SAADC + EasyDMA + timer
Is there an example that shows the "Nordic way" of "continuous" conversions using DMA? I think a timer and PPI are needed to generate a conversion task for each timer compare event?
Also, the SAADC END (of EasyDMA transfers for a conversion round) event is still available for interrupt?
I didn't find library support for ADC with DMA.
The idea is to let timer to trig several "rounds" of multi-channel conversions that DMA would store in a buffer. After pre-defined number of rounds a new buffer is taken into use by the N:th SAADC END interrupt, and the old buffer is used for further calculations.
    Additionally, you can check out how things are done in this github repository - please not that the NordicPlayground repositories are just intended as simple demos, and are not as thoroughly tested as our SDK examples.
    The saadc peripheral uses easyDMA, by extension so does the nrfx_saadc and nrfx_saadc2 drivers.
    No, the END event is not part of the nrfx_saadc driver - this is only available to the driver itself, or in the SAADC HAL.
    I would advice against mixing from both SAADC HAL and the nrfx driver, as this may place the driver in an invalid state.
    I would also recommend using the driver instead of implementing the functionality yourself from HAL - since a lot of this work is already done for you in the driver.
    If you want to do continuous sampling you should use the double buffering feature, and instead do your data processing once one buffer fills up - generating the DONE event.
    Please do not hesitate to ask if anything should be unclear, or if you should encounter any issues or questions!
    Karl
  • Hmm, the nRF52832 data sheet says:
    "The EasyDMA will have finished accessing the RAM when the END or STOPPED event has been generated."
    and
    "EVENTS_DONE 0x108 A conversion task has been completed. Depending on the mode, multiple conversions might be
    needed for a result to be transferred to RAM."
    I guess this means that EVENTS_DONE signals that the last conversion is done, but the results are not yet read from the registers to memory?
  • Also, does timer always generate interrupts internally? I was hoping to set the HW up such that timer compare just trigs an ADC scan (conversion of 4 channels) with DMA, and I only get an interrupt (event) after the DMA is finished, to start the next timer compare (and ADC scan).
  • BTW, if I try to look into the SAADC V2 driverAPI, I get:
    HTTP ERROR: 404
    Problem accessing /help/drivers/include/nrfx_saadc_v2.h. Reason:
        ProxyServlet: /help/drivers/include/nrfx_saadc_v2.h
  • Aha, the driver's interrupt routine checks the actual event, and if it's END, the interrupt routine calls the callback function with DONE-event.
