Hi, I'm working on the MSC USB example with the nrf52840-dk.
I'm using only the SD card interface, I've disabled the others.
I've noticed that the interface is quite slow, and it has some problems with large files.
I worked with a similar interface with another mcu (lpc1769) and I found that the buffer size used to read and write the SD is critical. So I've tried to change this value in the example touching the following declaration:
* @brief Mass storage class work buffer size
#define MSC_WORKBUFFER_SIZE (1024)
I put down something like 1024*16, to have a larger size. But when I do that, the application doesn't start.
What may be the problem in this case? do I have to change something else to have a larger buffer?
thanks a lot!
