Whitelist in peripheral side
Hi
I need to connect to perticular central and i know the central MAC address. So i am using whitelisting in peripheral.
I made below changes in my code in ble_app_uart but central getting connected disconnected so fast. Did i miss something to add in code or whats the problem?
1. When i used peer_addr.addr_type = BLE_GAP_ADDR_TYPE_PUBLIC; then peripheral is seen on nrf but not able to connect and when i set BLE_GAP_ADDR_TYPE_RANDOM_STATIC no peripheral is shown  on nrf app.
    uint32_t err_code;
    ble_gap_addr_t peer_addr; //peer device address
    ble_gap_addr_t const * p_peer_addr;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
      case BLE_ADV_EVT_WHITELIST_REQUEST:
	memset(&peer_addr, 0x01, sizeof(peer_addr));
	////peer_addr.addr[0] = 0xbc;			| Reverse the order you placed these:
	////peer_addr.addr[1] = 0x41;			|
	////peer_addr.addr[2] = 0x01;			| Also note that you used wrong address,
	////peer_addr.addr[3] = 0x31;			| as I said in my reply
	////peer_addr.addr[4] = 0x8f;			|
	////peer_addr.addr[5] = 0x48; 		| Insert the address like this:
            peer_addr.addr[5] = 0x41;
            peer_addr.addr[4] = 0x4D;
            peer_addr.addr[3] = 0x9E;
            peer_addr.addr[2] = 0xF8;
            peer_addr.addr[1] = 0x50;
            peer_addr.addr[0] = 0xE1;
//// c1a7f5c23cc6
            peer_addr.addr_type = BLE_GAP_ADDR_TYPE_PUBLIC; // Add the address type
	////peer_addr pointers. Double pointers for the win! :S
	p_peer_addr = &peer_addr;
	////pp_peer_addr = &p_peer_addr; --> Remove this line
	//// Set white list
	err_code = sd_ble_gap_whitelist_set(&p_peer_addr, 0x01); //swap pp_peer_addr with &p_peer_addr, like this
	if (err_code == NRF_SUCCESS)
		printf("Successfully set whitelist!\r\n");
        printf("Whitelist not set\r\n");
	APP_ERROR_CHECK(err_code); //Added an error check, always useful to have.
	//// White list reply
	err_code = ble_advertising_whitelist_reply(&m_advertising,p_peer_addr, 1, NULL, (uint32_t) NULL);
		printf( "Whitelist replied\r\n");
        printf("Whitelist not replied\r\n");
    ret_code_t             err_code;
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = false;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;  // Comment this line out if you havn't done it already
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.advdata.flags                     = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED; // These two lines are correct
    init.config.ble_adv_whitelist_enabled = true;									//
Please suggest how to connect one peripheral to particular central?
    Is the central always going to have a static address? Note that whitelisting of Android and iOS devices will require support for bonding as you will need a way to get their identity resolving key (IRK) for address resolving.
     The configured address type must match the actual address input. I expect that's not the case seen it doesn't start advertising. Does sd_ble_gap_whitelist_set() return an error?
  • No error is coming with sd_ble_gap_whitelist_set() api.
    Is there any chnages required in central side?
  • There must be an error returned somewhere if it doesn't start advertising.
  • Hi
    I also tried to make changes just like hid_keyboard example still its not working .
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "fds.h"
    #include "nrf_fstorage.h"
    #include "ble_err.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SEC_PARAM_BOND                      1                                          /**< Perform bonding. */
    #define SEC_PARAM_MITM                      0                                          /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                      0                                          /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS                  0                                          /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                       /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                       0                                          /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE              7                                          /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE              16                                         /**< Maximum encryption key size. */
    //bool erase_bonds = true;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static pm_peer_id_t      m_peer_id;                                 /**< Device reference handle to the current bonded central. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    static void advertising_start(bool erase_bonds);
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    //add
    void whitelist_set(pm_peer_id_list_skip_t skip)
    pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
        uint32_t     peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
        ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
        NRF_LOG_INFO("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
                       peer_id_count + 1,
                       BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
        err_code = pm_whitelist_set(peer_ids, peer_id_count);
    static void identities_set(pm_peer_id_list_skip_t skip)
        pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
        uint32_t     peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
        err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
        printf("delete bond\r\n");
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
         switch (p_evt->evt_id)
            case PM_EVT_CONN_SEC_SUCCEEDED:
                m_peer_id = p_evt->peer_id;
                advertising_start(false);
            case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
                if (     p_evt->params.peer_data_update_succeeded.flash_changed
                     && (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
                    NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
                    // Note: You should check on what kind of white list policy your application should use.
                    whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
    case BLE_ADV_EVT_DIRECTED_HIGH_DUTY:
             NRF_LOG_INFO("Directed advertising.");
             err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_DIRECTED);
             NRF_LOG_INFO("Fast advertising.");
    #if SWIFT_PAIR_SUPPORTED == 1
               err_code = ble_advertising_advdata_update(&m_advertising, &m_sp_advdata_buf, false);
    case BLE_ADV_EVT_SLOW:
              NRF_LOG_INFO("Slow advertising.");
              err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
    case BLE_ADV_EVT_FAST_WHITELIST:
             NRF_LOG_INFO("Fast advertising with whitelist.");
             err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
    case BLE_ADV_EVT_SLOW_WHITELIST:
              NRF_LOG_INFO("Slow advertising with whitelist.");
            sleep_mode_enter();
                ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
                ble_gap_irk_t  whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
                uint32_t       addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
                uint32_t       irk_cnt  = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
                err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                                            whitelist_irks,  &irk_cnt);
                NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
                              addr_cnt, irk_cnt);
                // Set the correct identities list (no excluding peers with no Central Address Resolution).
                identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
    // Apply the whitelist.
                                                           whitelist_addrs,
                                                           addr_cnt,
                                                           whitelist_irks,
                                                           irk_cnt);
    case BLE_ADV_EVT_PEER_ADDR_REQUEST:
    pm_peer_data_bonding_t peer_bonding_data;
                // Only Give peer address if we have a handle to the bonded peer.
                if (m_peer_id != PM_PEER_ID_INVALID)
                    err_code = pm_peer_data_bonding_load(m_peer_id, &peer_bonding_data);
                    if (err_code != NRF_ERROR_NOT_FOUND)
                        // Manipulate identities to exclude peers with no Central Address Resolution.
                        identities_set(PM_PEER_ID_LIST_SKIP_ALL);
                        ble_gap_addr_t * p_peer_addr = &(peer_bonding_data.peer_ble_id.id_addr_info);
                        err_code = ble_advertising_peer_addr_reply(&m_advertising, p_peer_addr);
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
             uint32_t err_code;
    init.advdata.include_appearance = true;
    init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids = m_adv_uuids;
    init.config.ble_adv_directed_high_duty_enabled = true;
    init.config.ble_adv_fast_enabled = true;
    // init.config.ble_adv_slow_enabled = true;
    // init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
    // init.config.ble_adv_slow_timeout = APP_ADV_SLOW_DURATION;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
        if (erase_bonds == true)
            delete_bonds();
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
            ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
            APP_ERROR_CHECK(ret);
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        //peer_manager_init();
        // Start execution.
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
            idle_state_handle();
    In this code the board is not advertise.Please tell me where i am going wrong?
    Please try to debug the application to find out why it's not advertising. Most likely you have an error being passed to one of the APP_ERROR_CHECK() macros which will cause the SDK Error module to get invoked.
