Data Transmission Fault
Hi there
I started with an empty ble_template and added my own custom service emulating the batterey service, with all the same functions etc. Using master emulator i can see the characteristic increasing and decreasing just like the batterey service.
My problem is that i wish i add another characteristic to this custom service. After defining and adding the characteristic to the stack i check with master emulator and i can now see both characteristics but the other one has stopped transmitting data and has become static.
Any thoughts?
function to handle data change (same in batteryservice.c) image description
function to update characteristic with value (same in hrs example main.c) image description
function for service init in main.c image description
sensor simulator image description
Thanks
Parents Reply
  • I have added the relevant code to the characteristic data update/change. I can upload code for the other characteristic structure and init if necessary? thanks
