Example for using S120 as peripheral?
currently I am using the S110 Softdevice with the ble_template example as peripheral. This works fine.
For our final application, we need the central feature with up to 8 connected peripherals. Therfor I want to use the S120 softdevice. At the moment I use the ble_app_hrs_c_s120 example for learning how to use the S120 softdevice. But in this application, the device only acts a a central. Is there an example, how to configure the S120 softdevice as an peripheral?
Additional an example of how to do dynamic switching between central and peripheral would be helpful.
Thanks in advance!
Regards BTprogrammer
  • I have modified ble_beacon example for S120 to be a simple connectable advertiser. you can use master control panel to connect to this app. you can find the zip file attached in my answer to this post. I have tested this with S120 softdevice that came with SDK8.x
  • Hello Aryan,
    I tried to compile and use your modified "beacon" example. If I try to compile your project directly, I get a few error messages: ......\main.c(25): error: #5: cannot open source input file "ble_advdata.h": No such file or directory "no source": Error: #5: cannot open source input file "..........\bsp\bsp.c": No such file or directory "no source": Error: #5: cannot open source input file "............\components\ble\common\ble_advdata.c": No such file or directory ... For me this looks like some missing/incorrect Paths. But I dont know how to set the right source Paths. I also tried to compile it in a comletly new project with the PACKS comming from the SDK. But there I only can select the S110 softdevice. With that configuration there is no gap_enable_params.role field in ble_enable_params. Do you have any additional recommendations?
  • Hello Aryan,
