What happened to SDK 7.0.0
It is no longer available for download.
I assume some problem was discovered, so it should not be used any longer, at all?
Any help appreciated
    Do you mean v17.0.0 ? If yes, then this is explained in the release notes for SDK v17.0.2. See this link.
  • Is this specific name change described in the release notes strictly necessary, as it would seem "old" (ie currently used) projects only require .xml to match .emProject and any name would in fact work:
    To use old projects in combination with this version of the SDK (MDK),
    make the following updates:
    1. In the flash_placement.xml file:
       MemorySegment name must be changed from "RAM" to "RAM1":
       <MemorySegment name="RAM1" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)">
    2. In the .emProject file:
       In "linker_section_placements_segments" you must refer to "RAM1", replacing "RAM":
       linker_section_placements_segments="FLASH RX 0x0 0x100000;RAM1 RWX 0x20000000 0x40000"
    Edit: ok I see why:
    #ifndef STACK_INIT_VAL
    #define STACK_INIT_VAL __RAM_segment_end__
  • Sigurd,
    So: If I use sdk V17.0.0, I have to implement the steps described.
    (A lot of steps)
    but
    If I use sdk V7.0.2 I do not have to, since the bugs were fixed?
    or
    Do I still need to implement the steps, described her
    https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_nrf5_v17.0.2%2Findex.html
    I have a project up and runnign seemingly fine, with sdk V7.0.2 and no changes, as described in the steps
  • Sigurd,
    Don't worry, looks like I have the answer.
    I did make those changes in the flash_placement.xml and .emProject files, and ym older project compiles.
    Regards
