UART Rx issue in MCU power 1.8V
Hi
I am now working on a project which I use ble_app_uart_c as a reference.
SDK 16 and used softdevice s140.
UART works normally at 3.3V.
But if I lower the power by 1.8V, it can be UART TX but not RX.
The 1.8V TX signal is working well from the hardware, but the signal won't work if you just connect the RX Pin.
If I connect the RX Pin and send the TX signal, I can see the signal shaking a little.
So I added the following code to the main beginning.
    if ((NRF_UICR->REGOUT0 & UICR_REGOUT0_VOUT_Msk) != UICR_REGOUT0_VOUT_1V8)
        NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos;
        while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
        NRF_UICR->REGOUT0 = (NRF_UICR->REGOUT0 & ~((uint32_t)UICR_REGOUT0_VOUT_Msk)) |
                            (UICR_REGOUT0_VOUT_1V8 << UICR_REGOUT0_VOUT_Pos);
        NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
        NVIC_SystemReset();
But it didn't work. Is there a UART setting part?
I need your help.
