I found there was a example in "nRF5_SDK_15.2.0_9412b96\examples\dfu\secure_bootloader\pca10056_uart\arm5_no_packs" .
Is there a applicaion example that when it recv a specific data like "AT+UPDATE" from uart, it can switch to bootloader and start to DFU.
The bootloader code is as follows:
* Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup bootloader_secure_ble main.c
* @ingroup dfu_bootloader_api
* @brief Bootloader project main file for secure DFU.
#include <stdint.h>
#include "boards.h"
#include "nrf_mbr.h"
#include "nrf_bootloader.h"
#include "nrf_bootloader_app_start.h"
#include "nrf_bootloader_dfu_timers.h"
#include "nrf_dfu.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "app_error.h"
#include "app_error_weak.h"
#include "nrf_bootloader_info.h"
#include "nrf_delay.h"
static void on_error(void)
NRF_LOG_FINAL_FLUSH();
#if NRF_MODULE_ENABLED(NRF_LOG_BACKEND_RTT)
// To allow the buffer to be flushed by the host.
nrf_delay_ms(100);
#ifdef NRF_DFU_DEBUG_VERSION
NRF_BREAKPOINT_COND;
NVIC_SystemReset();
void app_error_handler(uint32_t error_code, uint32_t line_num, const uint8_t * p_file_name)
NRF_LOG_ERROR("%s:%d", p_file_name, line_num);
on_error();
void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
NRF_LOG_ERROR("Received a fault! id: 0x%08x, pc: 0x%08x, info: 0x%08x", id, pc, info);
on_error();
void app_error_handler_bare(uint32_t error_code)
NRF_LOG_ERROR("Received an error: 0x%08x!", error_code);
on_error();
* @brief Function notifies certain events in DFU process.
static void dfu_observer(nrf_dfu_evt_type_t evt_type)
switch (evt_type)
case NRF_DFU_EVT_DFU_FAILED:
case NRF_DFU_EVT_DFU_ABORTED:
case NRF_DFU_EVT_DFU_INITIALIZED:
// bsp_board_init(BSP_INIT_LEDS);
// bsp_board_led_on(BSP_BOARD_LED_0);
// bsp_board_led_on(BSP_BOARD_LED_1);
// bsp_board_led_off(BSP_BOARD_LED_2);
case NRF_DFU_EVT_TRANSPORT_ACTIVATED:
// bsp_board_led_off(BSP_BOARD_LED_1);
// bsp_board_led_on(BSP_BOARD_LED_2);
case NRF_DFU_EVT_DFU_STARTED:
/**@brief Function for application main entry. */
uint32_t ret_val;
// Protect MBR and bootloader code from being overwritten.
ret_val = nrf_bootloader_flash_protect(0, MBR_SIZE, false);
APP_ERROR_CHECK(ret_val);
ret_val = nrf_bootloader_flash_protect(BOOTLOADER_START_ADDR, BOOTLOADER_SIZE, false);
(void) NRF_LOG_INIT(nrf_bootloader_dfu_timer_counter_get);
NRF_LOG_INFO("Inside main");
ret_val = nrf_bootloader_init(dfu_observer);
// Either there was no DFU functionality enabled in this project or the DFU module detected
// no ongoing DFU operation and found a valid main application.
// Boot the main application.
nrf_bootloader_app_start();
// Should never be reached.
NRF_LOG_INFO("After main");
