Sending SAADC data via ble_nus_data_send
I am trying to send data obtained from a SAADC port via BLE using the ble_nus_data_send function. This must happen periodically at frequencies within the Gigahertz range, ideally.
I started with the ble_app_uart example, from SDK16. Then, I initialized a timer using PPI to trigger an SAADC sampling event, such as in the saadc example.
Inside the saadc_callback function, I process the data and call the ble_nus_data_send function, as seen bellow:
        ret_code_t err_code;
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        saadc2ble_convert();
        uint16_t length = (uint16_t)UART_TX_BUF_SIZE;
        err_code = ble_nus_data_send(&m_nus, adc_output, &length, m_conn_handle);
the saadc2ble_convert function simply converts the data from uint16_t to uint8_t and the length of the data transmitted via ble_nus_data_send function has not been modified from the initial example:
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define SAMPLES_IN_BUFFER  UART_TX_BUF_SIZE/2
static nrf_saadc_value_t adc_buf[SAMPLES_IN_BUFFER];                   //!< Buffer used for storing ADC value.
static uint8_t          adc_output[UART_TX_BUF_SIZE]; //!< Current battery level.
void saadc2ble_convert(){
   int i;
   for(i=0; i<SAMPLES_IN_BUFFER; i++){
       adc_output[i*2] = adc_buf[i] & 0xff;
       adc_output[i*2 + 1] = (adc_buf[i] >> 8) & 0xff;
I initialize all in the main function as seen in the next code block:
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    saadc_init();
    saadc_sampling_event_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
Debugging, I see that the SAADC is reading data well, however, I couldn't get any data at the smartphone.
I am getting the error shown on the image:
Could anyone help me to find a way to solve this problem?
  • I got an error message when attaching the code in my sdk_config.h file to this post, so I uploaded the file to the link bellow:
    5736.sdk_config.h
    and this is the main function:
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        saadc_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        // Enter main loop.
        for (;;)
  • Both the main function and sdk_config seems all right.
    Could you try to use an RTT terminal, like J-Link RTT Viewer, to see the RTT outputs?
    You should see the message "Debug logging for UART over RTT started." when the application starts.
    If you are not able to see this, could you try to run an unmodified version of the ble_app_uart from the SDK, to see if this yields the proper output to the RTT terminal?
    From the earlier screenshots I assume you are developing on a nRF52840 DK, could you confirm this? If so, could you tell me how you have connected the board to your computer, and what the switches on the boards are set to?
    I just want to rule out some common errors.
    Looking forward to resolving this issue together,
    Karl
  • Hello, Karl.
    I am using a SEGGER J-Link EDU Mini to connect with my board. The exact DK I am using is the one shown in this link:
    MDBT50Q-DB-40
    I tried using RTT viewer. But I don't see any message. However, if I use the function SEGGER_RTT_WriteString() I can see messages both in the RTT terminal and on the debug terminal in SEGGER embedded Studio.
    All the issues discussed above happen when I run the ble_app_uart (unmodified) example from SDK16. The example runs perfectly (I can interchange messages between UART port in the DK and the smartphone app). But, when I switch to SDK15, and run the same example (ble_app_uart, unmodified), I can see all the debugging messages. On the other hand, I can send data from the Android application (NRF Connect) to the UART port, but I cannot send data from the UART port to the smartphone anymore.
  • Hello, Karl
    I downgraded to the SDK15 repeated the fusion of the two examples. I basically copied all the functions from the saadc example into the ble_app_uart. As I mentioned before, I just included my saadc2ble_convert
       int i;
           adc_output[i*2] = m_buffer_pool[i] & 0xff;
           adc_output[i*2 + 1] = (m_buffer_pool[i] >> 8) & 0xff;
    and made a few changes to the saadc_callback
            if(m_conn_handle != BLE_CONN_HANDLE_INVALID){
                if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) && (err_code != NRF_ERROR_NOT_FOUND))
                    char error_message[20];
                    sprintf(error_message, "Error code: %x", err_code);
                    SEGGER_RTT_WriteString(0, error_message);
    The main function is like this:
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        saadc_init();
        // Start execution.
        // Enter main loop.
        for (;;)
    I run the debug and the nrf_Connect app and when I enable notifications, the code goes into a breakpoint. But now because I moved to SDK15, as I mentioned earlier, I can see the debug messages as you see bellow:
    The content of the debug terminal is shown here in detail:
    <info> app: Allocated channel: 0.
    <info> app: Function: nrfx_ppi_channel_alloc, error code: NRF_SUCCESS.
    <info> app: Assigned channel: 0, event end point: 4000A140, task end point: 40007004.
    <info> app: Function: nrfx_ppi_channel_assign, error code: NRF_SUCCESS.
    <info> app: Debug logging for UART over RTT started.
    <info> app: Function: nrfx_ppi_channel_enable, error code: NRF_SUCCESS.
    <info> app: Connected
    <info> app: Data len is set to 0xF4(244)
    Error code: 0Error code: 0Error code: 0<error> app: ERROR 19 [NRF_ERROR_RESOURCES] at C:\Users\MBIS\Documents\Thiago\Projects\BCC Project\BLE Projects\nRF5_SDK_Current\examples\ble_peripheral\ble_app_uart - Copy\main.c:777
    PC at: 0x0002A7D1
    <error> app: End of error report
    It sounds very weird to me that you are not able to see the RTT outputs on the unmodified example from the SDK v16.
    Could you check to see that this line is defined to 0 in your sdk_config?
    #ifndef NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED
    #define NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 0
    This might mess up your RTT outputs, if it is defined to 1.
    Are you saying that you are no longer able to see the messages you are sending to your device through UART, on your connected device?
    If I may ask, why are you modifying your "adc_output" buffer with the contents of your buffer pool? I suspect that the naming here is just a bit ambiguous, but I am asking just in case.
    Great, this is very helpful!
    I do not know what is on your line 777 of main.c, but I suspect that it is the call to ble_nus_data_send. If this is the case, then the sd_ble_gatts_hvx is returning NRF_ERROR_RESOURCES because you are trying to queue too many notifications.
    You need to make sure that you are not queueing notifications faster than you are sending them.
    How often are you filling the SAADC buffer, what is your connection interval, MTU size and notification queue size?
    Knowing these things, we may take a look at the different options for solving this issue.
    Karl
