Blinky non-secure sample not running
Hi
When programming /NordicSDK/v1.3.1/zephyr/samples/basic/blinky in the cpu_app_ns version, it will not start. It is starting when I compile it as a secure application. The sample is modified to monitor a gpio on my custom board:
 * Copyright (c) 2016 Intel Corporation
#include <zephyr.h>
#include <device.h>
#include <devicetree.h>
#include <drivers/gpio.h>
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS   100
/* The devicetree node identifier for the "led0" alias. */
#define LED0_NODE DT_ALIAS(led0)
#define LED1_NODE DT_ALIAS(led1)
#if DT_NODE_HAS_STATUS(LED0_NODE, okay)
#define LED0	DT_GPIO_LABEL(LED0_NODE, gpios)
#define PIN	DT_GPIO_PIN(LED0_NODE, gpios)
#if DT_PHA_HAS_CELL(LED0_NODE, gpios, flags)
#define FLAGS	DT_GPIO_FLAGS(LED0_NODE, gpios)
#else
/* A build error here means your board isn't set up to blink an LED. */
#error "Unsupported board: led0 devicetree alias is not defined"
#define LED0	""
#define PIN	0
#ifndef FLAGS
#define FLAGS	0
void main(void)
	struct device *dev;
    struct device *led_dev;
    bool led_is_on = true;
	int ret;
	dev = device_get_binding(LED0);
	if (dev == NULL) {
		return;
	ret = gpio_pin_configure(dev, PIN, GPIO_OUTPUT_ACTIVE | FLAGS);
	if (ret < 0) {
		return;
    led_dev = device_get_binding("GPIO_0");
    gpio_pin_configure(led_dev, 24, GPIO_OUTPUT);
    gpio_pin_set(led_dev, 24, 0);
	while (1) {
		gpio_pin_set(dev, PIN, (int)led_is_on);
        gpio_pin_set(led_dev, 24, (int)led_is_on);
		led_is_on = !led_is_on;
		k_msleep(SLEEP_TIME_MS);
I'm using nRF Connect SDK v1.3.1, and build the code with Segger IDE rel.4.52
Any idea why the ns version is not working?
