Hello
I have an interesting problem from the ble_app_uart example modified to work with spis.
ble_nus.c code
// Add the RX Characteristic.
memset(&add_char_params, 0, sizeof(add_char_params));
add_char_params.uuid = BLE_UUID_NUS_RX_CHARACTERISTIC;
add_char_params.uuid_type = p_nus->uuid_type;
add_char_params.max_len = BLE_NUS_MAX_RX_CHAR_LEN;
add_char_params.init_len = sizeof(uint8_t);
add_char_params.is_var_len = true;
add_char_params.char_props.write = 1;
add_char_params.char_props.write_wo_resp = 1;
add_char_params.char_props.notify = 1; /* TSP */
add_char_params.read_access = SEC_OPEN;
add_char_params.write_access = SEC_OPEN;
add_char_params.cccd_write_access = SEC_OPEN; /* TSP */
err_code = characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->rx_handles); /* TSP */
if (err_code != NRF_SUCCESS)
return err_code;
// Add the TX Characteristic.
/**@snippet [Adding proprietary characteristic to the SoftDevice] */
add_char_params.uuid = BLE_UUID_NUS_TX_CHARACTERISTIC;
add_char_params.max_len = BLE_NUS_MAX_TX_CHAR_LEN;
return characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->tx_handles); /* TSP */
In the ble_nus.c code (above) I modified to enable notifications (both on RX and TX characteristic) from the peripheral (nRF device) side and because of these changes, I see the below (phone screenshots) on my nRF Connect app Attribute Table. But when I enable notifications on both characteristics, I do not see the data in my temp_ble_tx buffer (from my main.c { below } inside the spis event handler) which is what I need to see on my nRF Connect app. Anyone knows how to resolve this so I can see my data on the app?
void spis_event_handler(nrf_drv_spis_event_t event)
static uint8_t temp_ble_tx[BLE_NUS_MAX_DATA_LEN];
uint32_t err_code;
if (event.evt_type == NRF_DRV_SPIS_XFER_DONE)
spis_xfer_done = true;
strcat((char *)temp_ble_tx, (char *)m_rx_buf); /* TSP */
err_code = ble_nus_data_send(&m_nus, temp_ble_tx, &length, m_conn_handle);
RX characteristic properties : Write, Write w/o Response , Notify
TX characteristic properties : Notify
