app_timer2 assert by APP_TIMER_SAFE_WINDOW
There was an app timer immediate expiration issue with my project which is using nrf52840 + SDK 15.3.0 on custom board.
So I changed apptimer code to app timer2 like the issue post below.
https://devzone.nordicsemi.com/f/nordic-q-a/62406/app-timer-sometimes-expires-immediately
Recently, I've enbled nrf assert to catch unknow issues and then an assert happens like below. (booting -> leave the device for a while)
In "components/libraries/timer/app_timer2.c":
        ASSERT(app_timer_cnt_diff_compute(drv_rtc_counter_get(p_instance),
                                          mp_active_timer->end_val & RTC_COUNTER_COUNTER_Msk) < APP_TIMER_SAFE_WINDOW);
The settings I am using :
#define APP_TIMER_SAFE_WINDOW_MS 300000
#define APP_TIMER_CONFIG_RTC_FREQUENCY 0  // <0=> 32768 Hz
The device sleep time could be maximum 48 hours but usually, 1 hour but 24bit counter just have around 8~9 minutes and it will be reset.
I guess app_timer_cnt_diff_compute with 24-bit mask seems not to fit this long time timer.
Can I ignore that assert or any other suggestions?
Thank you.
    Yes, this is correct - as can be seen in the APP_TIMER_SAFE_WINDOW_MS documentation - the APP_TIMER_SAFE_WINDOW_MS is the maximum value that the app_timer_cnt_diff_compute is allowed to return. With your 24 bit counter width and 32768 Hz frequency you have a potential maximum of 512000 ms. Since this is > your APP_TIMER_SAFE_WINDOW_MS, it asserts.
    How high resolution do you need on this 48 hour wakeup? If you reduce your RTC frequency you can avoid waking up so often as every 9th minute.
    Is there a particular reason for having the app timer configured to 32 kHz?
    Karl
  • Thank you for supporting
    -> It doesn't need to be so accurate but I am using the apptimer rtc counter as the OS system tick as well so it should be high resolution.
    -> it's for system tick.
    I know I can use apptimer for sleep/wakeup and other rtc for system tick and I've tried that but there was another issue by using apptimer for sleep/wakeup and using other rtc for system tick. so if possible, I want to keep using apptimer for both sleep/wakeup timer and rtc counter as system tick.
    so still I need the app_timer_cnt_diff_compute code for any other reasons?
    No problem at all, I am happy to help!
    Thank you for clarifying.
    Well, this depends on what sleep mode you are intending to use. If you are in SYSTEM_OFF mode ( lowest possible power consumption ) then you will need an external interrupt to wake up.
    If possible, I would highly recommend this, if your device is only going to wake up every 48 Hour - it would save a lot of power, to stay in SYSTEM_OFF for those 48 hours, rather than a low power SYSTEM ON state ( with timers running ).
    I do not quite understand this question, you have not shown me any code in which you use app_timer_cnt_diff_compute.
    If you are asking if you can ignore the assert for the size of APP_TIMER_SAFE_WINDOW, then I must say that you can, but I would advise against it if you plan on using any app_timer for any other purpose.
    Altering of any driver might break it in unforeseen ways.
    Karl
  • Thank you for your answer.
    I am using system_on since I've check power mode at the beginning of this project that it's not available to use rtc wake up with system off mode.
    And the 48 hours is just a maximum case. For example, the device wakes up hourly checking significant data and it wakes up every 24 or 48 hours for non-significant data. Also, it can wake up any interrupt of some sensors any time. so the timeout for the app timer is various.
    I meant the code in my original post.
    -> Do you mean multiple uses of the app timer? I am using the app timer for device wakeup and sensor response timeout also nrf_serial driver also using but I haven't got any issue.
    I guess ignoring the assert probably should be fine but you are just not sure 100% if it'll be OK in any case, am I correct?
  • One more thing, I think this assert can happen even with a small timeout if you use 32k because the app timer2 supports 64 bit rtc counter and the end_val is 64 bit and it will be bit masked of 24 bit in app_timer_cnt_diff_compute and the diff could be larger than APP_TIMER_SAFE_WINDOW. But I guess the reason why apptimer2 supports 64 bits rtc counter is to be able to calculate the counter even with 32K. Then the assert code seems not so meaningful in this case.
    Sorry for my late reply.
    I seems I have made a mistake here, my apologies - I provided the wrong link and inaccurate information in my initial reply.
    I will update the initial reply with the correct reference and information.
    In essence, the APP_TIMER_SAFE_WINDOW_MS is actually used to set the maximum latency for handling of app_timer events. Since the RTC will keep ticking regardless of the events tied to it, there might be tasks that require handling within a certain time to ensure proper operation.
    Sorry for the inaccurate information earlier, I must have misread which define you were asking about.
    An exempt from the APP_TIMER_SAFE_WINDOW_MS documentation reads:
    Maximum possible timeout that can be set is reduced by safe window. Example: RTC frequency 16384 Hz, maximum possible timeout 1024 seconds - APP_TIMER_SAFE_WINDOW_MS. Since RTC is not stopped when processor is halted in debugging session, this value must cover it if debugging is needed. It is possible to halt processor for APP_TIMER_SAFE_WINDOW_MS without corrupting app_timer behavior.
    The exempt above also explains the assert you are seeing.
    There is a note attached to the assert states that the safe window should be increased if this assert fails.
    You are correct; you may not use the RTC to wake up from SYSTEM OFF - that would require an external interrupt.
    Again, I am sorry for any confusion this might have caused.
    Karl
    So I fixed this with #define APP_TIMER_SAFE_WINDOW_MS 512000 to avoid the assert.
  • Reply Children
