Bluetooth functionality with nRF5 IoT SDK - is it limited?
I made a demo app using advertising and scanning functionality in SDK 16. Now I'm trying to get it working in our company's full blown C++ framework, which is based on SDK for Thread and Zigbee 4.1.0.
With practically the same code, advertising works but scanning does not, nrf_ble_scan_start() gives an error 6.
Are the normal and Thread SDK:s different in this sense? Does Thread SDK give full Bluetooth functionality or not?
Chip is 52840, soft devices ones with aforementioned sdk:s.
    Applications running on the nRF SoC can only use one radio protocol at a time, and therefore you have to implement a way to use multiple. This can be done by either using switched multiprotocol or dynamic multiprotocol. You can read more about multiprotocol support with BLE and the two different types here. Note that switched multiprotocol is only supported for Thread, and not for Zigbee.
    We do already have some multiprotocol examples, so I would recommend you take a look at how this is implemented there. If you want to use Thread and BLE, you can find the examples here, both switched multiprotocol and dynamic multiprotocol. For Zigbee you should look here.
    So to conclude, the SDKs are a bit different, but both have support for BLE. The difference is that you're using multiple radio protocols at the same time, which requires some extra implementation.
    Marte
