Encryption in data
Hi Team,
we are working on nrf52 and we doing encryption of the data.
on the receiver end I can understand if there is connection , the keys will be exchanged and after that the receiver can decode advertisement packets.
But I would like to know that without connection is there possibility to decodethe advertisements on receiver end as we are planning to send some advertisement with information which can be read by receiver without connection
Could there be way by which the receiver can decode this encrypted advertisement.
  • surely, the method by which the encrypted data is transported is irrelevant to how you decrypt it?
    What @awneil is referring to here is the fact that if you intend to encrypt data, send it, and then decrypt it then it does not matter much how you transport that data - i.e the fact that you are doing this through advertisements does not matter for how you may go about encrypting the data, as long as both sender and receiver knows what to expect from these transfers.
    If I may ask, have you considered using a connection with LESC in stead of advertising encrypted data here? This way, the encryption will be taken care of for you by the SoftDevice.
    Please keep in mind that when you are using advertisements you have no guarantee that the receiver has actually gotten the messages - so if you are transferring important data, then you may loose some of it without knowing, when using advertisements to transport it.
    Please do not hesitate to let me know if I should have misunderstood your question, or if anything still should be unclear.
    Karl
  • Hi
    Thank you for response.
    Yes, correctly understood,
    but here some advertisement (without connection ) if gets dropped or non received by receiver , that is still ok.
    its good suggestion to use LESC but on the receiver end how to handle decoding,?
    Could you point to any example, document or reference.
    No problem at all, I am happy to help!
    Thank you for confirming this.
    Luckily, the SoftDevice ( if it is an nRF device ) or BLE stack in the other end take care of this for you, no need for you to do anything in regards to the encryption.
    You may see this being done in the BLE Glucose monitor example application from the SDK.
    The example uses LESC with MITM protection. The example contains a lot of other functionality too, but the interesting parts for you to see is mainly the peer_manager_init, with regards to configuring LESC and security.
    Karl
