ble_nus_data_send is returning NRF_ERROR_RESOURCES.
ble_nus_data_send is returning NRF_ERROR_RESOURCES. I would like to increase the Tx Queue size, but as it is not straight forward to increase by changing the macro BLE_GATTS_HVN_TX_QUEUE_SIZE_DEFAULT. I would like to know what are the other things i need to change along with this macro.
Also I tried waiting for the TX_RDY_EVT after receiving the nrf-error-resources. sometimes that even is not at all happening and it si get stuck there forever. Please suggest me on what can be done in such a case step by step
    I suspect that you have already seen the reason for this error in the functions API Reference documentation, but I mention it here just in case. The NRF_ERROR_RESOURCES is caused by queueing too many notifications.
    To remedy this, you could indeed increase the queue size like you suggest - but you should also verify that you are not attempting to send far more notifications than your connection parameters will allow for.
    If you would like to increase the queue size, please see the answer by my colleague Sigurd in this ticket.
    Are you saying that you never receive a BLE_GATTS_EVT_HVN_TX_COMPLETE event?
    If so, have you made sure that your event handler is registered as an observer to the BLE events?
    Is your event handler receiving other BLE events - or have you created a separate handler for this?
    If you could share how you have implemented this, that would be very helpful.
    Looking forward to resolving this issue together!
    Karl
  • Thanks for the quick response. I will check the resources shared.
    From the Sigurd ticket: I see the following code snippet:
    ble_cfg_t ble_cfg;
    memset(&ble_cfg, 0, sizeof ble_cfg);
    ble_cfg.conn_cfg.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
    ble_cfg.conn_cfg.params.gatts_conn_cfg.hvn_tx_queue_size = 50;
    err_code = sd_ble_cfg_set(BLE_CONN_CFG_GATTS, &ble_cfg, ram_start);
    what is the functionality of this and is this required for peripheral devices or for central or both?
    To clarify you on TX_RDY_EVT related queries:
    Yes, we are saying BLE_GATTS_EVT_HVN_TX_COMPLETE event.
    yes, we have registered as an observer.
    yes, we are receiving other events. even this BLE_GATTS_EVT_HVN_TX_COMPLETE  event happens but sometimes it stuck there indefinitely.
    I will refer the other resources and come back.
  • Punithkumar said:
    In case of no NRF_ERROR_RESOURCES, it simply submits the buffer and return; else it sets the flag gsErrResources = 1; and wait for an event and checks if this flag has become zero, if not it tries to submit again and waits for an event  nrf_pwr_mgmt_run(). The flag gsErrResources becomes zero when the TX_COMPLETE event get raised.
    This works, but some of the time it indefinitely get stuck here and gsErrResources = 1 always. and no TX_COMPLETE event is getting raised.
    Please suggest where could it go wrong and how can we debug this scenario.
    I am not sure that I can recommend the approach you are doing here. Have you verified that you are not generating new notifications faster than you could possible send them, like I asked earlier?
    What is generating your notifications, and how frequently are they being generated? What is your connection interval?
    What is the current size of your notification queue, params.gatts_conn_cfg.hvn_tx_queue_size?
    Punithkumar said:
    Currently we are not using this code snippet in our system ble-stack-init(), adding code snippet causing the system to hit NRF_BREAKPOINT_CONDITION. why could this be happening, what is the way to over come this?
    From your initial ticket I assumed that you have DEBUG defined in your preprocessror defines. Could you check that this is the case?
    It should look like the following image:
    If an error is passed to the APP_ERROR_CHECK with the DEBUG define set, then the error and its source will be written to the logger module.
    Karl
    Thanks for response. while trying to address the issue. I got the following doubt, please clarify:
    assume queue size(50 for example) for the following test :
    if I submit 10 data packets continuously one after the other making sure all the submission calls are returning success and  break that loop.
    Does it trigger TX_RDY_EVT, event for 10 times, assuming for each submission it triggers one TX_RDY_EVT.
    Because I am seeing the difference in these numbers sometime and not returning any error while submitting the data packet using ble_nus_data_send() API.
    Please suggest why the difference could come, if there are any.
    Please note that, in this test am not getting the NRF_ERROR_RESOURCES error from ble_nus_data_send() while submitting the data packet to be transferred. As I am making breaking the test once it hits the NRF_ERROR_RESOURCES.
    No problem at all, I am happy to help!
    I would not expect an NRF_ERROR_RESOURCES here, since you are only queueing 10 notifications, and you queue size is 50.
    Could you elaborate what the difference you are seeing here is?
    You should rather use the BLE_GATTS_EVT_HVN_TX_COMPLETE event to count how many notifications has been sent, as this is generated each time a notification transfer is finished, and contains the number of notifications sent.
    Karl
  • Hi Karl,
    Thanks for the reply.
    I was referring to the difference in the number of notification messages submitted and the number of TX_RDY_EVT triggered.
    When I say, TX_RDY_EVT, it is the same BLE_GATTS_EVT_HVN_TX_COMPLETE event interrupt I am referring to.
    we are seeing difference in the number of valid notification messages submitted using ble_nus_data_send() API and the number of times BLE_GATTS_EVT_HVN_TX_COMPLETE event interrupts getting triggered. I assume in ideal case both of them should be equal.
    Are there any possibilities which can lead to difference in these two?
    Yes, this is understood, but how much is this difference you are seeing, exactly? It is helpful if you could be as specific as possible, when describing behavior you are seeing during testing.
    Do you here mean the number of times you are seeing TX_RDY_EVT events, like you said in your previous comment?
    TX_RDY_EVT is not the same as BLE_GATTS_EVT_HVN_TX_COMPLETE.
    No, these are not the same events. One is to indicate that the service is ready to receive more notifications for sending, and the other one is for indicating that a notifications has been sent.
    I would recommend using the latter, because it is directly tied to how many notifications that is sent, while the READY can have multiple causes.
    Could you try this test with the BLE_GATTS_EVT_HVN_TX_COMPLETE event, instead of the TX_RDY_EVT? I think this is more suitable for the test you describe.
    Karl
    Karl
