-enum.h’
Rebuilding ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/syscall_list.h’
Rebuilding ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Rebuilding ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
1> Compiling ‘offsets.c’
1> In file included from ../../../../include/arch/arm/aarch32/cortex_m/cmsis.h:17,
1>                  from ../../../../include/arch/arm/aarch32/cortex_m/mpu/arm_mpu_v7m.h:10,
1>                  from ../../../../include/arch/arm/aarch32/cortex_m/mpu/arm_mpu.h:13,
1>                  from ../../../../include/arch/arm/aarch32/arch.h:185,
1>                  from ../../../../include/arch/cpu.h:19,
1>                  from ../../../../include/kernel_includes.h:38,
1>                  from ../../../../include/kernel.h:17,
1>                  from D:/Projects/SmartWristBand/git/sdk-zephyr/arch/arm/core/offsets/offsets_aarch32.c:28,
1>                  from D:/Projects/SmartWristBand/git/sdk-zephyr/arch/arm/core/offsets/offsets.c:12:
1> ../../../../soc/arm/nordic_nrf/nrf52/soc.h:16:10: fatal error: nrfx.h: No such file or directory
1> compilation terminated.
Build failed
