Zephyr CustomBoard with NRF52840 and MCP23S17
Hello folks
I have been struggling for some time with the driver for the MCP23S17 in Zephyr.
I have already tried this code:
https://devzone.nordicsemi.com/f/nordic-q-a/64024/sample-mcp23s17-driver
But for me its not working!
I receive the following error:
/home/trug/zephyrproject/zephyr/include/devicetree.h:158:36: error: 'DT_N_NODELABEL_spi2gpio_P_label' undeclared (first use in this function); did you mean 'DT_N_NODELABEL_gpiote'?
  158 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
/home/trug/zephyrproject/zephyr/include/devicetree.h:1526:38: note: in definition of macro 'DT_CAT'
 1526 | #define DT_CAT(node_id, prop_suffix) node_id##prop_suffix
/home/trug/zephyrproject/zephyr/include/devicetree.h:390:27: note: in expansion of macro 'DT_PROP'
  390 | #define DT_LABEL(node_id) DT_PROP(node_id, label)
../src/main.c:80:27: note: in expansion of macro 'DT_LABEL'
   80 | #define MCP23S17_DEV_NAME DT_LABEL(DT_NODELABEL(spi2gpio))
/home/trug/zephyrproject/zephyr/include/devicetree.h:158:29: note: in expansion of macro 'DT_CAT'
../src/main.c:80:36: note: in expansion of macro 'DT_NODELABEL'
../src/main.c:106:51: note: in expansion of macro 'MCP23S17_DEV_NAME'
  106 |  struct device *mcp23s17_dev = device_get_binding(MCP23S17_DEV_NAME);
This is my main.c
#include <zephyr.h>
#include <device.h>
#include <devicetree.h>
#include <drivers/gpio.h>
#include <sys/printk.h>
#include <drivers/uart.h>
#include <logging/log.h>
#include "CustomBoard.h"
LOG_MODULE_REGISTER(net_google_iot_mqtt, LOG_LEVEL_DBG);
/* This comes from newlib. */
#include <time.h>
#include <inttypes.h>
void main(void)
	int ret;
	LOG_INF(">>> Test: Driver MCP23S17 <<<");
	// MCP23S17
	if (!mcp23s17_dev) {
		LOG_INF("Cannot find mcp23s17!\n");
		return;
	ret = gpio_pin_configure(mcp23s17_dev, 1, GPIO_OUTPUT_ACTIVE);
	while (1) {
		gpio_pin_set(mcp23s17_dev, 1, (int)true);
		k_msleep(125);
		gpio_pin_set(mcp23s17_dev, 1, (int)false);
I compared it to some other drivers in zephyr and also tried the following defines in the main.c (but no of them are working)
//#define    MCP23S17_DEV_NAME    DT_LABEL(DT_NODELABEL("spi2gpio"))
//#define    MCP23S17_DEV_NAME    DT_LABEL(DT_NODELABEL(mcp23s17))
//#define    MCP23S17_DEV_NAME    DT_INST(0, spi2gpio)
//#define    MCP23S17_DEV_NAME    DT_LABEL(DT_INST(0, microchip_mcp23s17)
//#define    MCP23S17_DEV_NAME    DT_LABEL(DT_INST(0, mcp23s17)
//#define    MCP23S17_DEV_NAME    "GPIO_MCP23S17"
//#define    MCP23S17_DEV_NAME    "microchip_mcp23s17"
Here is my .overlay file:
/* GPIO Expander */
&spi2 {
    label="SPI2";
    status = "okay";
    sck-pin = <22>;
    mosi-pin = <23>;
    miso-pin = <24>;
    cs-gpios = <&gpio1 1 0>;
    spi2gpio: gpio@0 {
    	label="mcp23s17";
        compatible="microchip,mcp23s17";
        gpio-controller;
        #gpio-cells = <2>;
        spi-max-frequency = <800000>;
        reg = <0>;
	    #ngpios = <16>;
Here are my configs from my prj.confg
# Driver: GPIO
CONFIG_GPIO=y
CONFIG_GPIO_MCP23S17=y
# SPI
CONFIG_SPI=y
CONFIG_SPI_2=y
# UART support
CONFIG_SERIAL=y
CONFIG_UART_CONSOLE=n
# Print
CONFIG_PRINTK=y
# RTT Segger Debugger
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
What am I doing wrong? Can anyone help me or give me an example?
Regards
Dominique
  • What tag are you using? I tested your sample with NCS v1.3.0 and it built without any errors. The only change I made was to swap #ngpios with ngpios in the overlay file.
    Simon
  • Thanks Simon
    I tried to build the firmware as nrf52840dk_nrf52840 and it worked fine.
    But it does not work with my customboard.
    Since my customboard is not in the Zephyr directory, it could be a CMake problem?!
    I will check it and as soon as I find a solution, I will post it here.
  • Since the Zephyr version of Nordic is lagging behind, I use the latest version of Zephyr (2.4). I use some drivers on my customboard that are not yet included in the NCS.
    Do you think this could also lead to further problems?
  • Could you upload your board folder in zipped format, then I can test it myself? Have you seen this guide? Try following that when creating your board folder.
    Simon
  • Ok I found my problems:
    1.  Custom board error
    Between the Zephyr version 2.1.0 and version 2.4.0 are some differences.
    1.1 In XXX_defconfig the following configs aren't supported anymore:
    CONFIG_ARM=y
    CONFIG_SOC_FAMILY_NRF=y
    1.2 In XXX.dts
    compatible = "nordic,nrf52840-qiaa"; is not working!
    I use compatible = "nordic,nrf52840-dk-nrf52840"; instead.
    2. MCP23S17 pins
    The gpio expander mcp23s17 uses low active reset (nReset) and low active chip select (nCS).
    In my XYZ.overlay file I have to set the CS Pin to 1
    Wrong:
    Correct:
        cs-gpios = <&gpio1 1 1>;
    3. My solution
    3.1 Here my .overlay file
    /* GPIO Expander */
    &spi2 {
        label="SPI2";
        status = "okay";
        sck-pin = <36>;
        mosi-pin = <37>;
        miso-pin = <38>;
        spi2gpio: gpio@0 {
        	label="mcp23s17";
    	compatible = "microchip,mcp23s17";
            gpio-controller;
            #gpio-cells = <2>;
            reg = <0>;
    	ngpios = <16>;
    3.2 Here my main.c for testing
    #include <zephyr.h>
    #include <device.h>
    LOG_MODULE_REGISTER(blinky_logging, LOG_LEVEL_DBG);
    /* 1000 msec = 1 sec */
    #define SLEEP_TIME_MS   1000
    /* The devicetree node identifier for the "led0" alias. */
    #define LED0_NODE DT_ALIAS(led0)
    #if DT_NODE_HAS_STATUS(LED0_NODE, okay)
    #define LED0		DT_GPIO_LABEL(LED0_NODE, gpios)
    #define PIN_LED0	DT_GPIO_PIN(LED0_NODE, gpios)
    #define FLAGS_LED0	DT_GPIO_FLAGS(LED0_NODE, gpios)
    #else
    /* A build error here means your board isn't set up to blink an LED. */
    #error "Unsupported board: led0 devicetree alias is not defined"
    #define LED0		""
    #define PIN_LED0	0
    #define FLAGS_LED0	0
    /* The devicetree node identifier for the "led1" alias. */
    #define LED1_NODE DT_ALIAS(led1)
    #if DT_NODE_HAS_STATUS(LED1_NODE, okay)
    #define LED1		DT_GPIO_LABEL(LED1_NODE, gpios)
    #define PIN_LED1	DT_GPIO_PIN(LED1_NODE, gpios)
    #define FLAGS_LED1	DT_GPIO_FLAGS(LED1_NODE, gpios)
    #else
    #define LED0		""
    #define PIN_LED1	1
    #define FLAGS_LED1	1
    void main(void)
    	k_msleep(1000);
    	LOG_INF(">>> [main]: Test Application <<<");
    	const struct device *dev_led_0,*dev_led_1;
    	const struct device *mcp23s17_dev,*gpio_port0_dev;
    	bool led_is_on = true;
    	int ret,i;
    	// MCP23S17
    	LOG_INF("[main]: MCP23S17_Init");
    		return;
    	for(i=0; i<16; i++){
    		ret = gpio_pin_configure(mcp23s17_dev, i, GPIO_OUTPUT_ACTIVE);
    		if (ret < 0) {
    			return;
    	// GPIO Port_0
    	LOG_INF("[main]: GPIO_Port0_Init");
    	gpio_port0_dev = device_get_binding(CONFIG_GPIO_PORT_0);
    	if (gpio_port0_dev == NULL) {
    		return;
    	ret = gpio_pin_configure(gpio_port0_dev, GPIO_EXP_RST, GPIO_OUTPUT_ACTIVE);
    	if (ret < 0) {
    		return;
    	gpio_pin_set(gpio_port0_dev, GPIO_EXP_RST, (int)true);
    	// LED
    	LOG_INF("[main]: LED_Init");
    	dev_led_0 = device_get_binding(LED0);
    	dev_led_1 = device_get_binding(LED1);
    	if (dev_led_0 == NULL && dev_led_1 == NULL) {
    		LOG_INF("LEDs not found!\n");
    		return;
    	ret = gpio_pin_configure(dev_led_0, PIN_LED0, GPIO_OUTPUT_ACTIVE | FLAGS_LED0);
    	if (ret < 0) {
    		return;
    	ret = gpio_pin_configure(dev_led_1, PIN_LED1, GPIO_OUTPUT_ACTIVE | FLAGS_LED1);
    	if (ret < 0) {
    		return;
    	// While
    	LOG_INF("[main]: while");
    	while (1) {
    		gpio_pin_set(dev_led_0, PIN_LED0, (int)led_is_on);
    			//LOG_INF(">>> [main:while]: gpio[%i]=[%i]  <<<",i,(int)led_is_on);
    			gpio_pin_set(mcp23s17_dev, i, (int)led_is_on);
    		LOG_INF("[main:while]: gpio[XYZ]=[%i]",i,(int)led_is_on);
    		led_is_on = !led_is_on;
    		k_msleep(SLEEP_TIME_MS);
    		gpio_pin_set(dev_led_1, PIN_LED1, (int)led_is_on);
