Power consumption of ble_app_beacon and SPI
I'm trying to integrate an SPI slave into ble_app_beacon example. Power consumption of ble_app_beacon between advertising is up to 10 uA. But if I write a byte over SPI I immediately get idle power consumption up to 460 uA. Below is source code of the example. If line as_spi_write_reg (0x00,0x00); is commented out, power consumption is 10 uA. If the line is not commented out, 460 uA. How could I reset the power consumption back to 10 uA?
#include <stdbool.h>
#include <stdint.h>
#include "nordic_common.h"
//#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
//#include "nrf_spi_mngr.h"
#define APP_BLE_CONN_CFG_TAG            1                                  /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(5000, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE                 0x02                               /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI               0xC3                               /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER          0x0059                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE                 0x01, 0x02                         /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE                 0x03, 0x04                         /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                        0x45, 0x56, 0x67, 0x78, \
                                        0x89, 0x9a, 0xab, 0xbc, \
                                        0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
#define DEAD_BEEF                       0xDEADBEEF                         /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                 /**< Position of the MSB of the Major Value in m_beacon_info array. */
#define UICR_ADDRESS                    0x10001080                         /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
// SPI DEFINITIONS
#define SIZE_OF_SPI_BUF 20
static uint8_t       tx_spi_buf[SIZE_OF_SPI_BUF];           /**< TX buffer. */
static uint8_t       rx_spi_buf[SIZE_OF_SPI_BUF];    /**< RX buffer. */
//static const uint8_t m_length = SIZE_OF_BUF;        /**< Transfer length. */
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
#define SPI_SCK_PIN               26
#define SPI_MOSI_PIN              29
#define SPI_MISO_PIN              30
#define AS_SPI_CS                 31
// SPI FUNCTIONS
void as_spi_write_reg(uint8_t addr, uint8_t data)
   // Reset rx buffer and transfer done flag
   memset(rx_spi_buf, 0, SIZE_OF_SPI_BUF);
   spi_xfer_done = false;
   tx_spi_buf[0] = addr;
   tx_spi_buf[1] = data;
   nrf_gpio_pin_set(AS_SPI_CS);
   APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, tx_spi_buf, 2, rx_spi_buf, 0));
   while (!spi_xfer_done) __WFE();  //Wait For Event
   nrf_gpio_pin_clear(AS_SPI_CS);
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
// BLE FUNCTIONS
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = NULL,
        .len    = 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                         // implementation.
    APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                         // manufacturer specific data in this implementation.
    APP_BEACON_UUID,     // 128 bit UUID value.
    APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
    APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
    APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                         // this implementation.
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    uint32_t      err_code;
    ble_advdata_t advdata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    //m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
    m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration        = 0;       // Never time out.
    m_adv_params.scan_req_notification = 1;   //VLS
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
    ret_code_t err_code;
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    //err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
    //APP_ERROR_CHECK(err_code);
    case BLE_GAP_EVT_SCAN_REQ_REPORT:
      NRF_LOG_INFO("RSSI %d",p_ble_evt->evt.gap_evt.params.scan_req_report.rssi);
      // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing timers. */
static void timers_init(void)
        nrf_pwr_mgmt_run();
 * @brief Function for application main entry.
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    advertising_init();
    // Start execution.
    NRF_LOG_INFO("Beacon started.");
    advertising_start();
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    nrf_gpio_cfg_output(AS_SPI_CS);
    spi_config.miso_pin = SPI_MISO_PIN;
    spi_config.mosi_pin = SPI_MOSI_PIN;
    spi_config.sck_pin  = SPI_SCK_PIN;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    as_spi_write_reg(0x00,0x00);
    // Enter main loop.
    for (;;)
        idle_state_handle();
Thanks in advance
SDK_17.0.0_9d13099, nRF52832
    Could you try to implement the workaround suggested here.
    regards
    Jared
  • Hi Jared, thanks for the feedback!
    I tried switching the SPI off and then on again as described in the workaround. Power consumption resets itself. But when I initialize the SPI again, I get an error message
    <error> app: Fatal error
    <warning> app: System reset.
    Below is source code from the main function:
        // Initialize.
        log_init();
        timers_init();
        ble_stack_init();
        advertising_init();
        // Start execution.
        //[89] GPIOTE: Static 400 µA current while using GPIOTE
        *(volatile uint32_t *)0x40003FFC = 0; //Turn the SPIM off
        *(volatile uint32_t *)0x40003FFC;
        *(volatile uint32_t *)0x40003FFC = 1; //Turn the SPIM on
        //Reconfiguration of SPIM
        //<error> app: Fatal error
        //<warning> app: System reset
        // Enter main loop.
        for (;;)
    Thanks in advance
    hmm, it might be that the state of the spi parameter that is passed to the init function is invalid, could you try to initialize it to the default value and then pass it to the init function after resetting the peripheral? Also, try stepping into the function with a debugger and see where it asserts
    regards
    Jared
  • Hi Jared,
    The problem is solved. If I call function nrf_drv_spi_uninit(&spi); before re-initializing, it works perfectly.
    Thanks for your help!
  • hehe yes or that!! :P Happy that you found the root cause of the issue.
    Good luck with your projects!
    regards
    Jared
