My aim is on button press in peripheral side ,it should do advertise and sent data from single peripheral to multiple central(total two central).
I am using nrf52810 ,soft device 132, code used ble_app_uart(peripheral),be_app_uart_c(central).
I am able to make connection between one peripheral and two central but not able to send the data.When i press the button advertisement is starting and connection have been done but not able to receive data on central side.
The changes that i have done for sending data and for making central connection with peripheral are below :
main.c
static void led_status_send_to_button(uint8_t key)
ret_code_t err_code;
// uint8_t key = '1';
ble_conn_state_conn_handle_list_t conn_handles = ble_conn_state_periph_handles();
// printf("in led\r\n");
//printf("led_status_send_to_button | conn_handles.len=%d\r\n",conn_handles.len);
for (uint8_t i = 0; i < conn_handles.len; i++)
printf("Iteration-%d\r\n",i);
//nrf_delay_ms(2000);
// printf("led_status_send_to_button | calling...ble_nus_data_send(key=%c)\r\n",key);
err_code = ble_nus_data_send(&m_nus,&key,&length,conn_handles.conn_handles[i]);
printf("led_status_send_to_button | called...ble_nus_data_send(key) %c\r\n",key);
// if(err_code != BLE_ERROR_INVALID_CONN_HANDLE)
if ((err_code != NRF_SUCCESS) &&
(err_code != BLE_ERROR_INVALID_CONN_HANDLE) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING))
printf("Error\r\n");
// NRF_LOG_DEBUG("Sent button change 0x%x on connection handle 0x%x.", ke, conn_handles.conn_handles[i]);
return NRF_SUCCESS;
/**@brief Function for handling the Connected event.
* @param[in] p_gap_evt GAP event received from the BLE stack.
static void on_connected(const ble_gap_evt_t * const p_gap_evt)
periph_link_cnt = ble_conn_state_peripheral_conn_count(); // Number of peripheral links.
NRF_LOG_INFO("Connection with link 0x%x established.", p_gap_evt->conn_handle);
// Assign connection handle to available instance of QWR module.
for (uint32_t i = 0; i < NRF_SDH_BLE_PERIPHERAL_LINK_COUNT; i++)
if (m_qwrs[i].conn_handle == BLE_CONN_HANDLE_INVALID)
err_code = nrf_ble_qwr_conn_handle_assign(&m_qwrs[i], p_gap_evt->conn_handle);
// Update LEDs
bsp_board_led_on(CONNECTED_LED);
if (periph_link_cnt == NRF_SDH_BLE_PERIPHERAL_LINK_COUNT)
bsp_board_led_off(ADVERTISING_LED);
// Continue advertising. More connections can be established because the maximum link count has not been reached.
advertising_start();
nrf_delay_ms(1000);
led_status_send_to_button(key);
uint32_t err_code;
if (periph_link_cnt == 0 && advt_val == false)
advt_val = true;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
case BSP_EVENT_KEY_0 :
uint8_t key = '1';
case BSP_EVENT_KEY_1 :
key = '2';
if (advt_val == false)
// printf("do nothing\r\n");
// printf("send key = %c\r\n",key);
Is there is any problem in my code or i am missing something for sending the data ? Any suggestion is appreciable.
