Hello.
I'm working on sdk v17 and I'm trying to control the LEDs in order using a timer.
Before using the timer, we made it easy using delays. Apps work when they receive certain data
uint8_t string_buffer[BLE_NUS_MAX_DATA_LEN+1];
memcpy(string_buffer, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
string_buffer[p_evt->params.rx_data.length] = 0;
else if(strcmp("2", string_buffer) == 0)
NRF_LOG_INFO("Left LED Moning");
printf("Left MOVE!\n");
nrf_gpio_pin_clear(LED_1); //LED Off
nrf_gpio_pin_clear(LED_2);
nrf_gpio_pin_clear(LED_3);
for(int i=0; i<5; i++) //5times
//NRF_LOG_INFO("Left LED Moving");
//printf("Left MOVE!\n");
nrf_gpio_pin_set(LED_1); //LED ON 1,2,3
nrf_delay_ms(500);
nrf_gpio_pin_set(LED_2);
nrf_delay_ms(500);
nrf_gpio_pin_set(LED_3);
nrf_delay_ms(500);
nrf_delay_ms(300);
/*nrf_gpio_pin_set(LED_1);
LeftLED_timers_start(); //without delay
LeftLED_timers_start();*/
else if(strcmp("3", string_buffer) == 0)
NRF_LOG_INFO("Right LED Moving");
printf("Right MOVE!\n");
nrf_gpio_pin_set(LED_3); //LED ON 3,2,1
nrf_delay_ms(500);
nrf_delay_ms(500);
nrf_delay_ms(500);
nrf_delay_ms(300);
APP_TIMER_DEF(m_LeftLED_timer_id); //Left LED Timer, singleshot timer
static void LeftLED_timer_handler(void * p_context)
//Use only for delay
static void timers_init(void)
ret_code_t err_code;
// Initialize timer module.
err_code = app_timer_init();
// Create Left LED timers.
err_code = app_timer_create(&m_LeftLED_timer_id,
APP_TIMER_MODE_SINGLE_SHOT, //SINGLE_SHOT or REPEATED //single shot timer
LeftLED_timer_handler);
static void LeftLED_timers_start(void)
// Start application timers.
err_code = app_timer_start(m_LeftLED_timer_id, APP_TIMER_TICKS(500), NULL); //0.5sec delay
//printf("Left_Led Start\n");
LeftLED_timers_start(); //delay
}Can you tell me what I did wrong?
Thank you very much.
