Got the MQTT_SIMPLE to work and the sensor samples from zephyr also, however, how can i mix the 2 to have the mqttsimple with some gpio and i2c sensor ? how will the overlay file be changed ?
PLEASE HELP
Thanks
PLEASE HELP
Thanks
In order to combine two, you will need to combine prj.conf of each sample and ensure that you include any needed header files and its function calls in main.c of e.g. mqtt_simple.
This means that, based on mqtt_simple combined with bme680, the prj.conf should look similar to:
# # Copyright (c) 2019 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic # # Networking CONFIG_NETWORKING=y CONFIG_NET_NATIVE=n CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y # LTE link control CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_AUTO_INIT_AND_CONNECT=n # BSD library CONFIG_BSD_LIBRARY=y # AT Host CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_AT_HOST_LIBRARY=y # MQTT CONFIG_MQTT_LIB=y CONFIG_MQTT_LIB_TLS=n # Appliaction #CONFIG_MQTT_PUB_TOPIC="/my/publish/topic" #CONFIG_MQTT_SUB_TOPIC="/my/subscribe/topic" #CONFIG_MQTT_CLIENT_ID="my-client-id" #CONFIG_MQTT_BROKER_HOSTNAME="mqtt.eclipse.org" #CONFIG_MQTT_BROKER_PORT=1883 # Main thread CONFIG_MAIN_STACK_SIZE=4096 CONFIG_HEAP_MEM_POOL_SIZE=2048 # From sensor application CONFIG_STDOUT_CONSOLE=y CONFIG_I2C=y CONFIG_SENSOR=y CONFIG_BME680=y # Needed for GPIO CONFIG_GPIO=y
I recommend searching the Kconfig reference to ensure the CONFIG_x setting it correct.
And main.c of mqtt_simple will need to call whatever the sensor sample calls in its main.c.
The board overlay file should look similar to the following, Make sure to use available pins on your board, and pay attention to shared resources
&i2c1 {
status = "okay";
sda-pin = <30>;
scl-pin = <31>;
Øyvind
Have a look at the Thingy:91 DTS file, where you can see how they do it.
-Øyvind
Thank you for your help
Will try and let you know
Thanks
Regards
