I want to quickly send up to 100KB of data to a connected smartphone and then disconnect to save battery.
I have most of this working using the NUS service but today I noticed ble_nus_data_send() takes a pointer (uint16_t * p_length) as a parameter, this is the number of bytes to send and also the number of bytes sent. The example doesn't check this value at all.
Should I check *p_length immediately after calling the ble_nus_data_send() function? It's not obvious if *p_length is updated asynchronously or not.
the ble_nus_data_send() calls down to sd_ble_gatts_hvx but there is no source available to look at.
At the moment my main loop looks like this (simplified)
for (;;)
if (can_send)
int expected = length;
err_code = ble_nus_data_send(&m_nus, data_p, &length, conn_handle);
if (expected != lenght)
//log error and explode
can_send = false;
idle_state_handle();
in NUS event handler
if (p_evt->type == BLE_NUS_EVT_TX_RDY)
can_send = true;
I send BLE_NUS_MAX_DATA_LEN bytes per call.
If *p_length is less than requested then what should I do?
To give an example, If I call ble_nus_data_send() with *p_length = 240 and after the call I see *p_length == 100, should I wait to get BLE_NUS_EVT_TX_RDY and then send the remaining 140 bytes again?
Is there a substantially faster way to send the data instead of using the NUS service?
My connection parameters are
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS) //The central decides anyway
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) // These comply with apple guidelines
#define SLAVE_LATENCY 30
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)
Any help is appreciated,
-Jason
