nRF52820 USB Generic HID communication
I am trying to implement Generic HID that can transmit/receive data like CDC using the generic HID example source of nRF52820 SDK 17.0.2.
But I can't do both sending and receiving data. The HID descriptor is a setting value previously used when initializing HID in other MCU.
What is wrong??? Are there any projects I can refer to?
static bool m_report_pending;
 * @brief User event handler.
static void hid_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                app_usbd_hid_user_event_t event);
static void usbd_user_ev_handler(app_usbd_event_type_t event);
 * @brief Mouse state
 * Current mouse status
struct
    int16_t acc_x;    /**< Accumulated x state */
    int16_t acc_y;    /**< Accumulated y state */
    uint8_t btn;      /**< Current btn state */
    uint8_t last_btn; /**< Last transfered button state */
}m_mouse_state;
 * @brief Mark the ongoing transmission
 * Marks that the report buffer is busy and cannot be used until transmission finishes
 * or invalidates (by USB reset or suspend event).
 #define APP_USBD_HID_METER_REPORT_DSC() {                	 			\
		0x06, 0x80, 0xFF,	/* USAGE_PAGE		| Vender Define    	*/	\
		0x09, 0x01, 		/* USAGE			| Vender Define    	*/	\
		0xa1, 0x01, 		/* COLLECTION		| Application	   	*/	\
		0x06, 0xFF, 0xFF,	/* Usage Page		| Vender Define    	*/	\
		0x19, 0x00, 		/* Usage Minimum	| 0 			   	*/	\
		0x29, 0x7F, 		/* Usage Maximum	| 127			   	*/	\
		0x15, 0x00, 		/* Logical Minimum	| 0 			   	*/	\
		0x25, 0x7F, 		/* Logical Maximum	| 127			   	*/	\
		0x75, 0x08, 		/* Report Size		| 8�r�b�g 		 	*/	\
		0x95, 0x40, 		/* Report Count 	| 64			   	*/	\
		0x81, 0x02, 		/* Input			| Variable		   	*/	\
		0x91, 0x02, 		/* Output			| Variable		   	*/	\
		0xc0				/* END_COLLECTION					   	*/	\
 * @brief Reuse HID mouse report descriptor for HID generic class
APP_USBD_HID_GENERIC_SUBCLASS_REPORT_DESC(meter_desc,APP_USBD_HID_METER_REPORT_DSC());
static const app_usbd_hid_subclass_desc_t * reps[] = {&meter_desc};
/*lint -save -e26 -e64 -e123 -e505 -e651*/
 * @brief Global HID generic instance
APP_USBD_HID_GENERIC_GLOBAL_DEF(m_app_hid_generic,
                                HID_GENERIC_INTERFACE,
                                hid_user_ev_handler,
                                ENDPOINT_LIST(),
                                reps,
                                REPORT_IN_QUEUE_SIZE,
                                REPORT_OUT_MAXSIZE,
                                REPORT_FEATURE_MAXSIZE,
                                APP_USBD_HID_SUBCLASS_NONE,
                                APP_USBD_HID_PROTO_GENERIC);
static const app_usbd_config_t usbd_config = {
	   .ev_state_proc = usbd_user_ev_handler
//= Explanation : 																				=
//= Argument(s) : 																				=
//= Return Value: 																				=
//= Comment     : 																				=
 * @brief Get maximal allowed accumulated value
 * Function gets maximal value from the accumulated input.
 * @sa m_mouse_state::acc_x, m_mouse_state::acc_y
static int8_t hid_acc_for_report_get(int16_t acc)
    if(acc > INT8_MAX)
        return INT8_MAX;
    else if(acc < INT8_MIN)
        return INT8_MIN;
        return (int8_t)(acc);
static ret_code_t idle_handle(app_usbd_class_inst_t const * p_inst, uint8_t report_id)
    switch (report_id)
        case 0:
            uint8_t report[] = {0xBE, 0xEF};
            return app_usbd_hid_generic_idle_report_set(
              &m_app_hid_generic,
              report,
              sizeof(report));
            return NRF_ERROR_NOT_SUPPORTED;
 * @brief Internal function that process mouse state
 * This function checks current mouse state and tries to send
 * new report if required.
 * If report sending was successful it clears accumulated positions
 * and mark last button state that was transfered.
global void hid_generic_mouse_process_state(void)
    if (m_report_pending)
        return;
    if ((m_mouse_state.acc_x != 0) || (m_mouse_state.acc_y != 0) || (m_mouse_state.btn != m_mouse_state.last_btn))
        ret_code_t ret;
        static uint8_t report[HID_REP_SIZE];
        /* We have some status changed that we need to transfer */
        report[HID_BTN_IDX] = m_mouse_state.btn;
        report[HID_X_IDX]   = (uint8_t)hid_acc_for_report_get(m_mouse_state.acc_x);
        report[HID_Y_IDX]   = (uint8_t)hid_acc_for_report_get(m_mouse_state.acc_y);
        /* Start the transfer */
        ret = app_usbd_hid_generic_in_report_set(
            &m_app_hid_generic,
            report,
            sizeof(report));
        if (ret == NRF_SUCCESS)
            m_report_pending = true;
            m_mouse_state.last_btn = report[HID_BTN_IDX];
            CRITICAL_REGION_ENTER();
            /* This part of the code can fail if interrupted by BSP keys processing.
             * Lock interrupts to be safe */
            m_mouse_state.acc_x   -= (int8_t)report[HID_X_IDX];
            m_mouse_state.acc_y   -= (int8_t)report[HID_Y_IDX];
            CRITICAL_REGION_EXIT();
 * @brief HID generic IN report send handling
global void hid_generic_mouse_action(hid_generic_mouse_action_t action, int8_t param)
     * Update mouse state
    switch (action)
		#if 0
        case HID_GENERIC_MOUSE_X:
            m_mouse_state.acc_x += param;
        case HID_GENERIC_MOUSE_Y:
            m_mouse_state.acc_y += param;
        case HID_GENERIC_MOUSE_BTN_RIGHT:
            if(param == 1)
                m_mouse_state.btn |= HID_BTN_RIGHT_MASK;
                m_mouse_state.btn &= ~HID_BTN_RIGHT_MASK;
        case HID_GENERIC_MOUSE_BTN_LEFT:
            if(param == 1)
                m_mouse_state.btn |= HID_BTN_LEFT_MASK;
                m_mouse_state.btn &= ~HID_BTN_LEFT_MASK;
size_t out_report_size;
uint8_t *out_report;
uint8_t out_report_0;
uint8_t out_report_1;
uint8_t out_report_2;
uint8_t out_report_3;
 * @brief Class specific event handler.
 * @param p_inst    Class instance.
 * @param event     Class specific event.
    switch (event)
        case APP_USBD_HID_USER_EVT_OUT_REPORT_READY:
            /* No output report defined for this example.*/
			out_report = (uint8_t *) app_usbd_hid_generic_out_report_get(&m_app_hid_generic, &out_report_size);
			out_report_0 = out_report[0];
			out_report_1 = out_report[1];
			out_report_2 = out_report[2];
			out_report_3 = out_report[3];
            //ASSERT(0);
        case APP_USBD_HID_USER_EVT_IN_REPORT_DONE:
            m_report_pending = false;
            hid_generic_mouse_process_state();
            //bsp_board_led_invert(LED_HID_REP_IN);
        case APP_USBD_HID_USER_EVT_SET_BOOT_PROTO:
            UNUSED_RETURN_VALUE(hid_generic_clear_buffer(p_inst));
            NRF_LOG_INFO("SET_BOOT_PROTO");
        case APP_USBD_HID_USER_EVT_SET_REPORT_PROTO:
            NRF_LOG_INFO("SET_REPORT_PROTO");
 * @brief USBD library specific event handler.
 * @param event     USBD library event.
    switch (event)
        case APP_USBD_EVT_DRV_SOF:
        case APP_USBD_EVT_DRV_RESET:
        case APP_USBD_EVT_DRV_SUSPEND:
            app_usbd_suspend_req(); // Allow the library to put the peripheral into sleep mode
            //bsp_board_leds_off();
        case APP_USBD_EVT_DRV_RESUME:
            //bsp_board_led_on(LED_USB_START);
        case APP_USBD_EVT_STARTED:
        case APP_USBD_EVT_STOPPED:
            app_usbd_disable();
        case APP_USBD_EVT_POWER_DETECTED:
            NRF_LOG_INFO("USB power detected");
            if (!nrf_drv_usbd_is_enabled())
                app_usbd_enable();
        case APP_USBD_EVT_POWER_REMOVED:
            NRF_LOG_INFO("USB power removed");
            app_usbd_stop();
        case APP_USBD_EVT_POWER_READY:
            NRF_LOG_INFO("USB ready");
            app_usbd_start();
//= Explanation : 																				=
//= Argument(s) : 																				=
//= Return Value: 																				=
//= Comment     : 																				=
global void gvUSB_HID_Initialize()
	ret_code_t ret;
	ret = app_usbd_init(&usbd_config);
    APP_ERROR_CHECK(ret);
    NRF_LOG_INFO("USBD HID generic example started.");
	//EPIN
    app_usbd_class_inst_t const * class_inst_generic;
    class_inst_generic = app_usbd_hid_generic_class_inst_get(&m_app_hid_generic);
    ret = hid_generic_idle_handler_set(class_inst_generic, idle_handle);
    ret = app_usbd_class_append(class_inst_generic);
#if 0
	//EPOUT
    if (USBD_POWER_DETECTION)
        ret = app_usbd_power_events_enable();
        NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
        app_usbd_enable();
        app_usbd_start();
